  • PCW
  • PCW's Avatar
07 Jan 2025 16:06
Replied by PCW on topic Weiler DZ26 Millturn Conversion
Category: Turning
Does the 6I25 finish configuration loading?  (no red LEDs except briefly at power up)
Is the 6I25 jumpered for 33 MHz PCI clock?
  • blazini36
  • blazini36
07 Jan 2025 15:40
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
I installed the new deb from releases but it doesn't seem to be adding anything new. I don't have qabstractproperties on the pushbutton whether I set it inside the stacked widget or not. Do I have to do anything special when upgrading flexgui?
I'm not sure what qabstractproperties is, what are you trying to do with that?
If you download the deb from the latest release and install it with gdebi or your favorite way you have the latest.
I'll add a screenshot to the docs.
JT
Sorry I mean, Dynamic Properties. I couldn't remember the name because it does not appear. This is from your video
This is what I actually have.
I see what you're doing there, I got it from the first video.....I just can't do it because it doesn't exist. So I'm asking where dynamic properties for the QPushButton came from
I installed the 1.1 deb from git using apt yesterday
  • zelo
  • zelo
07 Jan 2025 15:32 - 07 Jan 2025 16:34
Ok, zelo, do a quick test to see if the speed doubles if you reduce the scale by half
Velocity doubles until 79, when set to 80 it will give error.
Actually up to 79.7 works.
  • Lcvette
  • Lcvette's Avatar
07 Jan 2025 15:26
probe basic - toolpath/file preview loading error
Category: QtPyVCP
i just did an install yesterday on one of my machines, my method of choice is how i listed it in the docs here:
kcjengr.github.io/probe_basic/development_quick_start_apt.html
thing of note, i had to go into the synaptic package manager after install and manually change to the preempt rt kernel as shown below, just search for linux-image in synaptic to bring up the different kernels. i also like to remove any unused or older kernels on my machine pc's once i have fully tested updated kernels.
  • Lcvette
  • Lcvette's Avatar
07 Jan 2025 15:19
Replied by Lcvette on topic Probe basic Install errors
Category: QtPyVCP
post your config files without them there isn't any way to identify the issue(s)
  • machinedude
  • machinedude's Avatar
07 Jan 2025 14:07
Replied by machinedude on topic Black Friday Deal got me :)
Category: Plasma & Laser
yep, already had that thought with the 4-jaw chuck route. the pneumatic idea will require different jaws for different material size but those could be made as well. that's the easy part. figuring out how to put it all together and not break the bank in the process is the hard part :) any kind of hollow body design for something fancy gets expensive quick the bigger you get.
  • Unlogic
  • Unlogic
07 Jan 2025 13:57
Calculating step length/space timings for Delta B3 servo drives
I'm trying to get my head around the calculation of the shortest suitable step length/space timings for the Delta B3 servo drives I'm using.
The manual for the servo drives lists the following specification:
I have the drives set to 10 000 steps per revolution and I'm using 5mm pitch ball screws with a 2:1 belt reduction.
My goal is to have a rapid speed of 8 000 mm/minute on the X/Y axis. In order to reach that speed with the current number of steps per revolution I have to set the step timing to the following values:
DIRSETUP   = 800
DIRHOLD    = 800
STEPLEN    = 700
STEPSPACE  = 700
My question is how do I calculate how much safety margin these values leave me given the specifications of the Delta B3 servo drives?
I assume the Mesa 7i96s card I'm using will not be the limiting factor.
  • zmrdko
  • zmrdko's Avatar
07 Jan 2025 13:26
Replied by zmrdko on topic Delta B3 index homing
Category: EtherCAT
Thank you for your reply.
This is the latest version of you ds402.comp file?
forum.linuxcnc.org/ethercat/47358-kollmo...over-ethercat#279190
  • JT
  • JT's Avatar
07 Jan 2025 13:09
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
As an added bonus I just added Next Previous buttons for a stacked widget so you only need two buttons for unlimited number of pages.
JT
07 Jan 2025 12:54
Replied by tommylight on topic Probe basic Install errors
Category: QtPyVCP
Moved to QtPyVCP section.
  • my1987toyota
  • my1987toyota's Avatar
07 Jan 2025 12:54
A propsed aid to retrieving information when try to provide answers.
The problem I see is unless it can be used to only make a select obscenely rich people even richer it
is kept locked away from the general public's view.
  • my1987toyota
07 Jan 2025 12:39
Replied by my1987toyota on topic Some 3D printing advice to start this section
Category: Additive Manufacturing
  Usually when I 3D print stuff I will make a pocket for a nut to either be pressed in or slid in place. That way if I have
to scrap the part I can recover the metal nut back out of it. I do understand though that their are times when that
simply isn't possible.
  • andypugh
  • andypugh's Avatar
07 Jan 2025 12:12 - 07 Jan 2025 12:12
Replied by andypugh on topic 2.9.3 INI_VARS issue
Lower-case INI file variables are OK in most circumstances.
For example adding this into the Touchy GUI init code (I just happened to have that one in the editor, not a special choice)
print("The value of [TEST]testywesty is %s" % self.ini.find("TEST", "testywesty"))
print("The value of [TEST]CAPITAL is %s" % self.ini.find("TEST", "CAPITAL"))
print("The value of [TEST]IDONTEXIST is %s" % self.ini.find("TEST", "IDONTEXIST"))
And inserting this in the corresponding INI file
[TEST]
testywesty = 12.3
CAPITAL = 4.56
Gives this result
The value of [TEST]testywesty is 12.3
The value of [TEST]CAPITAL is 4.56
The value of [TEST]IDONTEXIST is None
So lower case INI variables work in the general case.
But it seems that they do _not_ work in the case of G-code INI-file access.
This is probably because all G-code is lowercased before being sent to the interpreter. And then the bit of the interpreted that reads #<_ini....> variables explicitly uppercases them.
github.com/LinuxCNC/linuxcnc/blob/master..._namedparams.cc#L222
So, the actual situation is that if you want to read an INI variable from G code it must be capitalised, because case info is lost during the process of interpreting the G-code, and the interpeter assumes capitals.
To answer a question from the original posts, you can create a set of global parameters with particular values in the STARTUP_GCODES (would need to be a custom code or subroutine call, though).
But reading from the INI is probably best, accepting the limitations discussed here.
  • JT
  • JT's Avatar
07 Jan 2025 11:44
Flexible GUI
Category: Flex GUI
The first video really didn't show the steps to create a stacked widget page change buttons very well.
And I added a screen shot to the docs
gnipsel.com/linuxcnc/flexgui/controls.html#stacked-widget
JT
  • vre
  • vre
07 Jan 2025 11:43 - 10 Jan 2025 01:39
Replied by vre on topic MB2HAL write
MB2HAL write
Category: HAL
edit
If write 256(dec) to hal pin opens
and if write 512(dec) to hal pin closes
Also works function 16..
How to write values 256 and 512 to hal pins need a python script to convert boolean value to 16bit hex ?
Displaying 20446 - 20460 out of 21753 results.
Time to create page: 1.026 seconds
