  • cmorley
  • cmorley
26 Apr 2025 03:07
Replied by cmorley on topic qtdragon mod
qtdragon mod
Category: Qtvcp
Initialize a variable as 0 at startup.
Update that variable with the current encoder count after checking if it is higher or lower.
I think if you look at the master version 9f qtdragon you will see encoder input code with a similar idea. I am on the road so can't go in more detail right now.
  • pgf
  • pgf
26 Apr 2025 02:51
Replied by pgf on topic comparing to Grbl, or FluidNC
Category: Milling Machines
Well, they're "hobby only", but also "small workshop". I think those systems are used in an awful lot of places, because they're so much simpler to set up.
If I end up with a system that comes with grbl, I'll certainly be interested in trying it. Hope someone else can chime in as well.
paul
  • pgf
  • pgf
26 Apr 2025 02:48
manual tool change with tool length probe
Category: G&M Codes
Thanks! There's a fair amount there to absorb, but I think it will be worth it.
  • cmorley
  • cmorley
26 Apr 2025 02:43
Replied by cmorley on topic How to open QT ui file in LinuxCNC
Category: Qtvcp
I believe the grip only shows in z view. It should work without coding. Might have ro set grid bit it did work.
  • mikereid0817
  • mikereid0817
26 Apr 2025 02:26
unable to get gpio to work on Raspberry Pi 5 using latest image
Hi, I got my latest image working. In /boot/broadcom under config.txt, you need to comment out the line that enables SPI: dtparam=spi=on -> #dtparam=spi=on.
Then you can use GPIO7 and GPIO8.
You do not need to load hal_pi_gpio, it doesn't work on PI5.
The good news is that you don't need it, either.
  • Centurykid
  • Centurykid
26 Apr 2025 02:21
HSMworks Alternative? was created by Centurykid
Category: CAD CAM
I love HSMworks, its been the only CAM I’ve used for years in Solidworks but I no longer want to deal with Autodesk (plus HSMworks is done.)
Can someone please let me know of another similar CAM thats not Autodesk related and possibly integrates fully in Solidworks? I run 3axis mills making pretty basic one-off protos, Hurco & TRAK posts are needed as well.
Thanks for any tips!
  • JohnnyCNC
  • JohnnyCNC's Avatar
26 Apr 2025 01:01
Replied by JohnnyCNC on topic manual tool change with tool length probe
Category: G&M Codes
I had to save it as a PDF to be able to upload it.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
25 Apr 2025 23:47
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
Nice, i like the Voron 0 a lot.
I have 5 of Voron 2.4R2 that i built, some with modified Y and Z to use linear rods instead of rails.
If it works out, what are the chances of making the files available?
We already had and DIY ATC here but somehow it went quiet...
25 Apr 2025 23:42
Replied by tommylight on topic comparing to Grbl, or FluidNC
Not easy, but, GRBL and FluidNC are pretty much hobby only due to USB or WiFi comms mostly and the inherent latency and lack of "horse power" and lack of memory for complicated stuff, but they are pretty damn good for what they are and the fact they run even on a 8 bit micro controller.
LinuxCNC is a different beast altogether, the shear expandability and flexibility is definitely in the " life-changing epiphanies" level, and reliability combined with Mesa boards is way above most new industrial controls.
As a fresh example, today i went to visit a client of mine with 2 retrofitted industrial plasma cutters, he was just finishing the drawings and started the machine, literally as he pressed Run he turned and walked away from the machine and we went out for lunch. That is how comfortable he is with reliability of it all. He has over 10 years of experience with LinuxCNC machines, had one, now has two others, even his dad at over 70 years old uses those machines daily.
  • dbtayl
  • dbtayl
25 Apr 2025 23:27 - 25 Apr 2025 23:28
Replied by dbtayl on topic Fusion 360 Win 10 EOL
Category: CAD CAM
FWIW my work on the adaptive toolpaths got merged in FreeCAD- it's in the weekly builds. See: forum.freecad.org/viewtopic.php?t=96548
tl;dr is it adds a more-or-less one-click "rough the entire model" mode and- perhaps more relevantly- properly evaluates the stock and model instead of blindly projecting the contour you specify. Put differently, it's far smarter about not machining into the model, including avoiding areas it can't reach in 2.5D due to overhanging geometry. The attached image shows that on a demo model I threw together.
Not world-changing, but still a really nice QoL upgrade if you like adaptive toolpaths. Plenty of other... quirks... in FreeCAD remain, of course, but it's getting better all the time if you're not afraid of the weekly builds.
  • pgf
  • pgf
25 Apr 2025 23:24
Category: G&M Codes
Is there a write-up in addition to the ngc files?
  • gmouer
  • gmouer
25 Apr 2025 23:24 - 25 Apr 2025 23:42
Problem with Shuttle component , valid device faults with "not a known device"
I have a shuttle pro by Contour that I have used with linuxcnc for years under version 2.7 using the old HIDCOMP component which is now outdated and not included in the new distro.    The shuttle always worked perfectly.
Now, I have upgraded to 2.9.4 using the iso installer.     WIth only the single line "loadusr shuttle" it throws a error as "dev/hidraw0 is not a known device."          Looking at the docs it does not recognize a valid usb ID for my contour shuttlepro.     LSUSB lists the ID as "011" and that is not provided for in the shuttle component but is indeed valid for a shuttlepro.   The component only covers ID's of 0020, 0240 and 0030.
LSUSB displays Device 003   0b33 and ID 011 Contour shuttlepro
I did make the appropriate rule using the 011 ID but apparently the failure to recognize the id is withing the component coding.
Edit: I found the attached document that confrims that 011 is a valid usb id   (chart on pg2)
Hopefully someone will correct this in the shuttle.1 component.
Thanks,
George
  • pgf
  • pgf
25 Apr 2025 22:47
comparing to Grbl, or FluidNC was created by pgf
I'm interested in hearing opinions/thoughts from folks that have use both LinuxCNC, and one of the microcontroller firmware based systems, like Grbl, or FluidNC.  I have long (though perhaps not "deep") experience with LinuxCNC, and I've done some reading a couple of times about the "newcomer" systems, but I've never used one.
I assume that, given a g-code file, any of them will (basically) get the job done.   What I'm interested in hearing about is the things that surprised you, in switching from one to the other.  What was better?  harder?  easier?  worse?  What did you miss?  What made your milling life better?  I know, I know -- changing mill s/w probably doesn't involve life-changing epiphanies.  But I think you understand what I'm wondering about.
This question is triggered mostly by curiosity, and also because I've been window shopping for a new mill lately, and I'm wondering how much I should care about the controller and software that come with it.  It's likely that I'll replace whatever they provide, with my RPi and Mesa card,  but...  maybe not, or, maybe not right away.  I guess I'm wondering what the "dark side" is like.
paul
  • PCW
  • PCW's Avatar
25 Apr 2025 22:27
Replied by PCW on topic LinuxCNC S-Curve Accelerations
I can not test that as it requires EtherCat hardware.
  • IB_CnC
  • IB_CnC
25 Apr 2025 22:21
Category: QtPyVCP
Yes, I have a Voron v0.1 for small parts (120x120x120) and a Hevort for big parts (450x450x600 volume). Pretty sweet for sensor brackets and that kind of stuff. :-)
Displaying 16771 - 16785 out of 17082 results.
Time to create page: 0.548 seconds
