  • rodw
  • rodw's Avatar
16 Jan 2025 04:41
Replied by rodw on topic First Start Up - E Stops
Progress!
I always comment out the line causing the error(s) so Linuxcnc opens, then review things in halshow and your hal file to get the right pin name etc but by the looks of this, its telling you the line number and the fault so maybe change the signal name to something like aa-pos_fb then review
  • notJamesLee
  • notJamesLee
16 Jan 2025 04:06
Replied by notJamesLee on topic First Start Up - E Stops
okay so i went to that linked tutorial I commented out the existing estop loop and ended up actually testing code from the last entry on the first page (copied and pasted below) but modified with my pin for the estop.
Code i am using:
loadrt estop_latch addf estop-latch.0 servo-thread net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset net remote-estop estop-latch.0.fault-in <= hm2_[HOSTMOT2](7i96s).0.gpio.040.in_not
Now i am getting a similar error where it it thinks pins are double assigned. Should I have commented out other pin assignments? Or could i not be assinging the pin corectly?
error message:
.hal:258: Signal 'a-pos-fb' can not add OUT pin 'hm2_7i96s.0.encoder.00.position'. It already has OUT pin ' hm2_7i96s.0.stepgen.03.position-fb' 2034
  • nawaf
  • nawaf
16 Jan 2025 03:51 - 16 Jan 2025 09:34
Replied by nawaf on topic Axis Modifications
Axis Modifications
Category: AXIS
Thank you, Pill, this works great for me
Warning: Spoiler!
  • nawaf
  • nawaf
16 Jan 2025 03:47
Axis Modifications
Category: AXIS
nawaf are you using regularmac800?
Yeah, thanks, cakeslob, for the GUI mod.
I am using a 10-inch touchscreen with a resolution of 1024x600 and I want to use the Axis GUI with buttons that are large enough, and I saw your mod and tried it. It's great because the buttons are big enough.
But for the open file dialog, the buttons are not big enough for my fingers, making it a bit difficult to touch them on my screen
  • rodw
  • rodw's Avatar
16 Jan 2025 03:39
QtPlasmaC v2.9 - Time between turning off and back on the arc on a Powermax 105
Category: Plasma & Laser
Are you using Mode 1 and the ArcOK signal from the CNC port on the plasma cutter? If not do so. This will  let the plasma is tell you the Arc is OK, not some half assed guess based on the arc voltage.
Also on some plasmas, there is a setting that tells the plasma is turned on and off by seperate button presses. make sure its not set like this although if you using a machine torch, this should be overridden.
  • Diel
  • Diel
16 Jan 2025 03:24
Hi everyone. I hope you all are doing great.
I am trying  QtPlasmaC v2.9 for the first time. I have done some retrofitings of milling machines and routers with the Linux CNC, but never had worked with a plasma before.
I am finding out that the Plasma machines have some specific issues to deal with.
I am using a Hypertherm PowerMax 105 plasma source.
Everytime the plasma is turned off, the powermax start a process that Hypertherm calls overflux, blowing air trough the torch to cool it down.
During this overflux phase (aprox. 15seconds) the start torch does not work (on the powermax). It seems that the first pulse reduce the air blow and the second would start the torch.
I am having a problem because during a program executin, this first start to the powermax during the overflux does not start the torch, but the powermax send the signal of arc ok to the QtPlasma.
As Powermax sends the arc ok signal to QtPlasma, it does keep running the program, as it understand the arc is ok. But the arc is not ok and it is not cutting.
Does someone knows how to solve this situation?
Thank you very much
16 Jan 2025 02:41
Replied by Cant do this anymore bye all on topic Raspberry Pi OS PREEMPT RT 6.13 Kernel Cookbook
Category: Installing LinuxCNC
Kernel as built following instructions
  • arauchfuss
  • arauchfuss
16 Jan 2025 02:23 - 16 Jan 2025 02:26
Replied by arauchfuss on topic Tree Journeyman 325 (Dynapath)
Category: Milling Machines
This reminds me I need to mount the XY limit switches. Some tech at the company that donated the mills physically removed them. Kind of understandable since you could not jog the machine off the limits as they outright interrupt the drive enable circuit.
