  • bmoo
  • bmoo
02 May 2026 17:16
Replied by bmoo on topic Help wiring G0704 Spindle to Mesa 7i96s
Category: Milling Machines
I have not. I've been taking too long figuring out if I can make a dual loop feedback system and learning I should pause that endeavor for now. Currently working on seeing if this thing can cut a semblance of a part then hopefully spindle control. Will update if I learn anything.
  • dedlefou
  • dedlefou
02 May 2026 17:12
Firmware request : MESA 7I76EU + 7I85 + PWM & IOport
Category: Driver Boards
I got the 7I85 ;)
But I had to buy the S version... My mistake
I'll be fine if the P3 with 1 or 2 pwm and all the others P3 ports as IO if possible ?
  • PCW
  • PCW's Avatar
02 May 2026 16:34 - 02 May 2026 16:37
I'm not clear on what daughter card
you have: 7I85 or 7I85S ?
I can make firmware for either.
  • TheTinkeringMechanic1
02 May 2026 16:17
Replied by TheTinkeringMechanic1 on topic Can't read gcode text in dark mode when editing.
Category: Gmoccapy
System themes have no effect on the gcode editor in the linuxcnc program.
  • dedlefou
  • dedlefou
02 May 2026 15:41
ok I found this firmware corresponding to my card 7I85
forum.linuxcnc.org/27-driver-boards/5823...76eu-7i85-pwm#341493
I should buy the 7I85S :(
  • nighteagle
  • nighteagle
02 May 2026 14:04
  • dedlefou
  • dedlefou
02 May 2026 10:47 - 02 May 2026 13:13
Hi Peter,
I need custom firmware for my amazing 7i76EU with:
- 7i76 daughter for router 5 axes + 0-10V vfd (currently working with 7i76eu_7i76x1_7i85sx1d.bin)
- 7i85 (1 serial, 2 encoder, 4 stepgen) on P1 (currently working with 7i76eu_7i76x1_7i85sx1d.bin)
- 1 or 2 PWM generator on P3 for 20kHz laser control and idealy the rest as I/O port
Can you create such firmware combining all these ? Do you need more info ?
Board IP: 192.168.1.121
Thanks!
  • grandixximo
  • grandixximo's Avatar
02 May 2026 10:28 - 02 May 2026 10:29
Replied by grandixximo on topic MDI Command Error
MDI Command Error
there is no attached file, make sure you have something like this in your INI
[HAL]
HALUI = halui
[HALUI]
MDI_COMMAND = G53 G0 Z-165
also you cannot use the normal hal file, you must put
net ztouch halui.mdi-command-00 <= pyvcp.ztouch
in the hal file that loads after the UI, I think postgui.hal usually, depends on the UI
  • summat
  • summat
02 May 2026 09:05 - 02 May 2026 09:07
Replied by summat on topic 7i76e - Input pin erratic behaviour
Just to close this topic down, having found the enthusiasm to strip the machine down...
So, it looks like every group of 8 inputs is routed through it's own octal analogue mux, with each input circuit comprised a current limiting resistor, a pull-down resistor (essentially a voltage divider) and a capacitor snubber.
That only one input is at fault suggests either the mux (LV4051), or the RC network on each pin, or the pin itself. I've examined under magnification all joints, and reflowed them all, and the problem remains. Therefore I conclude the most probable fault is on the mux, most likely due to user (my) mishandling,
At this stage, remapping the input to an otherwise unused input closes this problem - tested and proven. I thank you all for your earlier replies.
02 May 2026 01:46
Replied by tommylight on topic Can't read gcode text in dark mode when editing.
Category: Gmoccapy
This is on Mint 22.3 with Mint-L-dark theme, notice the text on the left is clearly visible, on any other black theme no text can be seen there.
And this is not limited to LinuxCNC, many other programs i use daily had the same issue before so i had to revert to bright themes when using them.
What GUI are you using?
I know Axis can be modified, and so can the QT versions.
You can also try to install Mint themes in Debian, or Ubuntu themes. See also Ubuntu Studio as they do have some very nice themes, but forgot what they use as DE.
  • COFHAL
  • COFHAL
02 May 2026 01:37
QTDragon_hd with mechanical dial tool setter
Category: Qtvcp
I have a silly question: how do I install this version to replace the original one that comes with LCN?
02 May 2026 01:29
Category: Gmoccapy
Changing any of the colors in Debian settings has no effect on the editor in linuxcnc. That's why I'm here.
02 May 2026 01:22
Category: Gmoccapy
1. that is not a LinuxCNC issue, so Debian forums are a much better place to ask
2. i had the same issue on Linux Mint when using the included dark themes, but 22.3 added new dark themes that fixed the issue.
3. you can try fine tuning colors for the dark theme, for text mainly as that worked on Mint so should also work on Debian.
02 May 2026 01:14
Can't read gcode text in dark mode when editing. was created by TheTinkeringMechanic1
Category: Gmoccapy
I'm having an issue that I couldn't find a solution that worked. I prefer Adwaita Dark theme. Everything is fine that is when I go to edit a gcode file in linuxcnc, the text highlight washes out the text. See image:
During my search I have found a script to add to the user command file, it just seems to crash when it tries to load. I have attempted to change the editor in the INI from gedit to mousepad, heck, I can actually leave it blank and it still changes nothing. I have changed the theme to use the system settings, still no change. The only way I can get this to where I can read the highlighted text is to change out of dark theme which isn't ideal. I'm sure there's a solution, I just haven't found one that works. Anyone else find a fix for this?
  • COFHAL
  • COFHAL
02 May 2026 01:12
Replied by COFHAL on topic Qtvcp GUI and hal pins
Category: Qtvcp
Indeed, with Linuxcnc version 2.10, the HAL Bridge works and the Bridge pins now appear. Interestingly, in the QTDRAGON configuration examples, the macros and MDI-Command-macro are defined in the ini file, but the instruction HALBRIDGE=hal_bridge is not defined in [HAL]. It would be good to update the configuration to include it.
Displaying 4021 - 4035 out of 12541 results.
Time to create page: 0.740 seconds
