  • wusel0464
  • wusel0464
02 Jun 2025 14:38
Replied by wusel0464 on topic Reading variable from ini no longer works?
Category: Qtvcp
Hello,
I once exchanged tab for spaces, but that makes no difference. I suspect that the reader routine does not recognize the comment as such.
Incidentally, my INI file is not as chaotic as there, I just copied it in and this strange arrangement came out.
In practice, everything is nicely arranged in the INI.
Many greetings Frank
  • H-S-W
  • H-S-W
02 Jun 2025 12:55 - 02 Jun 2025 12:56
Replied by H-S-W on topic Index homing Heidenhain ls 403/exe602
Category: Basic Configuration
Unfortunately I do not have any coding experience...
like i mentioned in previous post a "C" at the end "LS 403 C", indicates you have a distance coded version of the scale. Do you also have an interpolator like the exe 602?
I doubt i'll manage to HAL such a custom component myself, but I have my mill moving and would of course be willing to do some testing if someone has some time over to give it a try!
/Hampus
  • NT4Boy
  • NT4Boy
02 Jun 2025 12:35
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
I think this is a raspberry PI issue as there is no fast sample rate option in the halscope.
Hopefully won't affect what I am doing, other than spoil my pictures.
  • Hakan
  • Hakan
02 Jun 2025 12:24
Ohmic sensing with IPTM-60 was created by Hakan
Category: Show Your Stuff
A break-out box.
A car relay.
Break the arc start ground cable when sensing.
And ohmic sensing works with the IPTM-60.
No modifications to the plasma cutter.
Standard arc voltage reader used, I use my own THTIC2.
  • atrex77
  • atrex77's Avatar
02 Jun 2025 11:19 - 02 Jun 2025 11:21
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
a full revision on the previous PCB:
All 24v inputs and outputs optical isolated, PWM exchanged to 12Bit DA controller for the analog output.
  • Hakan
  • Hakan
02 Jun 2025 10:27
Replied by Hakan on topic ethercat-conf.xml pdoentry limits?
Category: EtherCAT
Like this
      <sdoConfig idx="2002" subIdx="0"><sdoDataRaw data ="0a 00 00 00" /></sdoConfig> <!-- Lowpass filter pole frequency try 10 Hz -->
place before all syncmanagers in ethercat-conf.xml
Only thing to say here is that the byte order is reversed. Least significant byte comes first.
You can try to read out and set manually using
ethercat -p 0 upload 0x6064 0  # Read actual position
ethercat -p 0 download 0xregister subindex value #  write value to register
  • unknown
  • unknown
02 Jun 2025 10:25
installing linuxCNC 2.7.14 under Hyper-V Manager
Category: Installing LinuxCNC
Host System Linux Mint 22.2 Xia
VirtualBox 7.18
Guest
32 Bit System 4GB Ram 16GB HDD
Bridged Network
Install went fine about 5 or 10 miuntes, boots fine.
Obviously Wheezy is EOL so upgrades maybe a bit funky
Linuxcnc upgrade were fine
Installation of Midnight Commander & Geany went fine
Axis sim run as expected
Shutdown was clean
Langdons, before commenting please try to read the other posts.
VirtualBox was suggested
The last error log was from VirtualBox
This behaviour only frustrates people.
  • Cooped-Up
  • Cooped-Up
02 Jun 2025 10:19
Replied by Cooped-Up on topic Mesa card issues Maho MH800E Retrofit Project
yea so creating another new config is just working for some reason... that is weird
  • Cooped-Up
  • Cooped-Up
02 Jun 2025 10:10
The attach didnt work so here is the copy paste
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/coopedup/linuxcnc/configs/MH800E'
Machine configuration file is 'MH800E.ini'
INIFILE=/home/coopedup/linuxcnc/configs/MH800E/MH800E.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./MH800E.hal
Running HAL shutdown script
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25t at 0000:04:06.0
hm2/hm2_5i25.0: Low Level init 0.15
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin tx1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin rx1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:06.0
hm2_5i25.0: dropping AnyIO board at 0000:04:06.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
No input devices could be opened. This usually indicates a misconfigured
system. Please read the section 'PERMISSIONS AND UDEV' in the hal_input
manpage
./MH800E.hal:12: waitpid failed hal_input hal_input
./MH800E.hal:12: hal_input exited without becoming ready
1211
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f956125a000
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Sun Dec 1 08:29:00 AM EST 2024
UTC Date: Sun Dec 1 01:29:00 PM UTC 2024
this program: /usr/bin/linuxcnc_info
uptime: 08:29:00 up 0 min, 1 user, load average: 1.51, 0.37, 0.12
lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm
linuxcnc: /usr/bin/linuxcnc
pwd: /home/coopedup/linuxcnc/configs/MH800E
USER: coopedup
LOGNAME: coopedup
HOME: /home/coopedup
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/coopedup/linuxcnc/configs/MH800E/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: coopedup
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-rt-amd64 root=UUID=b581ec7e-d84c-481b-a4e0-faa5ae23e5e5 ro initrd=/install/gtk/initrd.gz quiet
model name: AMD FX(tm)-8320 Eight-Core Processor
cores: 4
cpu MHz: 3515.449
parport: 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 12.2.0-14) 12.2.0
python: Python 3.11.2
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-de 1:2.9.4 all motion controller for CNC machines and robots (German documentation)
ii linuxcnc-doc-en 1:2.9.4 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.9.4 all motion controller for CNC machines and robots (Spanish documentation)
ii linuxcnc-doc-fr 1:2.9.4 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.4 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.9.4 amd64 PC based motion controller for real-time Linux
  • Cooped-Up
  • Cooped-Up
02 Jun 2025 10:09
here is that log, I dont remember selecting an MPG but maybe I did.
  • NT4Boy
  • NT4Boy
02 Jun 2025 10:06 - 02 Jun 2025 10:17
What I hope will be the last part of my adventure, is to add a spindle encoder for rigid tapping etc.Mission now achieved. 48 teeth on the lower side of the drive pully as well as an index tooth on the upper side, (complete with counterbalance weight).Have used ATS616LSG hall effects, with 10k biasing resistors which produce at the 7i77 encoder 05 inputs, good clean 5volt signals.I have yet to get properly to grips with the hal side of things, but at first sight, the hal scope doesn’t look right.
  • esmurf
  • esmurf
02 Jun 2025 09:47
Replied by esmurf on topic ethercat-conf.xml pdoentry limits?
Category: EtherCAT
is this the <initcmd> tag?
  • Hakan
  • Hakan
02 Jun 2025 09:02
Category: EtherCAT
I don't know that, but if you have static data you can set that using the SDO instead.
  • esmurf
  • esmurf
02 Jun 2025 08:58
Category: EtherCAT
These servos have so many functions and parameters, that 10 is a really small limit.
Is there a way to split the pdoentry tags into multiple pdos?
Or change them during operation, e.g. have a different ethercat-conf.xml during homing vs. normal operation?
Displaying 15061 - 15075 out of 16327 results.
Time to create page: 0.671 seconds