  • vre
  • vre
16 Jan 2025 02:23 - 16 Jan 2025 02:24
Replied by vre on topic Mesa modbus and pktUart
Category: Other User Interfaces
modname.update-hz is 0 by default i have not changed so this not the reason for error
  • arauchfuss
  • arauchfuss
16 Jan 2025 02:17
It's also important to have the drive enables working so a following
error will disable the drives.
I have two relay outputs I need to get wired up. The default wiring does not give direct control of the drive enable relay which in turn energizes the main contactor. There is a reset relay that latches the enable relay and an error/e-stop relay that interrupts the enable relay.
I will pull the belts off all three servos. Need to figure out the ratio in any case.
16 Jan 2025 01:46
Replied by Cant do this anymore bye all on topic Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
All my Pi's are 4GB.
Along with my Rpi5 I also have a RPi400, basically the same as a RPi4 with an slightly upped clock speed. I can say I've never come across this issue (even when rod was polishing his iamge utility).
I don't know if this will actually help, but you could try comparing the config.txt files on the Linuxcnc image & the Rasp OS image and see if there is anything that sticks out. This is just a guess.
It might pay to monitor the 3v3 line when booting, both versions, and see if there is anything untoward. Again just another guess.
But yeah it does seem like a confusing issue.
16 Jan 2025 01:36
First of all your opening post was great. I'm actaully giving it a go now, just wish I had a nvme drive hooked up to the PCIe bus.
There's a couple of points regarding Linux kernels.
Sometimes the latest kernel may not be the optimum for your hardware.
The kernel you are using is a "release candidate" whilst usable for all intents is still going through some work.
The 6.1.y branch works fine on the RPi4, I think the kernel in the Linuxcnc image maybe 6.1.54
The RPi platforms with regards to Linuxcnc are a little different to the x86 platforms. Your Rpi4 & Rpi5 hardware is what it is. Whereas you may need a specific kernel dpending which x86 motherboard you buy.
The Rpi branch that appears to be active is the 6.6.y branch, so one could assume this is the branch that is receiving the most "bug fixies".
Simple things like isolating cores 2,3 will see latency drop. There doesn't seem to be as many options/tricks for latency on the RPi platforms as the x86 platforms.
I would chose to use a kernel that is a couple of version behind the the latest and greatest if it more tried in the real world and has better latency.
In my discussions with royka we talked about the fact that a kernel that is a little older is sometimes the better option.
Due to the issues with wayland I would recommend the use of the image form the Download page, Xorg is used. Plus it's easier to deploy ;)
Mind tho I'm not saying this is the only way to do it.
What I would suggest is trying some of the earlier kernels to see how performance differs.
One thing regarding the 6.6.y branch.
The latest version is 6.6.70 which I couldn't find any real time patches for.
The previous commit is 6.6.65 for which there are rt patches, but for some reason the overlay's aren't in the source. Which is a pain when building an image using Rod's image builder.
It seems, ATM, the deeper you dive it can seem a little confusing.
Sorry for the multiple posts but this editor is PITA.
  • rodw
  • rodw's Avatar
16 Jan 2025 01:19
In a Debian environment tasksel allows you to install a number of desktops. There is a (X) reason why we use XFCE in the linuxcnc images. It uses X windows not wayland
  • Rabin
  • Rabin
16 Jan 2025 01:08
Replied by Rabin on topic home axis problem
home axis problem
Category: AXIS
Thank you very much for your help.
I have set the parameter of HOME_USE_INDEX = NO to "No” before, but if I am not careful or accidental, clicking on [home axis] will still set my G53 coordinate to 0. This will lead to the possibility of subsequent collisions.
I hope CNC will do nothing when I accidentally click on [home axis]
Displaying 19756 - 19770 out of 21715 results.
Time to create page: 0.416 seconds
