  • tuxcnc
  • tuxcnc
21 Jul 2026 20:16
Gantry oxyfuel / plasma type machine from scratch
Ethercat is very good for motors, but for slow I/O is only expensive and modbus may be better choice...
  • PCW
  • PCW's Avatar
21 Jul 2026 20:14
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
You can drive small relays with the enable OPTOs
but make sure that the relay coils have flyback diodes.
21 Jul 2026 19:55
Replied by tommylight on topic Gantry oxyfuel / plasma type machine from scratch
I see the board has only one input for the encoder feedback. But I have 3 drives, so should I leave the encoders
signals from the drive to linuxcnc out ?
Yes you should leave them out, as noted above the only usable way for DMM drives is in Position mode as they have a delay in position signal outputs.
Also the encoder input will be used for THCAD if you want plasma.
Or there is a way to connect all 3 encoders to the board ?
Yes there is, Mesa 7i85 or 7i85S should have 4 encoder inputs.
Also has LinuxCNC some settings to make the preheat , and open the various gasses vales at ceartain time already in or should I be doing this from zero up ?
No, not per se, but LinuxCNC can be programmed as you need it, so a simple G04 P1800 will make the machine wait for 30 minutes at the first cut to preheat the material.
Same for outputs and solenoids, everything can be automated and even add a side panel with settings and buttons and stuff.
  • 5_Zylinder
  • 5_Zylinder
21 Jul 2026 19:35
Replied by 5_Zylinder on topic Hurco BMC 30 AP
Hurco BMC 30 AP
Category: CNC Machines
Thanks for the help.I’ve now implemented everything just as Aciera described. The error persists. I think a directory is still missing here?
  • PCW
  • PCW's Avatar
21 Jul 2026 19:30 - 21 Jul 2026 19:31
"7i92+7i76 on P2: SSerial detects board but registration fails with EAGAIN"
May be an introduced PathPilot bug since their hostmot2 driver has been
changed from LinuxCNC's version and Tormach doesn't use any sserial devices.
When the error happens, do you get a red LED illuminated on the 7I92?
  • spicybagel
  • spicybagel
21 Jul 2026 18:38
"Probe Height of the current tool" button not active in versatool
Category: Qtvcp
I don't use that workflow, but the button is also disabled in both my personal config that uses a tool setter and in the probing sim config. There may also be a separate issue even if the “Probe Height of Current Tool” button is enabled. The current BLOCK HT calculation uses the formula origin = float(INFO.INI.find("AXIS_Z", "MIN_LIMIT")) + value. Using the Z minimum limit doesn't really work or make any sense to begin with for me, but even if the machine was setup for that, the formula would only make sense if the probed value was a positive height measured upward from the Z minimum limit.
So doesn't directly answer why the button is disabled, but I can confirm it's not unique to your config and the routine in general is very confusing. Hopefully one of the developers who worked on these routines can clarify why the current BLOCK HT calculation does not produce the expected result and explain what setup or value the routine was originally designed around along with why the “Probe Height of Current Tool” button is disabled.
  • ronthomp
  • ronthomp
21 Jul 2026 18:27
Post this back to the thread — it's a genuinely useful negative result that narrows things down for PCW. Something like:
Ran the stress test as requested:
60000 packets transmitted, 60000 received, 0% packet loss, time 59998ms
rtt min/avg/max/mdev = 0.105/0.112/0.233/0.011 ms
Clean — no packet loss, tight timing. So it doesn't look like an Ethernet dropout issue. I also removed enable_raw from the config string per tommylight's question, but the same EAGAIN/"Ignoring soft error during init" failure persists.
For what it's worth: I've now reproduced this identical failure with two different bitfiles (7i92_7i76x1D.bit on P2, and 7i92_7i76x2D.bit on P1), on two different SSerial channel instances (.0.0 and .0.2). Both boards' modes print correctly (io_spin/io_ana_spin/io_enc_ana_spin_ff) before the same failure. This is on PathPilot 2.14.4 (LinuxCNC 2.8.0~pre1), if that Tormach fork detail matters.
That last paragraph is worth including since it's new information since your original post — the "reproduced across two different bitfiles/channels" detail might help PCW recognize this as something specific to the PathPilot fork rather than a generic hostmot2/hardware issue.
  • PCW
  • PCW's Avatar
21 Jul 2026 17:52
Yes, it's typically used for debugging.
It allows low level register access to FPGA registers.
