  • Cdub
  • Cdub
22 May 2025 20:55
M62-M68 codes not working was created by Cdub
Category: Plasmac
I can figure out why my feed rate percentages and thc on/off isn’t working. Feed rate is just constantly the same and doesn’t change unless I change it manually and thc doesn’t turn off unless I turn it off manually. The g code commands are doing nothing. G code attached bellow. I made a new install media with 9.4 and reinstalled linuxcnc completely just to make sure I wasn’t out of date with anything.
(test2)
(5/22/2025 2:48 PM)
(ProNest LT 16.2.0.9215 PostBuilder 2.88 Linux CNC PlasmaC)
N10 G20
N15 G90 G40
N20 G17 G91.1
N25 G64 P0.01 Q0.01
N30 M52 P1 (Allow paused motion)
N35 M52 P0 (Disable paused motion)
N40 M65 P2 (Enable THC)
N45 M65 P3 (Allow torch on)
N50 M68 E3 Q0 (100% feed)
N55 G0 X3.088 Y3.9014
(0.375--1--D751-0243-00-Default - Seq 1)
N60 M190 P1 (Select material 1)
N65 M66 P3 L3 Q1 (1s delay to allow material selection)
N70 F#<_hal[plasmac.cut-feed-rate]>
N75 M3 $0 S1
N80 M68 E3 Q20 (Set to 20% feed)
N85 M62 P2 (Disable THC)
N90 G3 X2.8229 Y3.6363 I-0.1325 J-0.1326
N95 G3 X2.8229 Y3.6363 I0.4329 J0.4329
N100 G3 X3.088 Y3.6363 I0.1326 J0.1325
N105 M68 E3 Q100 (Reset to 100% feed)
N110 M5
N115 M65 P2 (Enable THC)
N120 G0 X0.7118 Y0.4627
N125 M3 $0 S1
N130 M63 P2 (Enable THC)
N135 G1 X0.7118 Y0.8377
N140 G1 X0.7118 Y5.8999
N145 G1 X1.2376 Y6.4257
N150 G1 X4.274 Y6.4257
N155 G1 X5.2998 Y5.3999
N160 G1 X5.2998 Y1.8635
N165 G1 X4.274 Y0.8377
N170 G1 X0.7118 Y0.8377
N175 G1 X0.4618 Y0.8377
N180 M5
N185 G0 X0.0 Y0.0
N190 M30
  • PCW
  • PCW's Avatar
22 May 2025 20:51 - 22 May 2025 21:00
MESA 7i76 - Lenze VFD: Where are the 10V
Category: Driver Boards
Looks like the VFD (or I/O module) does not supply 10V, but it does
supply 5V and you can set the input to accept 0 to 5V instead of 0 to 10V
7I76           Drive
SPIN+        9      (+5V)
SPINOUT    1U    (VIN)
SPIN-          7      (GND)
My guess on the others is that:
28 is drive-on  (wire +24 to 7I76 ENA+ and 7I76 ENA- to 28)
59 is +12 to +24V power (same as 7I76 field power)
7 is GND (same as 7I76 field power GND)
A1 is an output (wire to a 7I76 field input)
Might be a fault or at-speed indication, need to look at
the drive settings to know.
2U is another analog input, no real idea what this was doing
but if you look at the current drive settings, it may give you a clue.
  • robocidalmaniac
  • robocidalmaniac's Avatar
22 May 2025 20:26
Replied by robocidalmaniac on topic How to Control a PWM Gripper
Category: G&M Codes
Please do you have any more details on this?
How do you use the M68 to open?
How do you use the M68 to close?
Do you have M68 (number value)?
  • scotta
  • scotta's Avatar
22 May 2025 20:25
Hi DarkPhoinix,
The Step Length and Step Space need to be integers / whole numbers. So go with 5 and 3.
  • TheRealMable
  • TheRealMable
22 May 2025 19:59 - 22 May 2025 20:01
MESA 7i76 - Lenze VFD: Where are the 10V was created by TheRealMable
Hi, I my name is Chrstian and I tend to read more on forums than to write. But as many others I am in some kind of a dead end and could use some advice...
Backstory:
I bought an used self build CNC Router. The controls were build around an USB Smooth Stepper and Mach3. Since the controls are not repair friendly (too much stuff packed in too little space with custom layout boards and same color wires) and I am more a Linux than a Windows guy, I am in the process to upgrade to LinuxCNC.
