  • gardenweazel
  • gardenweazel's Avatar
14 Dec 2024 14:20 - 14 Dec 2024 14:23
Replied by gardenweazel on topic Inconsistent values from Versaprobe
Category: Qtvcp
I suspect that I may have found out what is going on.
I was reading thru the setup instructions in the qt_auto_probe_tool.ngc file being careful not to
"read-thru" anything that I may have missed. This sentence caught my eye:
The following workflow assumes using both a XYZ probe and a Z Toolsetter:
;    1 - Initial Setup: Before beginning the program, setup the Probe Tool as
;        having a zero z-offset in the tool table.
My tool table file did not have an entry for the Z-Height of zero. So I added the entry as follows:
T99  P99  D+2.000000 Z+0.0 ;3D Probe
I started the test program that I had and everything worked as intended/expected. However, as it was getting late in
the evening when I tested I tested with a much shorter end mill than my previous tool which was the longest mill in my
inventory. Today, I will retest with the longer tool and report results. I'll have to look in the code and see if I can find where
the tool Z is picked up and see if there's any room for improvement if this is indeed the problem. Hence, if the probe Z has no value,
then assume zero?
14 Dec 2024 14:05
Replied by tommylight on topic Improving Base Thread Jitter
Category: Installing LinuxCNC
That reading is enough to continue testing.
Latency test can not test for every scenario/load/whatever happening in a PC, but it is a good indicator as to usable or not usable.
  • Lcvette
  • Lcvette's Avatar
14 Dec 2024 14:02
Replied by Lcvette on topic Trajectory Planner using Ruckig Lib
Hi Lcvette,
It's indeed a alternative controller, once it finished.
This can take a long time. Some are good coding day's, some are bad coding day's without good progress.
It turned out, modifying lcnc's code to do thing's i would see accomplished is almost impossible.
Best reason is entanglement.
Then just writing new code from scratch is 10x faster to get things done.
There are no goals for me. It's just a project to try out new things wich got my interest's.
It's not the purpose to outsmart lcnc or something like that. Or claiming thing are better etc.
Altrough it is interesting to find out differences in lcnc and this approach.
Like this has bi-directional hal pins and used modern boost interprocess for shared memory.
Today did a mayor bug fix. It turn's out that multiple shared memory regions updated by thread's, would not exchange data
properly. Even when mutex etc. was set.
In the end it worked by using a single shared memory region for all thread's.
Sounds very exciting! like an overhaul of linuxcnc without the constraints of outdated sections.  very cool indeed!
I have a question regarding the current Trajectory planner and since you have been in it elbow deep i was wondering if i could bounce it off you to see if it may be feasible for those of use who are experiencing some pretty bad effects of it.  I don't want to hijack this thread and was wondering if we might chat in realtime?  this is the QtPyVCP chat room link below please feel free to drop in, you can ping me with @Lcvette in the room and I will get a notification!
matrix.to/#/#qtpyvcp:matrix.org
Thanks Grotius, I hope to chat soon!
Chris
  • kjlty
  • kjlty
14 Dec 2024 14:01
Replied by kjlty on topic Large File Memory
Large File Memory
Category: Other User Interfaces
Hello expert, look at the picture description, can you optimize the memory usage?专家你好,看图片描述,你能优化内存使用吗?
  • kjlty
  • kjlty
14 Dec 2024 13:56
Large File Memory was created by kjlty
Large File Memory
  • Lcvette
  • Lcvette's Avatar
14 Dec 2024 13:31
Replied by Lcvette on topic preview wrong??
preview wrong??
hard to tell what is going on without more data, maybe tell us what the work offsets were set at as well as the current dro position readings at the time of the image capture.
  • Mitch66
  • Mitch66
14 Dec 2024 13:20
Replied by Mitch66 on topic Improving Base Thread Jitter
After installing Wheezy the jitter reading is 24899 - much improved. interestingly after all the BIOS changes the installation process took much longer - but it worked .
Do you think this reading is good enough to proceed with this computer in its current state?
  • seebaer1976
  • seebaer1976
14 Dec 2024 13:13 - 14 Dec 2024 13:49
Replied by seebaer1976 on topic Inconsistent values from Versaprobe
Category: Qtvcp
I've also continued testing and haven't made any progress.
and the m6 doesn't work under basic probe. It always tells me that the pin  #<_hal[qtversaprobe.searchvel]> doesn't exist.
  • JT
  • JT's Avatar
14 Dec 2024 11:29 - 14 Dec 2024 12:19
Flex GUI and Gentoo was created by JT
Flex GUI and Gentoo
Category: Flex GUI
I just found out that Flex GUI works on Gentoo!
JT
  • JT
  • JT's Avatar
14 Dec 2024 11:21
Replied by JT on topic Turn Preview Off
Turn Preview Off
Yes, you can add a checkbox to disable the program view.
JT
14 Dec 2024 11:08
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Debian dpkg-buildpackage uses perl, perl complains when running menu-config without LANGUAGE set.
So perl hasn't anything to do with Linuxcnc but when building packages, I had to build linuxcnc to have the hm2_spix driver for the Rpi5.
  • HansU
  • HansU's Avatar
14 Dec 2024 10:35
Building debian package without GTK2
I am following the steps from:
linuxcnc.org/docs/2.9/html/code/building...ding_debian_packages
but how can I disable GTK2 for the debian package build like I can do with "--disable-gtk2" for the normal build?
  • rodw
  • rodw's Avatar
14 Dec 2024 10:18
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
Why on earth are we using perl in a Linuxcnc project? What's wrong with Python? At least its supported by the project.
  • gitin
  • gitin
14 Dec 2024 09:24
Replied by gitin on topic Equivalent of some Fanuc codes
G05
High-speed and high-precision control Ⅰ
G05 P10000 High-speed and high-precision control opening
G05 P0 High-speed and high-precision control off
G05 P3 High-speed machining on
G05 P0 High-speed machining is off
G05.1
High speed and high precision control Ⅱ
G05.1 Q1 High-speed and high-precision control on
G05.1 Q0 High-speed and high-precision control off
G05.2 Q2 X0 Y0 Z0 Free-form surface high precision mode is on
G05.1 Q0 Free-form surface high precision mode is off
G05.1 Q1 R1 - coarse high-speed processing,
the feed at the corners does not change,
the corners are cut off, the contour does not correspond to the set one.
G05.1 Q1 R5 - high-speed processing, speed-quality balance,
deceleration at the corners, corners can still be cut.
G05.1 Q1 R10 - precise high-speed processing, significant deceleration
at the corners, the corners are not cut off, the contour corresponds
to the one set within the accuracy of the machine.
G64 P 0.01 may help. I think the professionals will correct me.
14 Dec 2024 09:09
Replied by Cant do this anymore bye all on topic Mesa firmware versions and updating
Category: Driver Boards
The RPi 5 has, from memory, has "engery saving malarkey" for it's ethernet, and no it's not on the USB bus, that foolishness was ended with the RPi4 I believe.
With regards to the mesa firmware....it's solid and reliable, a mesa card will need it's firmware updating as often as a Toyota Echo does for it's ECU.
Remember we aint in the Windows world. ;)
Displaying 21691 - 21705 out of 22100 results.
Time to create page: 0.972 seconds
