  • rodw
  • rodw's Avatar
13 Aug 2026 22:33
How do i know if my EtherCat Install is right
Category: EtherCAT
If ethercat reports your six slaves, its properly installed. The next step is to build a xml file which lcec_configgen does the heavy lifting for and then configure then move on to the ini and hal files.
  • Holzwurm56
  • Holzwurm56
13 Aug 2026 21:19
Replied by Holzwurm56 on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
Hallo PCW,
du hast geschrieben:
"If you have a 7I96, it can support up to 4 MPG encoders directly on the isolated inputs
with the right firmware ( 7i96_inmd.bin )"
Was ist der Unterschied zwischen 7i96_inmd.bit und 7i96_inmd.bin? Wichtig sind für mich 2 Achsenencoder
und ein Spindelencoder.
MfG
Hans
  • PCW
  • PCW's Avatar
13 Aug 2026 19:28
Replied by PCW on topic Frage zu 7I96?
Frage zu 7I96?
Category: Deutsch
You can simply update the firmware to what you need with mesaflash.
say:
mesaflash --device 7i96 --addr [card_ip_address] --write 7i96_inmd.bit --reload
Where 7i96_inmd.bit comes from 7i96.zip and [card_ip_address]  is either 192.168.1.121
or 10.10.10.10 depending on the 7I96 jumpering.
www.mesanet.com/software/parallel/7i96.zip
  • Holzwurm56
  • Holzwurm56
13 Aug 2026 19:06
Frage zu 7I96?
Category: Deutsch
Hallo PCW,
ich habe die 7I96 vor ein paar Jahren gekauft. Wie kann ich feststellen ob die Firmware 7I96_inmd.bin installiert ist? Oder
ob da eine ältere oder andere installiert ist?
  • PCW
  • PCW's Avatar
13 Aug 2026 18:25
PC817 is a strange chip that works in a strange way.
First of all, it is an analog circuit, not a digital one.
Secondly, the input is controlled by current, not voltage, and the output forces current, not voltage.
In addition, the frequency response strongly depends on the input current, a small current means a small propagation time, but also a small output current.
Not really strange at all, almost all transistor/Darlington output optocouplers function this way
and this type optocoupler is by far the most common.
Logic optocouplers also typically have current inputs (since the input  of most optocouplers   is simply a bare LED)
but differ in having a voltage output.
  • Aciera
  • Aciera's Avatar
13 Aug 2026 17:22
Replied by Aciera on topic DIY Robot Kinematic parameters,
As NWE has already commented, 'genserkins' assumes 6 axes (yours seems to be missing the forearm twist).
There is a kinematic in linuxcnc for a 'scorbot er3' which looks like it might be adaptable for your case:
github.com/LinuxCNC/linuxcnc/blob/master...atics/scorbot-kins.c
  • nhof
  • nhof
13 Aug 2026 16:49
Replied by nhof on topic Beckhoff EL2522 lcec xml file
Category: EtherCAT
Hello emresensoy, I recently wrote a driver for EL2522 which is available since linuxcnc-ethercat v1.41.2.
It supports Continuous Position (CSP-like) mode currently, as seen here: github.com/linuxcnc-ethercat/linuxcnc-et...ster/examples/el2522
I hope you will find this useful, please let me know if you try the driver and encounter any problem, as I may be able to assist. Thanks.
  • tuxcnc
  • tuxcnc
13 Aug 2026 16:39
I have never written anywhere that I forbid anyone to do anything.
I wrote that modifying Chinese electronics is a bad idea, which is true for several reasons.
Cheap PCBs do not tolerate re-soldering very well, the copper peels off from the substrate, even if something works well immediately after such an operation, there is no guarantee that it will work after a month or a year.
Is there any prohibition against writing about it?
The chip can work really fast (several dozen kilohertz), but then it may not drive the next stage with a small current.
However, when driven by high current, it may have problems already at a few kHz.
There must always be some compromise, assuming that the designer knew what he was doing and did not assume that if the PC817 withstands 50 mA, 20 will be fine...
  • hughcustoms
  • hughcustoms
13 Aug 2026 15:41
Category: EtherCAT
Hi All so i have a question
so how do i know if my Ethercat install is successful, I check the Master is active the Slaves are there
I now need to do the HAL files and config xml
i have this not sure if it is correct
i have 6 servo motors ,
  • NWE
  • NWE's Avatar
13 Aug 2026 15:21
Replied by NWE on topic DIY Robot Kinematic parameters,
Looking at the drawing, it seems to be missing 1 degree of freedom. Is this intentional? Or am I overlooking something?
  • 5280
  • 5280
13 Aug 2026 14:27
Replied by 5280 on topic Ver 10 NEW install
Ver 10 NEW install
No big deal as the guy that sold me my first computer said "a computer is pure MAGIC"
the laptop is a Dell Inspiron 5737, 43GTQzi, Bios A07 started out it's life with Windows 8 on it
I'll re type the command lines and again and see what comes up. but not right away
tks again for the help.! I keep trying
  • meister
  • meister
13 Aug 2026 14:10
Sorry for my poor English – enjoy it; it’s the first and probably the last video in which I’ll try to speak English.
www.youtube.com/shorts/u9xUOXN080M
Well, yes, blue is a 3.3V level, as I measured it directly at the FPGA pin
13 Aug 2026 13:20
Replied by tommylight on topic Conversational CAD CAM
Category: O Codes (subroutines) and NGCGUI
No promises.
13 Aug 2026 13:19
If I replace the DIR PC817 optocoupler with a high-speed 6N137, it can correctly return to the zero position.
This is wrong way.
By modifying the driver, you risk damaging it and reducing its reliability.
Although the PC817 has a very low bandwidth, the correct solution is to increase the dirhold.
Tux, you have a nasty way of replying, and you have been warned once about it.
It is their choice if they want to modify something or not, that is what DIY is about and helps with learning.
You are right about PC817, but you are wrong about dirhold as it does not magically raise the level to 5V on 3.3V systems.
I understand you are trying to help, so thank you, but the way you do it sometimes comes as very offensive and demeaning.
  • cmorley
  • cmorley
13 Aug 2026 13:04
Gui message while homing with shared home/limit swiches
Category: Qtvcp
It's more likely the bogus message comes from hal_glib library watching the limits switches without knowing about shared homing use.
Displaying 1576 - 1590 out of 12532 results.
Time to create page: 0.288 seconds
