  • JPL
  • JPL
13 Dec 2024 08:08
7i87 what is the purpose of W1 and W3 ?
Category: Driver Boards
Quick question: What is the purpose of W1 and W3 for the Mesa 7i87?   Manual describe W2 but not a word about W1 and W3.
  • cmorley
  • cmorley
13 Dec 2024 04:58
Replied by cmorley on topic cam_align
cam_align
Category: Qtvcp
Are you building a custom control panel there?
  • cmorley
  • cmorley
13 Dec 2024 04:30
cam_align
Category: Qtvcp
Here is a version that use a sequence to change the diameter increment.
hold left button double click right button  increment + .5
hold right button double click left button  increment - .5
See if you like that. If not, yes we could just use the rotation increment for the diameter increment too.
This file must be named 'camview_widget.py' and replace the original file.
  • Cj.tns60
  • Cj.tns60
13 Dec 2024 03:25
Replied by Cj.tns60 on topic Retrofit torno CNC traub TNS 60
Category: CNC Machines
I need help with the main spindle motor.
DC Motor 34.5Kw
Independent excitement
Independent Brake
independent cooling
tachogenerator 60v 1000rpm
Can anyone shed some light on which driver I should at least study, or do we need more information
According to the electrical diagram, the old switching board had 130A, if you want I can scan the electrical diagram to help
  • abdulasis12
  • abdulasis12
13 Dec 2024 01:35
Feedback control XY not full speed run G1 when curve or Arc
You should increase motion blending tolerance (g64 p0.002)
The more accurate the tolerance -> the lower the speed.
For roughing operation (adaptive) such accuracy is not required. Try setting P0.05, this will smooth the trajectory and allow it to be executed at high speed.
If the acceleration of your machine is not high, then for roughing operation you can choose P even more.
Hi MR.hmnijp
Thank you for the suggestion. I have applied your advice and made some adjustments. Previously, it was G64 P0.002 Q0.002. Now, I’ve changed it to G64 P0.01 and removed the Q0.002 parameter. The machine runs much more smoothly, although there are still some slight jerks when transitioning into curves during G0 moves. However, it’s a significant improvement.
Do you happen to know what the Q parameter is used for?
Thank you,
Asis
  • abdulasis12
  • abdulasis12
13 Dec 2024 01:27
Traj section in the ini file, velocities are much lower than in the display section, try setting those same as display section.
Hi MR.Tommy
"much lower than in the display section" Okay, I got it wrong. I think it's for the motor velocity. I will change it back to default.
Thank you,
Asis
  • fully_defined
  • fully_defined's Avatar
13 Dec 2024 01:16
Replied by fully_defined on topic Rotary Selector Switches & Resistors
I knew I wasn't crazy. Thanks for posting this!
I am at the very beginning of my LinuxCNC experience, and I don't know what I don't know. The only thing I know for sure is it isn't well documented.
  • D Jensen
  • D Jensen
13 Dec 2024 00:39
Replied by D Jensen on topic Retrofitting a 1986 Maho 400E
Category: Milling Machines
Just a couple more files.These are extracted from the Maho Technical manual that you can download from one of my previous links to my Google Drive.
If you just want to remove the quill it's easy to flip the vertical head on it's side as shown. It eliminates the possibility of dropping the whole thing out accidentally.
I've edited the sketch to show a trap. Mine doesn't have the bolt setup for retaining the hand wheel assembly like Marks.I don't have the "U" shaped cover shown in Marks video. Mine has 3 separate plates instead. Under the left plate there is a a tapered dowel scotch key to retain the assembly. As you can see the instructions neither show or explains this. I've added the instruction in red. The machine has these tapered dowels in quite a few other places also.
It has the same travel limiting screw, but they only mention loosening it. Better to remove it completely since you don't know how loose to clear the quill. 5 mm maybe!
The quill clamp on mine is quite different. It can be clamped in any quill position, unlike Marks which is one tooth step on the quill rack. I think both work nicely.
The heating instruction is to remove the tool clamping mechanism.is here, but it might be wise to leave the limit screw in place before you do it. I pulled the whole lot out and heated it on the bench in the vise as previously noted.
Cheers,
David
  • dm17ry
  • dm17ry's Avatar
12 Dec 2024 21:48
Replied by dm17ry on topic Rotary Selector Switches & Resistors
if you can write a little bit in c - just make a one-liner custom component... something like
pin in float vin;
pin out float factor;
function _;
if (vin < THRESH1) factor = 0.1;
else if (vin < THRESH10) factor = 1.0;
else if (vin < THRESH100) factor = 10.0;
else factor = 100.0;
select THRESH values somewhere in between values you get in corresponding switch positions.
the resistor thing should work fine. i did that for 24-pos switch, though with stm32 adc (12bit?)..
12 Dec 2024 21:04
Replied by tommylight on topic Improving Base Thread Jitter
Category: Installing LinuxCNC
thank you for the link to your document. I have a 2 core computer which I was rather hoping I could interface through a parallel port, and so I am not sure how much applies to me.
Download the Wheezy ISO from here
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
Burn to USB, boot from USB and test latency, should be much better, but still you should disable in BIOS;
-hyperthreading
-turbo
-TPM
-aggressive PCI-E power management
-speed-step
-virtualisations, all
-power states if any
-something else that i can not recall right now that should be disabled on older Dell PC's....
  • Mitch66
  • Mitch66
12 Dec 2024 20:50
Replied by Mitch66 on topic Improving Base Thread Jitter
thank you for the link to your document. I have a 2 core computer which I was rather hoping I could interface through a parallel port, and so I am not sure how much applies to me. From the Optional Steps section I find 'Disable energy efficient ethernet' and 'disable active state power management', I don't think the 'Isolate 2 Cores' is applicable. I was rather looking for things I should do in the BIOS, but the only reference is the Review Latency section which says the BIOS setting are important in reducing latency.
My lack of knowledge is almost certainly causing me to read the document incorrectly and I apologise for that. I will go into the BIOS and try to disable the power management and I will not have the computer on-line, but otherwise still not sure how to proceed.
  • Lisov_R
  • Lisov_R
12 Dec 2024 20:45
I do not know if it is worth doing this fee at all. There is only one two-year-old firmware for LinuxCNC on it. Will there be any positive result for switching from Mach3 to Linux CNC with this board?
  • aDm1N
  • aDm1N's Avatar
12 Dec 2024 20:44
At the beginning I tested it briefly, but not in detail. seemed to work. In the end nothing worked.
  • Lisov_R
  • Lisov_R
12 Dec 2024 20:38
At the moment when you couldn't flash it, did you try working with Mach3? If the controller itself is not working, it would hardly give signals to the output.
Displaying 21766 - 21780 out of 22103 results.
Time to create page: 0.513 seconds
