  • timo
  • timo
30 Jul 2026 15:05 - 30 Jul 2026 15:18
Replied by timo on topic DIY CNC
DIY CNC
Category: Milling Machines
Exactly! The PC (raspberry Pi or similar), power supplies and stepper (or servo drivers) can be basically the same. What I think is that the mesa card is not worth it, when you stay with open loop stepper motors and the mechanical system is not made for high speeds. But once you start using the I/O and Encoder inputs it is a real help to have a system that is easy to use, supported and works (happy customer of Mesa Plug n go kit).
For the picoCNC I paid roughly (guessing) 130-140€. Some things come with minimum quantities, others are discounted. It ends up at approx. 30€ a piece +-. I would have just bought the successor of it for 50$, but shipping would have doubled the price. To me it was more about the assembly challenge than the actual need for it. But there are "ready to go" options.
One aspect is that a 10 mm carbide endmill will cost roughly the same.
So for metal working the tooling and material quickly gets in regions where a Mesa card is really my least problem :-) and I bought a 2nd Mesa card after the first one.
#no advertisement just random pictures.
  • djdelorie
  • djdelorie
30 Jul 2026 14:29
Replied by djdelorie on topic DIY CNC
DIY CNC
The OP implied he already had a PC to use, which you'd need for GRBL anyway (unless you added an LCD, buttons, and an sdcard), so adding a parallel breakout board is about $10, compared to the $4 for the pico and whatever the picocnc costs (assuming you can buy it, I couldn't find one for sale, but web site says "retired", but historically $29 assembled). You need the same stepper drivers either way.
A Mesa board is way more expensive, yes, but you get a lot more for your money.
  • meister
  • meister
30 Jul 2026 14:01
there is an example:
./bin/rio-flow riocore/configs/TangNano9K/config.json
  • viewsat
  • viewsat
30 Jul 2026 13:16
I'm using a Tang Nano 9k FPGA. How do I configure it to output a PWM signal to the spindle?
  • timo
  • timo
30 Jul 2026 12:26 - 30 Jul 2026 12:29
DIY CNC
I am not sure if Linux CNC is really cheaper than GRBL.
www.grbl.org/single-post/a-peek-at-the-picocnc This is an example based on the Raspberry Pi Pico, all documented and possible to recreate "in the flesh". I bought the Pico boards for like 3€ a piece. The base board was more expensive, but not too crazy.
  • slow simple 3 axis machine without linear scales or rotary encoders probably works just fine with the GRBL
    • When I think of adding things "slaved axis", "linear scales", "automatic tool changer" I would go for LinuxCNC
  • alex_sar
  • alex_sar
30 Jul 2026 09:43
Gremlin rewrite for OpenGL ES and possible optimization
Hi all! Long time no speak.   Finally, I was able to finish this transition. There is the PR: github.com/LinuxCNC/linuxcnc/pull/4293 Any feedback is welcome!
  • rodw
  • rodw's Avatar
30 Jul 2026 04:55
Looking for STLs for 3 axis vismach model
I don't know if anybody can help but working with Brad Collette a Freecad Developer who has a PR pending for MTconnect. His PR includes a machine simulation which looks much nicer if the machine visulisation is based on a real machine. The model he has is not open source.
I was hoping somebody would be willing to share their model (only looking for basic 3 axis machine)
You can learn more about his MTconnect project here where I interviewed him about it.
youtube.com/live/b_S-p2nylr8
Thanks guys, Please let me know here if  you can help and are willing to contribute a model that will end up being part of LinuxCNC core code.
  • rodw
  • rodw's Avatar
30 Jul 2026 04:42
Replied by rodw on topic DIY CNC 2
DIY CNC 2
Not sponsered at all, just Meanwell make well priced power supplies that are available globally.
  • rodw
  • rodw's Avatar
30 Jul 2026 04:39
Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
MAke sure you have the Realtek R8168-dkms or R8125-dkms driver installed for your realtek card. It may fix it.
30 Jul 2026 04:05
Replied by tommylight on topic DIY CNC 2
DIY CNC 2
Those should be fine at 48V, i know mine were fine when testing them, but being used at 36V.
