LinuxCNC S-Curve Accelerations
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
01 May 2026 13:11 #346077 by Todd Zuercher
Replied by Todd Zuercher on topic LinuxCNC S-Curve Accelerations
I'm not really in a position to do any testing on hardware right now (I no longer work in a router shop.) but I can offer links to some G-code that I used in the past to help with testing the circular arcs tool planner when it was being developed. They are some 2.5-D V-groove engraving tool paths. They are in inches and need to have approximately +/- 0.003 of precision in the movements to look good. The first file is only XYZ moves, the 2nd file has XYZW to run a 2nd engraving spindle on a 2 headed router.
File Name: SER-40.ngc
File Size:540 KB
File Name: 130207LZW.NGC
File Size:127 KB
The following user(s) said Thank You: grandixximo, tommylight
07 May 2026 06:06 #346239 by m0602232
Replied by m0602232 on topic LinuxCNC S-Curve Accelerations
I'll attach one simple spiral planing operation gcode file. In my machine this brought up the toolpath blending problems in tp1, I had to roll back into tp0 (haven't tried tp2 though). I could not get the machine to move smoothly, tried different blending settings but no help (tp0 blends this just fine). Unfortunately didn't have time to investigate any further but maybe simulation shows something?
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Elite Member
  • Elite Member
10 May 2026 02:32 #346298 by grandixximo
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
github.com/mika4128/liscio/tree/main
new trajectory/gcode compressor for the future trajectory planner, testers wanted, feed your gcode to it, check the SVG output
The following user(s) said Thank You: akb1212, MX_Master, endian, m0602232
10 May 2026 14:21 #346308 by m0602232
This looks promising, nice work!
A couple of quick tries, sometimes the compressor seems to output scientific notation on small decimals; ie. X-76.198 Y6.6066e-05. That and injected G0 X0 Y0 Z0 at the beginning are only things that pop up at the first tests.
The following user(s) said Thank You: grandixximo, akb1212
  • grandixximo
  • Elite Member
  • Elite Member
12 May 2026 02:11 #346335 by grandixximo
Should be fixed
The following user(s) said Thank You: akb1212, rodw, endian, m0602232, NWE
25 Jul 2026 04:10 #348050 by Darium
Replied by Darium on topic LinuxCNC S-Curve Accelerations
May I ask how the project is going? Any update?
25 Jul 2026 08:20 #348051 by rodw
Replied by rodw on topic LinuxCNC S-Curve Accelerations
Its in Master branch.
The following user(s) said Thank You: Darium
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
27 Jul 2026 10:04 #348089 by Todd Zuercher
If it is in Master, are there instructions for enabling and configuring the S-curve accelerations?
27 Jul 2026 10:09 #348090 by rodw
There are some Sims. I have not gone looking for docs but I think the ini files etc are well documented
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
27 Jul 2026 10:18 #348091 by Todd Zuercher
I've not looked at Master for some time, I'll have to check it out.
Time to create page: 0.224 seconds
