  • rodw
  • rodw's Avatar
10 Jan 2025 22:36
Replied by rodw on topic 7i96s Arc Voltage + Encoder Fault
Category: Plasma & Laser
When I turn on QTPlasmaC the value of Arc Voltage is 145.
The encoder velocity pin seems to be working fine on halshow.
Sounds like you have not correctly calibrated qtplasmac for your THCAD settings
The THCAD 0 volt frequency should be what you observe on the encoder velocity pin give or take some bouncing around.
This offset needs to be entered in qtplasmac.
If you read the QTplasmac docs, there is a link to a calculator to determine your settings.
  • slowpoke
  • slowpoke
10 Jan 2025 22:27
Replied by slowpoke on topic 7i96s Questions
7i96s Questions
Category: Driver Boards
The first P1 encoder is  encoder 1 so the position would be:
hm2_7i96s.0.encoder.01.position
and the most important parameter for that encoder would be:
hm2_7i96s.0.encoder.01.scale
After your warning (thanks) I was going to solder up a little proto-board with some protection diodes for the negative rail. Then decided to just do a quick and dirty actual PCB. I will obviously be careful when connecting, and to your point chassis ground is not zero volts. I inserted a 100r series resistor and TVS, please see attached and let me know if you think this is adequate?
I'm ready to press the send button for a free PCB, but I can tweak if you have any suggestions.
Re: hm2_7i96s.0.encoder.01.scale, can I assume that's a float value? Is there documentation available for the finer details of the 7i96s_p1encd.bin?
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • rodw
  • rodw's Avatar
10 Jan 2025 22:23
Replied by rodw on topic Mach3 machine, some questions.
Category: CNC Machines
You say LinuxCNC is way way better than Mach 3.
How so?
A work in progress by a user in NZ but try commanding a pallet changer on a horizontal 5 axis machines like this in Mach3.
This machine fills a shed.
Many people use Linuxcnc to retrofit big commercial machines because of its flexibility and extensibility.
Here the user had hit the limits of using classic ladder and wrote a custom Linuxcnc C component to do this. A week earlier, he knew nothing about programming and is now loving it!
  • rodw
  • rodw's Avatar
10 Jan 2025 22:09
Solved - LinuxCNC does not work with new Delta ASDA-A2 drive
cool.
downside to the ethercat is its ONLY ethercat. i wish it has pulse as well. would be more versatile.
It does if you use an Ethercat stepper driver. There are many. I use rtelligent ECT86
10 Jan 2025 22:08
Asservissement de la vitesse de broche avec une carte MESA 7i96s
From google translate
Is it possible to configure a speed-controlled spindle with a Mesa 7i96s board using the spindle encoder as speed feedback?
does not make much sense....so
VFD or Servo?
With VFD, yes, 7i96S can be used as it has the 0-10V control and has encoder inputs.
  • scotta
  • scotta's Avatar
10 Jan 2025 22:05
Hi, the outputs on the NVEM are not an output voltage like your thinking. They are as shown in the diagram attached. Basically a switch sinking to ground.
10 Jan 2025 21:47
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
These are Linux kernel patches, so I guess where the kernel devs hangout.
  • Damon2
  • Damon2's Avatar
10 Jan 2025 21:39
Bonjour,
Il est bien possible de configurer une broche asservie en vitesse avec une carte Mesa 7i96s en utilisant le codeur de broche comme retour de vitesse?
Merci
  • Lezard
  • Lezard
10 Jan 2025 20:20
That's right. Now I remember that this is what pushed me to choose the M version. It seemed to me at the time that the pulse/dir was the simplest method, so it was less risky for me (this machine was my first build), and I paid some extra to get another option for the future. Turns out that CanOpen does not seem to be a viable option with LinuxCNC, but well...
If EtherCAT works well, wouldn't it make the pulse option look rather outdated ?
(Still need to do a lot of reading before I can consider an upgrade to EtherCat)
  • haham
  • haham
10 Jan 2025 20:17 - 11 Jan 2025 10:47
SOLVED: CSS G96 with CCW spindle M4 on lathe
Category: G&M Codes
Good evening,
G96 constant surface speed on my lathe works fine with CW spindle movement. Now I want to use an upside down parting tool with CCW spindle rotation.
