  • Guytou
  • Guytou
04 Jan 2025 08:49
Replied by Guytou on topic encoder to change PWM value to VFD
In the meantime, I found the information I was looking for here : wiki.linuxcnc.org/cgi-bin/wiki.pl?Spindleoverride
  • BSOD
  • BSOD
04 Jan 2025 08:32
Please share your config, HAL and ini. (can't find them, if you did earlier.)
  • timo
  • timo
04 Jan 2025 08:31 - 04 Jan 2025 14:53
Stepper based machine some general questions
I finally got around to start putting wires on the MESA card. Now I came across some questions that may have simple answers.
1. Do I need to wire up the enable inputs on the stepper drivers?
  • motors work fine without enable lines.
  • driver reduces current to half when the motor is not moving; so no heat issue.
    Is there anything that I overlook that would make it adviseable to add this wiring?
    1.1. The 7i76 does not have an "enable Pin" on the step generator. So I then need to hook up enable to any normal I/O?
    2. I noticed that I can get a higher top speed when I reduce the accelleration and at lower top speed I can put in higher accelleraton values.
     For a small bench top mill should I rather focus on acceleration with lower top speed?
    3. Is it possible to generate a 4th axis in PNC config? I did not find it yet. Maybe someone can point me in the right direction. Do I have to add this manually to the HAL file?
    No idea why I could not make it work yesterday. Answers to 3. are: Yes it works with pncconf and NO manual adding it to hal from scratch is not required.  I just tried fresh again. Choose XYZA configuration and everything was fine.
04 Jan 2025 06:15
Replied by Cant do this anymore bye all on topic Pi5 MESA 7c80: mesaflash can't see the card.
Category: Driver Boards
It may help to mention that the 7c81, mesaflash & driver loading wise is the same. Apart from the difference in the name of the driver loaded the RPi4 is the same. You need to enable the SPI interface via config.txt
Hopefully you'll be able to put together a killer doc that people will read.
Good luck
04 Jan 2025 06:06
Replied by Cant do this anymore bye all on topic Arduino IO Expansion
Category: Show Your Stuff
This one is close to 30 years old, I wrote a win95 device driver in assembly many many moons ago, ones & zeros of different length. I also manged to squueze a basic master station into a 16f84 all done in assembly.
www.nmra.org/sites/default/files/standar...C/S/s-92-2004-07.pdf
www.testandmeasurementtips.com/morse-cod...munication-protocol/
Then there's "Manchester encoding" used by ethernet.
We can also encode 1 & 0 as a certain frequency or shifting the phase.
The PCIe bus transfers data serially, at far greater rates than the parallel ISA & PCI buses could.
PS/2 is another way of sending data serially.
SPI is somewhat different in that the transfer of data is controlled by a clock are controlled by a clock. Bits can be shifted in & out depending on the clock polarity, of course you wanna define this beforehand.
Human generated speech is serial in nature, supposedly Tibetan throat singers can generate more than one sound at a time. Then again sound is serial in nature, as is light.
Even the written word is serial in nature, unless of course you are some rare type that can ingest a whole page of words at once. I don't know if this is even possible.
Even the parallel port could be considered serial in nature, talking to printer requires sending the data at one byte at a time, even 32 bit transfers end up being broken into 8 bit chunks.
PAL, SECAM and NTSC sent data in a serial fashion.
This is kind of going off the rails now. I quite happy to not totally agree with you but also not think you are a fascist.
  • MrDe
  • MrDe
04 Jan 2025 05:54
I'm using the latest nvem-rt1052 from the Remora-RT1052-cpp repo, but the issue persists. I don't think it's a config problem, as all pins are functioning properly except the output pins. It seems unlikely that this is a coincidence.
I'm starting to suspect either the HAL component or the firmware might not be working as expected with the NVEM V5 board.
Here’s a quick video demonstrating the issue:
Thank you so much for your time, really appreciate it!
  • cmorley
  • cmorley
04 Jan 2025 05:08 - 04 Jan 2025 05:08
Replied by cmorley on topic QTDesigner PATH issue
This will because PATH.find_image_path() returned nothing.
Can you give any more information?
  • blazini36
  • blazini36
04 Jan 2025 04:52
Replied by blazini36 on topic Arduino IO Expansion
When setting the baud rate (divisor) on a 8250 or the later variants it will always be tied directly to the time allowed for each bit.
