12 Dec 2024 20:31
Replied by tommylight on topic Mesa firmware versions and updating
Category: Driver Boards
I am correct in understanding that when I get a new Mesa 7i96S card, I don't have to flash any firmware to it, please?
Yes, you are correct, it comes already flashed with the normal firmware for 5 step/dir and a spindle with encoder feedback, so no need to flash.
  • PCW
  • PCW's Avatar
12 Dec 2024 20:27
Solution fo "hm2 error finishing read" with no good PC
Do all inductive loads switched by the 7I97T have flyback diodes?
Did you verify that IRQ coalescing is disabled?
verify with:
ethtool -c eno1
A a temporary test you can try pinning IRQs with
File Name: pinirq_2024-12-12.txt
File Size:1 KB
download,
chmod +x pinirq.txt
sudo ./pinirq.txt en01
and then run LinuxCNC
  • aDm1N
  • aDm1N's Avatar
12 Dec 2024 20:06
I had problems with the new version of the board at the beginning. Flashing the board was not possible. I have tested some ST-Link and also Daplink. Actually the board was defective. I complained about it and got a new one and bought another one. Flashing worked with both without any problems.
  • greg23_78
  • greg23_78
12 Dec 2024 19:57
I set my configuration for the tool change because this is where the fault comes at 100% if there is something wrong.
  • Lisov_R
  • Lisov_R
12 Dec 2024 19:55
If it is not clear in my question, then I will say again that I have tried it. Not one of the programs is connected to the STM32, not via SWD, not via UART, not via ST-Link, not via RS232. The board itself is working and works with Mach3. Perhaps all ports are closed in the firmware. Perhaps someone has come across such a thing?
  • Ricoch3T
  • Ricoch3T
12 Dec 2024 19:55
Encoder belt was created by Ricoch3T
Encoder belt
Category: CNC Machines
 Does anyone have a source for a belt like the one pictured?
  • greg23_78
  • greg23_78
12 Dec 2024 19:54
I added the line
I restarted the PC
I still have the same fault
  • PCW
  • PCW's Avatar
12 Dec 2024 19:45
auto eno1
    iface eno1 inet static
    address 10.10.10.11
    netmask 255.255.255.0
    hardware-irq-coalesce-rx-usecs 0  <<<< try adding this
  • greg23_78
  • greg23_78
12 Dec 2024 19:37
lspci | grep -i ether
cnc@cnc:~$ lspci | grep -i ether
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-LM (rev 04)
sudo nano /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
#source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
auto eno1
    address 10.10.10.11
  • PCW
  • PCW's Avatar
12 Dec 2024 19:25
1. if your PC has a Intel MAC, do you have IRQ coalescing disabled?
2. Do you have the Ethernet IRQ pinned?
  • greg23_78
  • greg23_78
12 Dec 2024 19:05
cnc@cnc:~$ halcmd show param *.tmax
Parameters:
Owner   Type  Dir         Value  Name
    72  s32   RW            924  abs.0.tmax
    45  s32   RW           1124  and2_both_sw.tmax
    45  s32   RW            900  and2_driver_x_fault.tmax
    45  s32   RW           1068  and2_driver_z_fault.tmax
    45  s32   RW            708  and2_invert_fault.tmax
    45  s32   RW            848  and2_jogconvoyor-fwd.tmax
    45  s32   RW           1020  and2_jogconvoyor-rev.tmax
    45  s32   RW            984  and2_mot_rev_off.tmax
    45  s32   RW           1060  and2_tailstock_manu_moins.tmax
    45  s32   RW            856  and2_tailstock_manu_plus.tmax
    45  s32   RW           1112  and2_turret_lock.tmax
    42  s32   RW           2112  carousel.0.tmax
    60  s32   RW           1284  driver_x_fault.tmax
    60  s32   RW           1008  driver_z_fault.tmax
    63  s32   RW           2104  encoder.capture-position.tmax
    63  s32   RW           2224  encoder.update-counters.tmax
    36  s32   RW              0  hm2_7i97.0.read-request.tmax
    36  s32   RW        2604944  hm2_7i97.0.read.tmax
    36  s32   RW          46236  hm2_7i97.0.write.tmax
    60  s32   RW           1000  invert_fault.tmax
    29  s32   RW           3164  motion-command-handler.tmax
    29  s32   RW          30508  motion-controller.tmax
    69  s32   RW            992  near.0.tmax
    51  s32   RW           1196  not_both_sw.tmax
    60  s32   RW            804  oil_level.tmax
    60  s32   RW              0  oilpressure.tmax
    54  s32   RW           1072  oneshot_motor_rev.tmax
    48  s32   RW            944  or2_jogconvoyor-fwd.tmax
    48  s32   RW            752  or2_jogconvoyor-rev.tmax
    48  s32   RW            820  or2_tailstock_manu_auto_moins.tmax
    48  s32   RW            980  or2_tailstock_manu_auto_plus.tmax
    39  s32   RW           1324  pid.s.do-pid-calcs.tmax
    39  s32   RW           2272  pid.x.do-pid-calcs.tmax
    39  s32   RW           1120  pid.z.do-pid-calcs.tmax
    60  s32   RW           1224  pneumatic_pressure.tmax
    66  s32   RW            936  scale.0.tmax
    30  s32   RW        2633312  servo-thread.tmax
    60  s32   RW           1108  tension_convoyor.tmax
    57  s32   RW            904  timedelay.0.tmax
  • PCW
  • PCW's Avatar
12 Dec 2024 18:45
 I would make sure that the 7I97T mounting hole near the RJ45 connector is grounded to chassis ground
When you get an error, what does:
report?
  • greg23_78
  • greg23_78
12 Dec 2024 18:22 - 12 Dec 2024 18:36
I did a continuity test on the 7i97t at the fasteners, it's not grounded.
below are videos of my errors. On one of them, the turret doesn't even launch before the error message.
the other is during rotation.
  • rodw
  • rodw's Avatar
12 Dec 2024 17:48
Replied by rodw on topic Improving Base Thread Jitter
Category: Installing LinuxCNC
Is there a list anywhere of the required changes please? If those changes reduce the latency then may be the graphics card might be worth a try.
thanks again
Try my list
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
Displaying 21781 - 21795 out of 22103 results.
Time to create page: 0.534 seconds