I use an 7i92 and an 7i76
One of the last steps missing is the spindle control (1,5kw china spindle with ER16). For some reason the person, who built the router went with an "Lenze 822MV" 400V 2,2kw VFD.
After the long introduction, my question:
Where can I get my 10V reference (Spindle +) from this VFD? If someone might take a look and give me a hint, I would appreciate it.
The manual for the "Application IO Module" that is used, can be found here: www.becker-antriebstechnik.org/WebRoot/H...__v6-0__DE_EN_FR.pdf
(page 21 starts the english description)
The manual for the actual VFD (should not matter that much, just in case):https://www.lenze.com/en-de/products/inverters/previous-products-inverters/8200-motec
Currently connections A1, 2x7 (GND), 59, 28 and 2U are connected. I have absolutely no Idea where they go to...
In case the VFD does not have an 10V reference voltage, what are my options? Do the cheap 20€ 4channel 2,5V, 5V, 7.5V, 10V reference voltage things from ebay work?
Am I missing something?
Thanks in advance for the help (and all the help I got from the forum without having to ask).
Christian aka TheRealMable
  • besriworld
  • besriworld
22 May 2025 19:05
Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
At a later stage, I plan to add an additional 1kW servo motor, which will operate in torque mode to act as a dynamic load on the main 7kW motor. This will increase the system's rigidity. Currently, I'm using the encoder from the main motor
  • spumco
  • spumco
22 May 2025 18:46
I don't have copy on hand, but if you search through my posts you should find some of the later caxis.comp configs attached.  Maybe 4-6 months ago or so?
I tried step/dir and pwm, so there may be examples of both attempts somewhere in the forum.
Something to keep in mind is that for rotary axis work you want the highest resolution encoder (or resolver) you can get.  NoJo (OP) I think reported problems with C-axis milling and feature alignment due to a moderate-count encoder.
Of course, high counts and a high-speed spindle means problems with max input speed.  I wound up with a 10k-line encoder on my 3500rpm spindle... which works but I had to turn off Mesa input filtering.
Another issue I think I encountered with NoJo's polar kinematics was that he hard-coded the live tool offset in to the component.  He only had a single live tool so that worked for him, but a re-write which uses a tool offset from the tool table might be wise.
  • atrex77
  • atrex77's Avatar
22 May 2025 18:42 - 22 May 2025 18:43
W5100S-EVB-PICO stepgenerator and encoder driver
Update
1.variable pulse width for the step generator (1000nS - 6000nS) set from hal pin.
2.work with pico + w5500 module (connections like in the w5100s-evb-pico)
  • eliaslau28
  • eliaslau28
22 May 2025 18:41
Mesa Sammelbestellung was created by eliaslau28
Category: Deutsch
Hallo zusammen,
ich plane aktuell eine Sammelbestellung für Mesa-Karten (z. B. 7i76e, 6i25, etc.), da sich bei größeren Stückzahlen häufig günstigere Konditionen ergeben – sowohl beim Preis pro Karte als auch beim Versand.
Rahmenbedingungen:
Ziel: mindestens 10 Karten
Bestellung erfolgt gesammelt direkt beim Hersteller
!!!Vorkasse notwendig, damit ich nicht auf den Kosten sitzen bleibe!!!
Ich übernehme die Organisation und den Versand innerhalb Deutschlands
Preise sind noch nicht final, je nach Anzahl & Modell
Wer Interesse hat, bitte folgende Infos per E-Mail an "This email address is being protected from spambots. You need JavaScript enabled to view it.":
Betreff: [Name, Vorname]   [Modell]  [Anzahl]
z.b.:      [Lauterbach, Elias] [7i76e] [3]
Als Text dann den Versandort (Packstation Möglich)
Alles weitere erfolgt dann per E-Mail :)
Wenn wir genug zusammenbekommen, gebe ich die finalen Preise bekannt und sammle dann das Geld ein, bevor bestellt wird.
Ziel ist eine faire, transparente und zügige Abwicklung.
Viele Grüße
Elias Lauterbach
  • besriworld
  • besriworld
22 May 2025 17:46
Thanks for the update. Then I will try without polar coordinates.I would be happy if you could share the configuration. Because I did not find an example of a spindle and C axis with +-10v control.
My lathe doesn't have an index yet and can't make threads. Because I want to install a hydraulic chuck first.
  • spumco
  • spumco
22 May 2025 16:50
It seems quite complicated. Has anyone done it with +-10v control? I want to try it on my lathe.