  • saxa
  • saxa
21 Jul 2026 17:28
Hi NWE, thanks for commenting. Can you share more details on what are you looking for to use for the retrofit ?
  • saxa
  • saxa
21 Jul 2026 17:27
Hi RodW, many thanks for answering. Seems you are telling me to use an EtherCAT Beckhoff module for the THC ?
Should I be using only Beckhoff modules or can I go with any other producer, there is a lot of stuff out there. I was evaluating Triomotion modules for motion controll, IO and Analog IO. The Flexslice series (www.triomotion.com/public/products/flexsliceExpansion.php). Seems they should work with LinuxCNC.
  • saxa
  • saxa
21 Jul 2026 17:20
Hello Tommylight, many thanks for answering. So if I understand well I should not bother with EtherCAT at all for this. I was looking at the Mesa board and seems reasonable to me.
Right now I have a doubt on the encoders signal feedback. I see the board has only one input for the encoder feedback. But I have 3 drives, so should I leave the encoders
signals from the drive to linuxcnc out ? Or there is a way to connect all 3 encoders to the board ?
  • PCW
  • PCW's Avatar
21 Jul 2026 16:50 - 21 Jul 2026 16:59
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
Suggests you have lost Ethernet communications during startup
Could be a network setup issue or perhaps marginal  5V power
that drops out with increased power drain at startup with the 7I76.
What does:
sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
report?    ( It should run for 1 minute then print timing statistics )
( replace 10.10.10.10 with 192.168.1.121 if your 7I92 is jumpered that way )
21 Jul 2026 16:25
`DRIVER_PARAMS`: `board_ip=10.10.10.10 config="num_encoders=1 num_pwmgens=2 num_3pwmgens=0 num_stepgens=5 enable_raw"`
Just a stab in the dark, but, delete "enable_raw" as that is something i have never seen on Mesa parameters, but i am also pretty sure it might just be valid.
  • ronthomp
  • ronthomp
21 Jul 2026 16:10
Hi all,
I'm using Claude ai. And it suggested and composed this message, because I am no coder.
Good call, and yes — I can't actually post to the forum myself (no login, no ability to submit forms there), but I can draft a clear, complete post for you to paste in. Here's one:
**Subject: 7i92 + 7i76 on P2 — "Ignoring soft error during init" then "board fails HM2 registration" (EAGAIN -11)**
Working on a non-Tormach retrofit using PathPilot 2.14.4 (LinuxCNC 2.8.0~pre1) with a 7i92 and a single 7i76. Bitfile is `7i92_7i76x1D.bit`, confirmed via `mesaflash --readhmid` to match the official `.pin` file exactly (5 stepgens, 1 SSerial module, 1 QCount, all on P2; P1 is unused GPIO).
With the 7i76 cabled to **P1**, everything works fine — boots clean, X/Y/Z stepgens register, GPIO pins behave as expected. No SSerial devices show up (expected, since P1 has no SSerial module in this bitfile).
Per the `.pin` file, the 7i76 needs to be on **P2** to access its real field I/O via SSerial. After (removing the ribbon) moving the ribbon cable to P2 (direct pluging to db25) and confirming proper 24V field power + 5V logic power to the 7i76 (jumper on the 7i92 adjusted to supply 5V to P2 instead of P1 — two LEDs now lit on the 7i76 confirming both supplies are good), I get this on every boot attempt:
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
Board hm2_7i92.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i92.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i92.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i92.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2_eth: Ignoring soft error during init
So the board is clearly detected correctly (modes print fine) but registration fails right after with EAGAIN. I've tried:
- Removing `sserial_port_0=` entirely (letting it auto-detect per the hostmot2(9) manpage's note that no config should be needed)
- Explicitly setting `sserial_port_0=0xxxxxxx` (mode 0 for the one channel, rest disabled)
- Full power-cycle of both the PC and the 7i92/7i76 (not just a warm reboot)
- Enabling `debug_module_descriptors=1 debug_modules=1` on the hostmot2 load — descriptors parse fine, same failure point every time
Any idea what "soft error" is actually being ignored here, or what typically causes a valid-looking SSerial handshake to still fail registration with EAGAIN? Happy to post the full boot log if useful.
Thanks!
Feel free to tweak tone/details before posting — and if you want, mention you're happy to run any diagnostic commands PCW or others suggest, since that tends to get faster responses on that forum.
Thanks!
Displaying 2311 - 2325 out of 12538 results.
Time to create page: 0.255 seconds