The thing is, the cheap drives i mentioned some posts back have 9-42V written on them, but powering them with 36V will cause them to fail, fairly quickly, as the 42V written on them is the "absolute maximum rating" or the point where they die. Typical or preferred working power supply is written as 24V on the chip datasheet. I have them running at 27V for several years.
Yours are a different type, with output mosfets that are usually rated for 100V absolute maximum.
Sorry for this topic becoming to convoluted, so try not to overthink stuff, get some parts, wire, test, make chips, after a while you get a very good idea of what is perfectly fine and what you could do with upgrading.
  • Logthor
  • Logthor
30 Jul 2026 04:03
Replied by Logthor on topic DIY CNC 2
DIY CNC 2
The supply seems to have protections in place already for this so I'm probably not going to bother but thanks for the heads up
  • NWE
  • NWE's Avatar
30 Jul 2026 04:00
Replied by NWE on topic DIY CNC 2
DIY CNC 2
I would expect that adjustable PSU to work just fine for this application. Like I said, I would not bother adding a capacitor. But if you do, don't use the 35V capacitors I suggested earlier, for use on a 48V PSU.
30 Jul 2026 03:55
Replied by tommylight on topic Chinise mesa clone vs Original vs Ethercat
Try to find an Intel network card, look for used 100Mbps ones, all new 1Gbps ones seen to be RealTek.
If the PC has a PCI slot, even real old 10Mbps Intel ones should work.
  • Logthor
  • Logthor
30 Jul 2026 03:48
DIY CNC 2
I think I have a pretty good idea of what I need, but I might switch the LRS to a 48V 10A supply just so that I have room to grow in the future if I want to.
Yes, this is a fact, and the drives you chose should be fine on 48V.
The drives have a 50V max but if you don't think it'll cause an issue I'll go for it and see.
  • leexi
  • leexi
30 Jul 2026 03:46 - 02 Aug 2026 07:41
Dear Colleges I what to share my experience on this topic.
I after several years looking for this card, I get a mesa card,
looks a Clone one, V2. (kind of clone of 7i92) Pls. have a look on picture attached, I get his one because was easy way to get it, at the beginning  I try to purchase the original one but was not available to be send to my county and after, after they were lack on cards, and after they start to shipping to my country but  the shipping cost became  more difficult to get  that original  card, and after I was looking on amazon o other retail pages and then I found this one on aliexpress. I was thinking it was the original but after some research I understood that it  was a clone one of original one. but cheap and easy to get (shipping cost included) and for test propose I run the risk to get it
well now I use it with my PC box and I do not load any other bin file. ( I see on forum load a bin file is not a good Idea).
Supplier support = after the time they send me the card information
Process to make it talk and work with linuxcnc (debian 12).
1.       Configure the ip on my dual Ethernet port pc box , card ip 10.10.10.10 my pc 10.10.10.11 port 2 and ethercat on port 1.
2.       Install the mesa card utilities
3.       Install the ethernet utilities
4.        I discover the card io setup by maker
5.        I use linuxcnc wizard (PnCConf) with discover option
6.       end configuration and start running the Linuxcnc
7.        communication with card disconnect issues , solved by disabling the power save option on the realteck Ethernet com card and after not more issue by the moment
8.       If I do not have any other problem I will replace my old and good  PCIe parallel port card that make  my fadal cnc  run G0 at 200 IPM.
fadal can run up to 600 IPM but this is not my goal to stress my cnc at that speed. ( perhaps I will test it with this new card)
 About Ethercat  servos and I/os card I been testing,  I have  a hybrid configuration with ethercat, and parallel port and this configuration is working but realteck nic is having disconnect issues that the community say the intel nic is the good one for ethercat and servos, and test it with IO ethercat cards and this realteck nic do not notice me any issue,
 I do not have a pc with intel NIC yet.
Please share your comments and experience.
File Name: PinDefinition.txt
File Size:3 KB
Displaying 2041 - 2055 out of 12540 results.
Time to create page: 0.708 seconds
