  • ccatlett1984
  • ccatlett1984
01 Jan 2025 23:14
Replied by ccatlett1984 on topic Pi5 MESA 7c80: mesaflash can't see the card.
Category: Driver Boards
repo shows 3.4.5-1 as latest
  • PCW
  • PCW's Avatar
01 Jan 2025 23:09
Are you using the latest mesaflash?
(3.5.10)
  • Becksvill
  • Becksvill
01 Jan 2025 23:05
assignments glitching with larger ladder programs
Category: ClassicLadder
hey chris and everyone else
here is my config to have a look at cheers
Andrew
  • CaspianCmonster
  • CaspianCmonster
01 Jan 2025 23:05
Replied by CaspianCmonster on topic Tool setter setup
Tool setter setup
Category: Basic Configuration
Happy New year everyone.
I am back in the workshop and have made some progress.
I did a new clean install with the current version and on a much more powerful computer as my original machine was just not happy being a super slow single board computer from 10 years ago. The only other computer I have around with a PCI slot is a massive dual Xeron workstation which is a great heater in the winter :)
I was chatting with some other folks about this and they suggested that using the qtdragon interface would perhaps be a good idea so I made a config with that and it is close to working but there are some errors around calling the python files. I  used the text from the manual and added the "examples" folder step so they should point correctly but I think there is something wrong, either with what I wrote or how the paths are written in the example. (I don't understand the format with the text over two lines with a ":/" but I am no linux expert.
Any ideas?
thanks
Luke
01 Jan 2025 22:59
Replied by tommylight on topic 7i96s not recognized
Not a problem, netmask is 24 for the 255.255.255.0 subnet, it is the same thing, just written differently.
8 is 255.0.0.0
16 is 255.255.0.0
24 is 255.255.255.0
Subnets are used to separate internal networks despite being on the same physical network.
  • ccatlett1984
  • ccatlett1984
01 Jan 2025 22:57 - 04 Jan 2025 04:46
Pi5 MESA 7c80: mesaflash can't see the card. was created by ccatlett1984
Unexpected cookie at 0100..0110:
00000000 00000000 00000000
No 7C80 board found
getting this response when running the below command.
[code]sudo mesaflash --device 7c80 --addr /dev/spidev0.0 --spi --readhmid
Do i need to configure this blind (using something like a 7i96), then change the line in the hal file to load the new driver?
[/code]
  • slowpoke
  • slowpoke
01 Jan 2025 22:55 - 01 Jan 2025 23:09
Replied by slowpoke on topic 7i96s not recognized
Your help is much appreciated.
Mesa is definitely talking now (I can see DRO input on inputs 0,1 changing)
I just found a video by rodw that explains some of the IP stuff, I think I might now have a rudimentary understanding:
  • direct 1:1 connection from PC's Ethernet port (10.10.10.100)  to Mesa port 10.10.10.10)
  • I though that I needed to put the MESA boards address into the wired network, but you actually have to have a different address on the PC side with the same 10.10.10.x
Next up the fun stuff.
  • PCW
  • PCW's Avatar
01 Jan 2025 22:53
Replied by PCW on topic 7i96s not recognized
 A /24 netmask is the same as 255.255.255.0
  • slowpoke
  • slowpoke
01 Jan 2025 22:51
You can set this up with the network manager as you already have
but the address in the network manager should be 10.10.10.100
not 10.10.10.10,
also the netmask should be 255.255.255.0 not 255.0.0.0
okay, finally LinuxCNC starts.
However when I enter 255.255.255.0 for the netmask it changes it to 24 when i go back in, not sure if that's a problem?
  • ccatlett1984
  • ccatlett1984
01 Jan 2025 22:46
Replied by ccatlett1984 on topic raspberry pi5 requirements
Storing files would be whatever size SD Card you get for the Pi, it has nothing to do with the 2GB/4GB/8GB variants (those are designating the amount of RAM on the device)
  • Skippy2024
  • Skippy2024
01 Jan 2025 22:41
raspberry pi5 requirements was created by Skippy2024
How many GB raspberry pi do I need? Would like to store some projects files on it.
  • PCW
  • PCW's Avatar
01 Jan 2025 22:26
not 10.10.10.10,
01 Jan 2025 22:25
  • slowpoke
  • slowpoke
01 Jan 2025 22:21 - 01 Jan 2025 22:22
I'm not sure what you mean when you say (long) Ethernet device name?
enx0050b6c0edc3
I'm really lost here.....
What exactly should I put in that file?
I added my connection information in the previous post
  • PCW
  • PCW's Avatar
01 Jan 2025 22:17
enx0050b6c0edc3
Displaying 20821 - 20835 out of 21866 results.
Time to create page: 0.595 seconds