G54
G40
G97 S50 ; start with low rpm
M4 ; switch spindle on CCW
G0X10 ; start diameter
G96 D3000 S12 ; CSS max 3000 rpm, 12 m/min
G96 F0.02 ; 0,02 mm feed per rotation for parting
G1 X0 ; start parting
But the x-axis does not move. It works with M3 instead M4. Gmoccapy shows correct -350 rpm (minus!) during M4. I assume, that feed does not start because it waits for positive spindle speed.
Do I realy have to use a separate HAL file with negated spindle feedback?
Best regards,
Hartmut
  • machinedude
  • machinedude's Avatar
10 Jan 2025 19:56 - 10 Jan 2025 19:58
Replied by machinedude on topic Black Friday Deal got me :)
That manual self-centering 4 jaw chuck came yesterday, and that brand seems pretty well made and works really well.
i have some material ordered and coming for a attempt at a rotary union, the seals should be here today, i hope this material is not under sized or i will have issues. for whatever reason thick-walled tube in this size range is expensive and i only had one supplier that i have used that was fair on price, but sizes were limited. i checked on bar stock prices and that was even more expensive yet :) it's amazing how you get screwed so bad on prices for small orders.
these unions are hard to make on the cheap. i did see one import that had 120 mm bore but was around $400 each. what i am trying is 140 mm bore. not big enough for a 4" square tube so it is what it is i guess. if i can make these i can make 2 of them for around half the price of one of the smaller imports.
i hope i can make it work :) would be a neat build and if nothing else i am eager to try it at least. nothing ventured nothing gained :)
  • timo
  • timo
10 Jan 2025 19:52 - 10 Jan 2025 19:55
Replied by timo on topic Mach3 machine, some questions.
How so?
As far as I could research, Mach3 is not able to do fully closed loop operation with feedback between motor axis and rotary or linear encoders.
  • feed rate based on spindle power (cutter breakage detection)
  • EDM with reverse movements or slow down based on electrical values
  • a hobbing machine that slows down workpiece spindle and tool spindle in case something reaches the limits.
  • Turning excenters or augers on a lathe
  • cam shaft grinding
    These are examples I can think of. Things that Mach3 could not provide, according to my understanding of the available information.
    Of course those items go bejond the average DIY user and will not be easy to do. Not easy to do in any system, unless available as turnkey in exchange for $$$
    Linux CNC seems to be in the gap between, "very basic good enough" and "just pay money to one of the usual suspects"
    I see a lot of misconception that Linux CNC ist "Parallelport technology" for 3-axis open loop stepper machines. Which is actually only the lower end of the spectrum.
  • ihavenofish
  • ihavenofish
10 Jan 2025 19:46
cool.
  • timo
  • timo
10 Jan 2025 19:13 - 10 Jan 2025 19:25
The spindle driver is some weird (undocumented) BLDC unit with a motor using hall sensor feedback.
This benchtop mill has the tool spinde parallel to the motor and a short 1:1 toothed belt transmission. Amplifier works I can spin it up connecting 5V to signal wires.
How to connect wires, power supply and HAL components is another story.
Probably similar to a frequency inverter.
I am using the old transformer, which includes a AC to DC rectifier board.
  • Lezard
  • Lezard
10 Jan 2025 19:06 - 12 Jan 2025 12:21
Hello,
Got the drive working again today, the parameters for Control Mode and Pulse Type were indeed wrong (so you were both right :-)
Turns out that my backup parameters file was not good at all, I ended up just copying the working parameters from one of the X drives to the new Y drive. Both axis have the same mechanical setup, gear reduction ratio etc...
@ihavenofish : you are right, these drives have CAN bus capability. I made this choice at the time as I was not quite clear about the various options. Now, I wish I had chosen the E version that offers EtherCat...
I'm thinking about upgrading the whole setup to EtherCat, possibly running LinuxCNC from a RaspBerry. Pi. That would allow me to get rid of the PC/Parallel Port limitations, move all the hardware inside the control cabinet, and have more I/O to finally add some extras to the machine.
Thank you all for your help, great to see this community thriving !
Displaying 20146 - 20160 out of 21716 results.
Time to create page: 0.430 seconds