Lol yeah, that's how all asyncronous serial works. What do you think you are setting when you set "115200" on a COM port? Divide that baud rate into 1 and get the "time allowed for each bit". It's just easier to ask people to set the baud rate on the COM port than it is to say "gimme the period of time in us/ms". Anything that happens a specific number of times within a second is a period, you just forgot to do the division.
Yeah sure there are serial protocols the will define a zero has being so many us and one has being another value, which no one has yet to mention, but each period for either 1 or 0 will be an absolute value.
Like what? What protocol is that? That would literally be something that has no predefined data rate because the rate you can transfer data specifically relies on the difference between how many 1s are in that package vs how many 0s are in that package.
Morse code is not a serial protocol, it's a method of spelling the alphabet by using human understandable events, like flashes of light or sound. There is no precise timing involved, just perception. You can't perceive the difference between 1us and 1ms and a machine would have a hard time trying to figure out what the hell some outrageously long and inconsistent "dot" is.
  • ccatlett1984
  • ccatlett1984
04 Jan 2025 04:31
Replied by ccatlett1984 on topic Pi5 MESA 7c80: mesaflash can't see the card.
Easier than trying to edit a post.
My fork was way out of date to create a pull request and I've kind of forgotten the code structure of the Image generating program. So I started a new thread asking if the next round of images could have the spi interface enabled, I also mentioned that you were a very patient user that had been lead astray by the spidev10.0 being created with the SPI interface, I guess it would be a idea to refer to it as the SPI user usable interface.
I think it would be an idea just to keep it to that topic alone, rather than requesting other software packages and mind reading abilities to be added (rod has declined the mind reading abilities on previous occasions). Tho to be fair in would be quite unkind for the poor old Rpi to read my mind.....I barley know what direction it is going. ;)
That sounds great, I am including this specific callout in the write-up that I am making (specifically for the 7c80, geared towards the Pi5). Since a start to finish guide doesn't exist in any single document.
  • Jdolecki
  • Jdolecki
04 Jan 2025 04:24 - 04 Jan 2025 04:45
Lathe project was created by Jdolecki
Lathe project
Category: Turning
I been wanting a small Cnc lathe for awhile now.
One of my requirements was to have its own stand / enclosure.
I was mainly interested in just the iron.
My initial plan was to strip and rebuild it mechanically and electrical.
I looked at different controller mach3 (old) Mach 4 ( buggy I heard) acorn (expensive) masso ( only does x and y)
Found grizzly 924 on fb marketplace for cheap and the guy even delivered it.
The closer I looked at the fuzzy pictures I realized it already had a mesa card it it with two expansion cards.
So this is my intro to Linuxcnc.
first steps
1: clean it
2: put it on wheels
3: power only the motherboard and replace battery.
4: bring up the 220 mains.
5: see it the old controller still starts up.
  • Benb
  • Benb's Avatar
04 Jan 2025 04:15
Replied by Benb on topic Inhibit tool when z is above set point
Category: HAL
If you have measurment of the z distance you can use the hal compare component.
linuxcnc.org/docs/stable/html/man/man9/comp.9.html
otherwise install a limit switch to send a signal to inhibit the laser.
  • Jdolecki
  • Jdolecki
04 Jan 2025 04:01
Lathe setup question was created by Jdolecki
My machine has a 5i20 card on the motherboard.I don’t see that card option on PcConfig.
Do I have to add it somewhere
thanks john
  • Nolan2924
  • Nolan2924
04 Jan 2025 03:19
BRIDGEPORT R2E3 MILL REDO QUESTIONS was created by Nolan2924
I have a Bridgeport R2E3 mill that I gutted and followed the instructions from a Fellow on line RustyBrainDump.com did everything step by step but having problems. He is not available to answerquestions anymore. Started this process in 2022 and stopped. My wife has medical issues now. So home bound now trying to return with this project. Have analog Encoders that are on 80vdc brush motorold school machine. have 3 Gecko 320X drivers ST-3V breakout board.  Most folks say that I Should of used7i77/7i77e and Daughterboard? Using Linux CNC, 150 chopper wheel count Analog encoder. 5vdc input 50-200ma. Do anyone know that converted a CNC R2E3, 4000lbs machine. I would hate to stop now.Tony K Omaha NE
04 Jan 2025 03:18
A propsed aid to retrieving information when try to provide answers. was created by Cant do this anymore bye all
Would this device or something similar be of help
04 Jan 2025 03:10
Displaying 20656 - 20670 out of 21838 results.
Time to create page: 0.697 seconds
