  • MarkoPolo
  • MarkoPolo
07 May 2026 07:34
Replied by MarkoPolo on topic Qtvcp GUI and hal pins
Category: Qtvcp
To update to master in Debian 12, add an entry to /etc/apt/sources.list
deb buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace
then apt update ; apt upgrade
  • zu4lu
  • zu4lu
07 May 2026 06:10
  • m0602232
  • m0602232
07 May 2026 06:06
Replied by m0602232 on topic LinuxCNC S-Curve Accelerations
I'll attach one simple spiral planing operation gcode file. In my machine this brought up the toolpath blending problems in tp1, I had to roll back into tp0 (haven't tried tp2 though). I could not get the machine to move smoothly, tried different blending settings but no help (tp0 blends this just fine). Unfortunately didn't have time to investigate any further but maybe simulation shows something?
  • rodw
  • rodw's Avatar
07 May 2026 04:02
Replied by rodw on topic HAL component for tangential knife
Category: HAL
Is it tangential?
  • bedouno
  • bedouno
07 May 2026 03:14 - 07 May 2026 03:32
Replied by bedouno on topic HAL component for tangential knife
Category: HAL
can you please refer to the implementation of it and how to use it and configure the z lift angle and z height , or a demo component of the usage like the Mach3 Implementation
07 May 2026 03:14
  • Lcvette
  • Lcvette's Avatar
07 May 2026 02:28
Replied by Lcvette on topic Probe Basic facing no tool selected
Category: QtPyVCP
is this dev venv install or apt system wide install?
  • rodw
  • rodw's Avatar
07 May 2026 01:51
Category: HAL
I'm working on it again today to  ensure it works on XZ and YZ planes and also to prevent a helix being treated as a circle. None of this has any impact on your use case.
  • cmorley
  • cmorley
07 May 2026 01:40
Replied by cmorley on topic Qtvcp GUI and hal pins
Category: Qtvcp
But ye the latest 2.10 (master) branch should have the latest code.s
  • cmorley
  • cmorley
07 May 2026 01:36
Category: Qtvcp
I actually don't know - I always use run-in-place compiled version.
Hopefullt someone else will chime in to help.
  • grandixximo
  • grandixximo's Avatar
07 May 2026 01:14 - 07 May 2026 01:14
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
@papagno-source
Would love to get access to the actual machine, there were no jumps on the test rig even moving windows.
@andrax
Videos have been posted somewhere in the thread already I think, not everyone gets the same thing, some motors do a small click, some grind, like vibrate making a grinding noise, this is during motion.
  • bedouno
  • bedouno
07 May 2026 01:11
Category: HAL
great work , i hope it will be included in the comming version
  • rodw
  • rodw's Avatar
06 May 2026 22:25
Replied by rodw on topic Pierce only and pierce delay
Category: Plasmac
Open the post processor in a text editor. There are some settings you can change which allows QTplasmac to be the master of cut settings.
There is a script included that converts a Sheetcam tool file to QTplasmac format.
  • rodw
  • rodw's Avatar
06 May 2026 22:19
Replied by rodw on topic Brilliant Bambu Lab
Brilliant Bambu Lab
Some of this rubbish is because a company engages a IP lawyer and the lawyer fires off all of these unsubstantiated ambit claims so he can bill his customer.
  • rodw
  • rodw's Avatar
06 May 2026 22:00
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
I don't think a hardware master could be used with Linuxcnc in the present implementation of Ethercat. Choose this option carefully as it might require replatforming.
Displaying 3886 - 3900 out of 12541 results.
Time to create page: 0.271 seconds
