  • cmorley
  • cmorley
29 May 2025 01:28
Replied by cmorley on topic Keyboard shortcut rempaping
Category: Qtvcp
oops here is the new file.
  • cmorley
  • cmorley
29 May 2025 01:25
Category: Qtvcp
Here is a slightly different file to try. replace the one I gave before.
I think there still will be a focus problem if you click the gcode display then spacebar.
But clicking the window or graphics display should refocus so space bar works again.
If you can confirm these things, I will look further into the gcode display problem.
Focus problems are always a pain!
  • kworm
  • kworm
29 May 2025 00:33
Mesa 7i95t connection to Thermal Dynamics 60i
Category: Plasma & Laser
I'm converting a Crossfire Pro to LinuxCNC using a Mesa 7i95t and THCAD2.  I have the automation interface card in the cutmaster 60i so it has the torch start/stop, voltage divider, ok to move, and ohmic sensing on the CPC connector.  I'm still waiting for the THCAD2 to come in but the wiring for it seems pretty straight forward.  I've attached the wiring diagram from the service manual and I'm not quite sure if I can just wire the start/stop directly to a 7i95t output or if I need to use a relay.  If I understand the qtplasmac docs I should be able to connect the ok to move directly to an input but may need a resistor if the current draw isn't enough.  I may hook up ohmic later but would I need another THCAD2 for it as well?
Thanks,
Kevin
28 May 2025 22:03
Replied by tommylight on topic Need 8i20
Need 8i20
Category: User Exchange
You lucky .... :)
You are welcomed, always.
  • bassti
  • bassti
28 May 2025 21:36
Replied by bassti on topic Need 8i20
Need 8i20
got one ...
thanks
  • PCW
  • PCW's Avatar
28 May 2025 21:12 - 29 May 2025 14:35
Replied by PCW on topic Mesa modbus and pktUart
Category: Other User Interfaces
I wanted to say that there is a new Modbus interface: hm2_modbus
available for all Mesa cards, and that fixes a lot of the issues with mesa-modbus.
hm2_modbus needs the latest snapshot of 2.9.4 or master. and may require
a firmware upgrade to at least V2 PktUART.
It adds the ability to have multiple devices on the same RS-485 interface,
device initialization/setup code that only runs once, plus many bug fixes.
Its been running a 25IOC32_PNP for a more than a week now with 0 issues.
The configuration file has a different format (XML) than mesa-modbus.
This format is documented in the mesambccc man page ( mesambccc is
the hm2_modbus configuration file compiler)
  • Studio_TC
  • Studio_TC
28 May 2025 19:39
Replied by Studio_TC on topic Getting Setup with PC and MESA
Happy to provide any info when I get up and running. I'll post the sys specs and latency tests when I can.
  • juliankoenig87
  • juliankoenig87
28 May 2025 19:01 - 28 May 2025 19:04
Replied by juliankoenig87 on topic Getting Setup with PC and MESA
Cool. M710q works fine. Have one in a router installed. Can give you the grub infos for the first test.
Just for information. Have also a M2 to realtek nic installed in the m710q which runs stable 2 kHz servo thread. But that isnt necessary. The internal intel nic runs 1 kHz with ease.
  • MRTtechnology
  • MRTtechnology's Avatar
28 May 2025 18:24
Replied by MRTtechnology on topic 7i97T+7i74+7i84+7i73
Category: Driver Boards
Hi guys
I want to connect two MPGs to the encoder inputs of the 7i73
My MPG has A+A-B+B- OV5V e and use two analogue inputs.
To do this, I'll have to use mode 1 on the 7i73 board
Has anyone configured this board in encoder+analogue mode?
  • Studio_TC
  • Studio_TC
28 May 2025 17:32
Thanks, you put my mind at ease. I ordered a refurbished ThinkCentre M710q last night and got the MESA card ordered. Now I have a table to build while I wait for the hardware.
  • juliankoenig87
  • juliankoenig87
28 May 2025 16:21 - 28 May 2025 16:28
How to refresh the Axis screen after setting offsets G10 L20
Category: AXIS
I use M codes for this kind of stuff also. For example M130.
github.com/hausen8/EasyProbe/blob/v2.0/nc_files/M130
Use with:
M130 P255
I am not sure right know, but I had something in mind while writing  "&".
Also some sleeps are always a good idea. Sometimes it gets lost otherwise.
Best regards
Julian
28 May 2025 15:35
Replied by tommylight on topic 7i97T+7i74+7i84+7i73
As Darth Vader once said: welcome to the dark side! :)
  • MRTtechnology
28 May 2025 15:19
My test bench
I know it's nothing to you experts, but for me it's a big step.
  • MRTtechnology
28 May 2025 15:11
hi guys i managed to get the communication between Rp1 7i97t+7i744+7i84+7i73 working
Thank you for your help.
  • SwitchWitch
  • SwitchWitch
28 May 2025 15:09
Replied by SwitchWitch on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
I would really like to, but I have to wait a little bit with the next invest in my hobby.
Displaying 15256 - 15270 out of 16336 results.
Time to create page: 0.333 seconds
