  • Jabbery
  • Jabbery
19 Apr 2025 00:45
Replied by Jabbery on topic Spindle will not stay running
Here are the files, axis are not tuned only tested for basic motion.
I added Ferrite cores to the UVW of the spindle, checked all wires are grounded properly. They are all foil wrapped with drain. All drains are grounded. I even moved the EMI filter and VFD to as far away as I could (6 feet) without having to completely rewire. Same issue if I turn off the VFD breaker the M3 command holds with no reset, with the breaker on it resets in a second or 2. I removed the xboxctrl.hal but included it here.
Thanks for all your assistance.
19 Apr 2025 00:41
Are the program's extents available to the g-code?
Secondary question: I don't have a Z+ limit switch. My mill is so slow I'd really have to not be paying attention for the carriage to get close to the stepper. A lower limit would be nice, but I really don't understand how that could work. My spindle is a router, so the bit length varies a lot. Is there any way to configure this to work? I see people say that they don't bother with a lower Z limit, and just rely on a soft limit there, but what would you set it to? Is there something about "real" spindles that I don't know? Are the bits always the same length?
No need for lower limit switch, LinuxCNC is very good at obeying soft limits, and you set it to the actual hardware limit, so if say Z is able to move 200mm it is set at -200mm in the ini file as the min_limit.
Upper limit switch is nice to have as it is also used as the home switch in LinuxCNC, so the top of the Z becomes 0 in G53 coordinates, then you put the tool in, jog till the tip of the tool touches the surface of the material and you do a touch off in G54, jog up a bit to avoid hitting something and press run.
All the usual CAM software outputs gcode where 0 it the top of the material and everything below it is negative values, hence the above -200 example.
As for tools, no they are not the same length, and above is how to deal with them.
The thing with hardware limits is, no matter what G54 is set to, LinuxCNC will not allow the machine to move beyond what limits are set in G53.
And then there is G55... :)
  • royka
  • royka
19 Apr 2025 00:18 - 19 Apr 2025 00:40
Replied by royka on topic ChatGPT LinuxCNC Assistent
Category: Configuration Tools
I didn't try it, but I have a good experience with Gemini 2.5 pro to configure (text based) a midi controller with custom firmware just by uploading the manual and explain what I wanted. You could try the same with LinuxCNC, upload the right PDF and tell that this is the manual and explain what you want. If it doesn't give a good result try without the manual but add the right prompts.
In the PDF you can see the result with adding the manual, I didn't look at it throughout but it seems already make more sense. (If you indeed will use remora)
  • PCW
  • PCW's Avatar
18 Apr 2025 23:51
Replied by PCW on topic Spindle will not stay running
Switching to machine-off indicates LinuxCNC sensed something
and changed operating mode.
The question is what did it sense.
Can you post you hal/ini files?
  • unknown
  • unknown
18 Apr 2025 23:38
Replied by unknown on topic ChatGPT LinuxCNC Assistent
Problem is here:
Note: Using POSIX realtime
./custom.hal:5: execv(stepgen): No such file or directory
./custom.hal:5: waitpid failed stepgen stepgen
./custom.hal:5: stepgen exited without becoming ready
  • unknown
  • unknown
18 Apr 2025 23:34
LinuxCNC and Linux and Ubuntu and PC and RPi ping issues with Mesa 7i96s
Category: Installing LinuxCNC
I ran my RPi 5 and 7i96s overnight and completed 40 million pings with zero errors.
sudo chrt 99 ping -i .001 10.10.10.10 -c 40000000
At the same time in the background, I ran Latency Histogram and two Glxgears. I have attached photos in case anybody is interested in seeing the results.
I’m not sure what to make of the maximum ping time of just over 10 ms.
It seems that "hardware-irq-coalesce-rx-usecs 0" has fixed the issues I was having (aside from the 10 ms issue) at least on RPi 5 * GB with LinuxCNC 2.9.2.
What is this "coalesce" thing?
Interrupt coalesce settings (access.redhat.com/documentation/en-us/re...ing_networking/index)
"By using interrupt coalescing, the system collects network packets and generates a single interrupt for multiple packets. This increases the amount of data sent to the kernel with one hardware interrupt, which reduces the interrupt load, and maximizes the throughput."
My /etc/network/interfaces looks like this:
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet static
address 10.10.10.11
There's no need to test with a base thread when using Mesa hardware.
Even with 4GB ram you wont come close to running out of memory when using the Linuxcnc image.
  • unknown
  • unknown
18 Apr 2025 23:33
auto lo
auto eth0
address 10.10.10.11
Why are you running a base thread for a latency test when using mesa hardware ?