It's been a while since that post, and my lathe project has been stalled for a few months... but I had to give up on C-axis.comp.  I didn't get far enough to try the polar kinematics.
The insurmountable problem I encountered with caxis.comp was that it interfered with synchronized spindle moves (threading).  I wasn't able to figure out how/why it was causing problems, but once I abandoned it for a spindle/axis scheme proposed by @Aciera and @PCW, threading started working properly.
There is still an issue with threading in LCNC - thread start point varies with RPM - but that's not related to caxis.comp.
  • besriworld
  • besriworld
22 May 2025 16:37
  • ihavenofish
  • ihavenofish
22 May 2025 16:00
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
Ok, time to get back to this.
What am I doing again? :P
  • SanzuiWorks
  • SanzuiWorks's Avatar
22 May 2025 15:58 - 22 May 2025 16:06
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
I’ve managed to detect WCS (G54–G59) from a loaded .ngc file and output it to the terminal.
To be precise, it prints the WCS to the terminal log.
But I haven’t yet succeeded in sending it to MDI to change the GUI WCS.
Code implemented inside qt5_graphics.py > StatCanon:
def set_g5x_offset(self, index, x, y, z, a, b, c, u=None, v=None, w=None):
    g5x = {
        1: "G54", 2: "G55", 3: "G56", 4: "G57",
        5: "G58", 6: "G59", 7: "G59.1", 8: "G59.2", 9: "G59.3"
    print(f"[DEBUG] {g5x.get(index)} on line {self.lineno}")
    super().set_g5x_offset(index, x, y, z, a, b, c, u, v, w)
Sample G-code:
G21
G90
G55
G0 X10 Y10
M2
Terminal output:
[DEBUG] G54 on line 0
[DEBUG] G55 on line 3
[DEBUG] G54 on line 5
As you can see, G54 appears at both the top and bottom.
This needs further filtering to ensure only the first actual WCS used in the program is considered.
  • byunchov
  • byunchov's Avatar
22 May 2025 15:58
Interpolation accuracy with Delta ASD-B3 EtherCAT servo drives
Category: EtherCAT
Greetings fellow machinists!
Back in 2023, I did a reconstruction of my old CNC router for my woodshop. I have decided to use EherCAT hardware as my main communication interface tween LCNC and the main build components. A friend that makes CNC machinery advised me that I use Delta servo system, as it is the best option for my budget. I have decided to go for Delta ASD-B3 drives with 1kW motors. The setup in LCNC for the drives was rather easy. I had to use generic driver for lcec and couple it with dominik’s hal-cia402 component.
Everything seemed to work fine until last week when I have noticed that the circles turn out to be slightly oval. This is especially prominent on semi- and quarter-circles. I see this effect while doing interpolation in XY, XZ and YZ. The error seems to be of the same size and in the same position in the 3 planes.
I have also noticed that when I make a slot it is slightly wider than the tool diameter and slightly shorter than programmed. What is more the depth pattern is visible and alternating on the sides. This is depending on the cut direction. I usually use ramp plunging along the whole length of the slot and this effect is not visible then but when doing single line slot milling with small ramp plunge then the score lines are visible.I have tried few things like tuning the servo drives, changing LCNC configuration parameters like axis acceleration, speed; arc blending settings in [TRAJ] section but nothing seems to work. I have tried both slow and fast work feeds but the effect is prominent no matter the speed.
Something interesting I have found is that when squaring a piece of wood (hardwood like oak, beech or soft materials like pine, MDF, chipboard) one corner is seemingly sharp and the opposing corner is rounded and then this is mirrored diagonally. The radius seems to around 1mm. When squaring I have created a subroutine that uses arcs at corners so that the tool is not chipping the piece at the corners and sometimes to avoid burns.
Y- and Z-axis are ball screw with 5 and 10 mm pitch and are belt driven with 1:1 ratio. X-axis is helical rack and pinion with 1:10 gearbox. I have checked for mechanical issues and none is present or apparent. The gantry and the axes in general are square, as far as I can measure. X-axis is 4100 mm of travel but along that distance, I get like 0.02mm deviation from the zero point. Y-axis is around 1600 mm and Z-axis is around 560 mm. I have enabled E-Gear option in the servo drives as 10000 PPR.
I have attached pictures of the interpolation errors I get. I am open to discussion of what might be the cause of this - communication lag, drive parameters, LCNC config. I will also attach my INI and EC configuration files.
Displaying 15616 - 15630 out of 16341 results.
Time to create page: 0.470 seconds
