  • BX-CNC
  • BX-CNC
21 Mar 2025 22:52
  • BX-CNC
  • BX-CNC
21 Mar 2025 22:50
Replied by BX-CNC on topic Need help with CNC machine build up
00:00.0 Host bridge: Intel Corporation Core Processor DMI (rev 11)
Subsystem: Dell Core Processor DMI
Flags: fast devsel
Capabilities: <access denied>
00:03.0 PCI bridge: Intel Corporation Core Processor PCI Express Root Port 1 (rev 11) (prog-if 00 [Normal decode])
Subsystem: Dell Core Processor PCI Express Root Port 1
Flags: bus master, fast devsel, latency 0, IRQ 29
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: f8000000-fbcfffff [size=61M] [32-bit]
Prefetchable memory behind bridge: c0000000-dfffffff [size=512M] [32-bit]
Kernel driver in use: pcieport
00:08.0 System peripheral: Intel Corporation Core Processor System Management Registers (rev 11)
Subsystem: Device 0028:0027
Flags: fast devsel
00:08.1 System peripheral: Intel Corporation Core Processor Semaphore and Scratchpad Registers (rev 11)
Flags: fast devsel
00:08.2 System peripheral: Intel Corporation Core Processor System Control and Status Registers (rev 11)
Flags: fast devsel
00:08.3 System peripheral: Intel Corporation Core Processor Miscellaneous Registers (rev 11)
Flags: fast devsel
00:10.0 System peripheral: Intel Corporation Core Processor QPI Link (rev 11)
Flags: fast devsel
00:10.1 System peripheral: Intel Corporation Core Processor QPI Routing and Protocol Registers (rev 11)
Flags: fast devsel
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
Subsystem: Dell 5 Series/3400 Series Chipset HECI Controller
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at f7fffc00 (64-bit, non-prefetchable)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06) (prog-if 20 [EHCI])
Subsystem: Dell 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at f7c00000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
Subsystem: Dell 5 Series/3400 Series Chipset High Definition Audio
Flags: bus master, fast devsel, latency 0, IRQ 33
Memory at f7ff8000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06) (prog-if 00 [Normal decode])
Subsystem: Dell 5 Series/3400 Series Chipset PCI Express Root Port 1
Flags: bus master, fast devsel, latency 0, IRQ 17
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 1000-1fff [size=4K] [16-bit]
Memory behind bridge: fbd00000-fbdfffff [size=1M] [32-bit]
Prefetchable memory behind bridge: be000000-be1fffff [size=2M] [32-bit]
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7a00000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a6) (prog-if 01 [Subtractive decode])
Subsystem: Dell 82801 PCI Bridge
Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: fbe00000-fbffffff [size=2M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
00:1f.0 ISA bridge: Intel Corporation H57 Chipset LPC Interface Controller (rev 06)
Subsystem: Dell H57 Chipset LPC Interface Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06) (prog-if 01 [AHCI 1.0])
Subsystem: Dell 5 Series/3400 Series Chipset 6 port SATA AHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 30
I/O ports at cc00
I/O ports at c880
I/O ports at c800
I/O ports at c480
I/O ports at c400
Memory at f7800000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
Subsystem: Dell 5 Series/3400 Series Chipset SMBus Controller
Flags: medium devsel, IRQ 18
Memory at f7fff800 (64-bit, non-prefetchable)
I/O ports at 0400
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation G96CGL [Quadro FX 580] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation G96CGL [Quadro FX 580]
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=512M]
Memory at f8000000 (64-bit, non-prefetchable) [size=32M]
I/O ports at dc00
Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: nouveau
Kernel modules: nouveau
02:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetLink BCM57780 Gigabit Ethernet PCIe (rev 01)
Subsystem: Dell NetLink BCM57780 Gigabit Ethernet PCIe
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at fbdf0000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: tg3
Kernel modules: tg3
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
Flags: bus master, medium devsel, latency 64, IRQ 16
I/O ports at e800
Memory at fbe00000 (32-bit, non-prefetchable)
Kernel driver in use: 8139too
Kernel modules: 8139cp, 8139too
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers (rev 04)
Subsystem: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 04)
Subsystem: Intel Corporation Core Processor QuickPath Architecture System Address Decoder
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 04)
Subsystem: Intel Corporation Core Processor QPI Link 0
Kernel driver in use: i7core_edac
Kernel modules: i7core_edac
ff:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 04)
Subsystem: Intel Corporation Core Processor QPI Physical 0
ff:03.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller
ff:03.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder
ff:03.4 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Test Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Test Registers
ff:04.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers
ff:04.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers
ff:04.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers
ff:04.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers
ff:05.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers
ff:05.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers
ff:05.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers
ff:05.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers
This is result after enter the first line
  • ContinenteCNC
  • ContinenteCNC's Avatar
21 Mar 2025 22:50 - 21 Mar 2025 22:55
Replied by ContinenteCNC on topic Need help with CNC machine build up
Is this your driver?
  • BX-CNC
  • BX-CNC
21 Mar 2025 22:47
This is the only enable I found
  • ContinenteCNC
21 Mar 2025 22:46
lspci -v
sudo cat /proc/ioports | grep parport
ls /dev/parport*
these commands
Go to "Applications" (upper left corner), then "Terminal Emulator"
Copy the first line, paste in terminal, press enter. Then copy the result or take a picture.
Do it for the remaning commands. One by one.
  • ContinenteCNC
21 Mar 2025 22:43
So should I unused all the other pins?
If you are testing only one motor, no need to use others.
I believe you have to change P1 to Enable, instead of E-stop.
  • BX-CNC
  • BX-CNC
21 Mar 2025 22:38
lspci -v
ls /dev/parport*
these commands
  • ContinenteCNC
21 Mar 2025 22:38
i dont really know
What you don't really know?
  • BX-CNC
  • BX-CNC
21 Mar 2025 22:35
  • ContinenteCNC
21 Mar 2025 22:32
Replied by ContinenteCNC on topic CNCmakers 4 Position Lathe Electric Turret
Sorry, I forgot to return with the result. I'm only four years late.
Anyway, it worked just fine.
  • BX-CNC
  • BX-CNC
21 Mar 2025 22:31
YES! They are free to move when I power off and it locks when I power the board on.
  • BX-CNC
  • BX-CNC
21 Mar 2025 22:28
  • BX-CNC
  • BX-CNC
21 Mar 2025 22:28
Sorry but it doesn’t allow me to upload the original quality photo.
  • ContinenteCNC
21 Mar 2025 22:26 - 21 Mar 2025 22:29
It seems you are using Z pins. So it should be P6 for step and P7 for direction and P1 for enable.
Is the motor shaft locked when you power everything up or can it spin freely if you turn it by hand?
If they are free to move, try reverting enable pin.
  • ContinenteCNC
21 Mar 2025 22:24
What these comands show?
lspci -v
ls /dev/parport*
Displaying 17221 - 17235 out of 18505 results.
Time to create page: 0.425 seconds