  • terrymackintosh
  • terrymackintosh
18 Apr 2025 22:23
RPi 4B - LC2.8.4 vs LC2.9.2 - Queue MDI Commands, Run From Here
Category: Basic Configuration
I often run programs, but sometimes, like today, I am hacking at a rough bar that I cast in an open face sand mold. The exact size is not as important as it is that the surfaces clean up. Then once all sides are cleaned up, then, and only then, I concern myself with size. One side might be much more pitted or something then the other side, so I can not say that I want to take 2mm off of all sides. Maybe one side is pretty good, so 0.5mm cleans it up, but the other side has a pit and takes all that can be spared to clean it up. I judge this on the fly. And while I could write a tiny program to take one pass, then stop, it is also very easy, or used to be, to use MDI, typically G1 in X, G0 in Y followed by X, by Y, back at start, asses, maybe drop Z by some amount, repeat. This cuts the part in only one direction, as that cuts a better finish, moves out around the bar and returns to the start. Z moves are what ever amount looks correct for that pass, no set amount. So a sort of hybrid of CNC and manual machining. With a queue I can stack the four moves, often add an M5 on the end, go do something else and when I hear the spindle stop I know I need to go look at it and decide what next. Once the bars are all trimmed to overall size, then I have a program to make something out of them.
  • Jabbery
  • Jabbery
18 Apr 2025 22:05 - 18 Apr 2025 22:06
Had an idea, dangerous I know!
I put a buck converter on the 24VDC supply to get me 10VDC for a ref voltage for the spindle output. Tested with the buck converter and of course had the same problem but it allowed for another test. Note the spindle out was at 5V then 0V when the spindle stopped.
I powered off the breaker for the VFD and put my meter on the Spindle Out/Gnd. The M3 S9000 (5V) held with no reset. I tried a few different speeds and all worked. It is some type of EMI problem.
Any suggestions on how to resolve this? I have a EMI filter on the VFD. I tried moving the VFD further away from the 7i96s and no effect.
  • JohnnyCNC
  • JohnnyCNC's Avatar
18 Apr 2025 21:45
Replied by JohnnyCNC on topic spindle with encoder
The index signal sent to the encoder input to LCNC must be 1:1 with the spindle. My encoder is on my motor. But, I get the index signal from the sensor on my spindle. If the gearing of the motor to the spindle was exactly 1:1 you could attached the encoder to either the motor or spindle. But if the gearing is anything other than 1:1 you must get the index signal from the spindle. My gearing is 1:1.8 and the A/B encoder signals come from the motor side, but my Z (index) signal comes from the spindle side.
  • Jabbery
  • Jabbery
18 Apr 2025 21:32
It had no effect removing the xbox.hal and disconnecting the controller.
Something I noticed this time is I changed to qtdragon (from qtdragon_hd) so I could see the terminal window behind. In that change I noticed the "At Speed" indicator beside the spindle controls turns green when I enter the M3 S9000 and when the motor stops the indicator flashes.
The other not so obvious item is the machine 95% of the time switches to "Machine Off" but not 100% of the time.
I also noticed the secure boot was enabled, I thought I had disabled that. It is now disabled in bios.
  • israfilcaglar
  • israfilcaglar
18 Apr 2025 21:19
Replied by israfilcaglar on topic How to homing the A-axis again with gcode?
Category: AXIS
thank you for your help. I want to ask you a question. I have a mesa 7i96s card. stepgen.00 X axis, stepgen.01 Y axis, stepgen.02 Z axis, stepgen.03 spindle pwm speed control, stepgen.04 a axis. I use spindle speed mode. I turn the spindle with m3 command, then I stop the spindle with m5 command. I want the spindle tip to always stay at the same angle when I give the m5 command. How can I do this?
  • PCW
  • PCW's Avatar
18 Apr 2025 21:15
Nothing too obvious
I would try running without the XBOX controller
USB devices are notoriously sensitive to noise.
  • RNZ
  • RNZ
18 Apr 2025 21:11
I bought the version with the most memory. I figured that it was safer to spend a little extra and never run out of memory (which could be fatal).
  • vre
  • vre
18 Apr 2025 21:02
Replied by vre on topic spindle with encoder
What this means?
That for rigid tapping encoder must be on spindle shaft
or must be on 1:1 ratio with spindle shaft?
Other ratio configurations can't work for rigid tapping ?
Displaying 17041 - 17055 out of 17155 results.
Time to create page: 1.303 seconds
