  • Holzwurm56
  • Holzwurm56
25 Jul 2026 16:44
Help Controller for a Lathe ? was created by Holzwurm56
Category: CNC Machines
Hello, I have a—Belgian?—Gallic 16 NC lathe. When I acquired it, I removed the control system but left the spindle power unit in place. For the control system, I use Mach3 via two parallel ports, UHU drives, and DC servos. I can also turn in a quasi-conventional manner using two electronic handwheels. The whole setup worked well for years, but it is admittedly outdated. Now I have a fault in the original main power circuit. Although I have an old wiring diagram, the actual wiring is a chaotic mess. I am now considering overhauling the main power circuit to make it organized and installing a more modern control system. However, I need to be able to use the two electronic handwheels, as there are no mechanical ones. Does anyone have experience with a control system that is affordable (the machine is 35 years old and could fail completely at any time), supports two electronic handwheels, and doesn't come with a 1,000-page manual?
In my stock is a Mesa 7I96 Eth, can I use it?
Many thanks for any replies,
Hans
  • RotarySMP
  • RotarySMP's Avatar
25 Jul 2026 16:43
Lathe macros - Facing bug? was created by RotarySMP
Category: Turning
G'day all,
This is a question about Andy's lathe macros. I am getting a slight angle / coordinated facing angle although I set zero angle in the cut parameters.
Is this finger trouble on my part, or a possible bug?
Cheers,
Mark
  • GFC
  • GFC
25 Jul 2026 11:08 - 25 Jul 2026 11:09
Integrating ethercat with QTplasmaC and Beckhoff modules
Category: EtherCAT
First of all thank you for the help
with your tips I managed to get a list of all the I/O pins and managed to test the inputs manually
I also managed to create and edit a qtplasmac config the way you suggested, now I can get it to run
I managed to get these things working:
-QtPlasmaC interface
-motion on all axis when jogging the machine
-external E-stop
-torch break detection switch
-machine enable output turning on a light
but im still having some problems:
- cant get a torch on output signal when I do a torch pulse
- the ohmic probe enable doesn't output any signal
-when I hit cycle start the G code pauses without moving the machine
what are the best ways to debug this situation and what should I be looking for?
all config files in a zip file below
Thank you again
  • 0x2102
  • 0x2102's Avatar
25 Jul 2026 10:11 - 25 Jul 2026 10:18
Replied by 0x2102 on topic Preview plot with touchscreen gestures
Category: Gmoccapy
Hello everyone,
first of all, thanks to Wischi for the touch gesture version of gremlin.py — it works perfectly on my hardware (Melfas LGD AIT touch panel, LinuxCNC 2.9, Gmoccapy).
The only limitation for me was the one HansU already mentioned: with the mouse you can only rotate, dragging/panning does not work in any setting, because motion() returns unconditionally.
I'm attaching a version that is Wischi's file unchanged, with one addition: instead of disabling motion() completely, it now filters events by their source device. Only events that clearly come from a real physical mouse are processed — the event must not be pointer-emulated, the source device must be classified as MOUSE, and the device name must not contain "touch". Everything ambiguous is discarded, so the touch behavior stays exactly as in Wischi's version.
The background: many touch controllers expose a second X input device that does driver-level mouse emulation (mine shows up as "Melfas LGD AIT Touch Controller Mouse" in xinput list). Its events look like genuine pointer events to GTK — no emulation flag set — and those are what caused the original "preview only moves a couple of mm then stops" bug in the legacy motion() path. That's why the filter also checks the device name, not just the emulated flag.
Result on my machine:
Touch: unchanged from Wischi's version — one finger rotates (perspective view), two fingers pan and pinch-zoom
Real mouse: full mouse_btn_mode behavior restored — left rotate, middle drag/pan, right zoom (mode 0), shift+left drag also works
Since motion() is active again, the mouse button mode setting in Gmoccapy works again too
Tested on LinuxCNC 2.9 with Gmoccapy, capacitive multitouch panel. As before: just replace gremlin.py in /usr/lib/python3/dist-packages/ (keep a backup of the original — it gets overwritten on updates).
Changes:
1. Lines 40–50 — header comment (documentation only)
2. Lines 676–699 — new helper function _is_real_mouse_event()
3. Line 700 — motion()
  • rodw
  • rodw's Avatar
25 Jul 2026 08:20
Replied by rodw on topic LinuxCNC S-Curve Accelerations
Its in Master branch.
  • Darium
  • Darium
25 Jul 2026 04:10
Replied by Darium on topic LinuxCNC S-Curve Accelerations
May I ask how the project is going? Any update?
  • rodw
  • rodw's Avatar
25 Jul 2026 03:25
Gantry oxyfuel / plasma type machine from scratch
QEMM on Linux is more to my taste than Virtual Box in Windows. On Linux VB kept getting in a tangle over UEFI
25 Jul 2026 03:23
Flexi-HAL – “hard limits tripped”, home inputs read as permanently triggered
Simple answer would be find the old image and do not change it, but no idea how or where or anything as i do not use RPI's.
From what i read here (hence the i do not use them as they are way to much trouble), there is something that needs to make GPIO active, but i do not recall what or how.
25 Jul 2026 03:16
25 Jul 2026 03:15
Replacing RichAuto A11 handle with PC control (LinuxCNC/Mach/UCCNC) on AC servo
This is the second time i am reading this, most if it is your statements, not questions, the only actual question i can find is about the dual Y axis, and that can be done in multiple ways, from using the same output for both, to have two separate outputs with two separate home switches and the added possibility of tramming the axis every time the machine homes.
The Mesa 7i96S should be all that is needed from what i gather, but you will not have position feedback to LinuxCNC and that is fine, but if you do want that and the drives have encoder outputs, you can add a Mesa 7i85 or 7i85S as it has 4 encoder inputs, and there is another one on the 7i96S for the spindle feedback.
25 Jul 2026 03:05
Replied by tommylight on topic Servo driver
Servo driver
We would need much more info to be able to help.
  • cmorley
  • cmorley
  • Luczia
  • Luczia
24 Jul 2026 22:01
Replied by Luczia on topic AMSAMOTION IO module
Category: EtherCAT
Hello @Kuzma30,
I'm looking at starting a EtherCAT build and considering the AMSAMOTION EC3A IO1632. Have you been able to make it work on your setup and could you share the EtherCAT-config.xml file ?
Thanks !
Displaying 2191 - 2205 out of 12539 results.
Time to create page: 0.343 seconds
