  • kb0thn
  • kb0thn
13 Dec 2024 23:37
Servo tuning for an axis that behaves different in one direction versus the othe
Category: CNC Machines
I am not sure what I was thinking this morning, it is x-axis (the 120" long one) that is rack and pinion. y-axis and z-axis are ball screw and are working fine. (most of my work these days has been on MSY lathes and now a tube laser ... it seems every machine in my shop has different axis names ... and then I screw up the simplest axis named machined I own)
I am going to take tommylight's suggestion and give the rack and pinion a good cleaning. And look at if there is anything that could be lose / binding elsewhere in that axis.
  • StoneB
  • StoneB
13 Dec 2024 23:08
Replied by StoneB on topic Xilinx Setup to edit config for 7i92T
Category: Driver Boards
You have the old (G540) package name in your pinout file
While copying the file for pasting I noticed that while I had changed the package name at the start of the file, I had forgotten to change it at the end...
It compiles!! I'll flash it tomorrow
Thank you for all your help!
  • RNZ
  • RNZ
13 Dec 2024 22:23
Replied by RNZ on topic Mesa firmware versions and updating
Hi Behai. I purchased a couple of these cards from the US. I built a CNC around this card and a raspberry pi five. If you want to chat about it, I’m at the top of the South Island.
  • PCW
  • PCW's Avatar
13 Dec 2024 22:14
Replied by PCW on topic Xilinx Setup to edit config for 7i92T
Please post the entire PINxxxx file
  • StoneB
  • StoneB
13 Dec 2024 22:05
Thanks for your patience - I fixed that and I think I'm one last step from success!
I have been checking at least 5 times now, but I can't find where I have a typo in my pins: it says "mismatch on label in pin_slidersfxg_36...
Here's what I have:
constant PinDesc : PinDescType :=(
--     Base func  sec unit sec func      sec pin                    -- external DB25
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 00    PIN 1        Output 2 just GPIO
        IOPortTag & x"00" & PWMTag & PWMAOutPin,                -- I/O 01    PIN 14      Spindle DAC PWM
        IOPortTag & x"00" & StepGenTag & StepGenDirPin,            -- I/O 02    PIN 2        X Dir
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 03    PIN 15        Fault in just GPIO
        IOPortTag & x"00" & StepGenTag & StepGenStepPin,        -- I/O 04    PIN 3        X Step
        IOPortTag & x"04" & StepGenTag & StepGenStepPin,        -- I/O 05    PIN 16       Charge Pump (16 KHz)
        IOPortTag & x"01" & StepGenTag & StepGenDirPin,            -- I/O 06    PIN 4        Y Dir
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 07    PIN 17        Output 1 just GPIO
        IOPortTag & x"01" & StepGenTag & StepGenStepPin,        -- I/O 08    PIN 5         Y Step
        IOPortTag & x"02" & StepGenTag & StepGenDirPin,            -- I/O 09    PIN 6        Z Dir
        IOPortTag & x"02" & StepGenTag & StepGenStepPin,        -- I/O 10    PIN 7        Z Step
        IOPortTag & x"03" & StepGenTag & StepGenDirPin,            -- I/O 11    PIN 8        A Dir
        IOPortTag & x"03" & StepGenTag & StepGenStepPin,        -- I/O 12    PIN 9        A Step
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 13    PIN 10        Input 1 just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                      -- I/O 14    PIN 11        Input 2 just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                       -- I/O 15    PIN 12        Input 3 just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                        -- I/O 16    PIN 13        Input 4 just GPIO
        -- 26 HDR    -- IDC DB25
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 17    PIN 1        PIN 1         Output 2 just GPIO
        IOPortTag & x"01" & QCountTag & QCountQAPin,              -- I/O 18     PIN 2        PIN 14        Input 1 (Quad A)
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 19      PIN 3        PIN 2        Input just GPIO
        IOPortTag & x"01" & QCountTag & QCountQBPin,            -- I/O 20    PIN 4        PIN 15        Input 2 (Quad B)
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 21    PIN 5        PIN 3        Input just GPIO
        IOPortTag & x"01" & QCountTag & QCountIdxPin,            -- I/O 22    PIN 6        PIN 16        Input 3 (Quad Idx)
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 23    PIN 7        PIN 4         Input just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 24    PIN 8        PIN 17        Input just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 25    PIN 9        PIN 5           Input just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 26    PIN 11        PIN 6           Input just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 27    PIN 13        PIN 7        Input just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 28    PIN 15        PIN 8           Input just GPIO
        IOPortTag & x"00" & NullTag & NullPin,                    -- I/O 29    PIN 17        PIN 9           Input just GPIO
        IOPortTag & x"02" & QCountTag & QCountQAPin,              -- I/O 30    PIN 19        PIN 10        Input 1 (Quad A)
        IOPortTag & x"02" & QCountTag & QCountQBPin,              -- I/O 31    PIN 21        PIN 11      Input 2 (Quad B)
        IOPortTag & x"02" & QCountTag & QCountIdxPin,            -- I/O 32    PIN 23        PIN 12        Input 3 (Quad Idx)
        IOPortTag & x"00" & NullTag & NullPin,                        -- I/O 33    PIN 25        PIN 13        Input 4 just GPIO
  • PCW
  • PCW's Avatar
13 Dec 2024 21:15
Replied by PCW on topic Teknic Clearpath SDSK wiring to 7i96s
The enable outputs and input common are still not right
The drive enables could be wired in parallel as there is typically
no reason to drive them separately
Parallel Drive enable wiring could be:
+5V --> OUT0+
OUT0- --> all Drive ENA+
GND --> all Drive ENA-
  • PCW
  • PCW's Avatar
13 Dec 2024 20:42
homing with Phase Z encoder on MESA 7i96s
Tuning/diagnosis will be quite difficult  without using halscope
  • JackRay
  • JackRay
13 Dec 2024 20:34
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
my unit is degrees for a rotating axis. I don't know how to use a halscope.
  • PCW
  • PCW's Avatar
13 Dec 2024 20:11
Set your following error limits wide (1 inch or 25 mm)
and post a halscope plot of the following error when
you do a motion.
  • Teknic_Servo
  • Teknic_Servo's Avatar
13 Dec 2024 20:07
Replied by Teknic_Servo on topic Teknic Clearpath SDSK wiring to 7i96s
Hi fully_defined,
I'm an engineer with Teknic and came across your post. While we're not familiar with the exact board and pinout, the ClearPath wiring makes sense. (Good suggestions PCW)
If you encounter any problems or have other questions, please reach out directly at 585-784-7454 or teknic.com/contact/.
Best regards,
- Aaron B. Teknic Servo Systems Engineer
  • partec
  • partec
13 Dec 2024 20:07
Replied by partec on topic cam_align
cam_align
Category: Qtvcp
but sure, it works exactly as described, thank you very much for now, I'll be happy to test all sorts of things further
  • JackRay
  • JackRay
13 Dec 2024 20:05
Good morning, gentlemen,
I'm coming back to you because even with your advice I can't adjust my encoder. I still have my “joint 3 tracking error” problem. I've made a short video showing how the position of my encoder reacts, as soon as I touch it, I get a tracking error. on the other hand, the scale of my encoder is correct on my B axis display.
My config file are attach .
Could you help me?
Thank you
  • cmorley
  • cmorley
13 Dec 2024 18:37
Replied by cmorley on topic cam_align
cam_align
Category: Qtvcp
This zipped file should work:
  • PCW
  • PCW's Avatar
13 Dec 2024 17:53
Displaying 21871 - 21884 out of 21884 results.
Time to create page: 0.378 seconds
