  • jjdege
  • jjdege's Avatar
25 Apr 2026 08:59
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
What you're doing is fantastic. The installation is going well.
The simulations show great potential. Congratulations!
If I may make a point, looking at the video, I think it's better if the horizontal drilling unit
descends when it reaches its position. In the video, you can see it descending and then reaching its position.
That's just my opinion.
Thanks and congratulations again!
  • axemas
  • axemas's Avatar
25 Apr 2026 08:14 - 25 Apr 2026 08:15
Category: NativeCAM
Hi everyone,
I’ve just uploaded a short demonstration of the NativeCAM (Python 3 / GTK3) port running on an industrial CNC machine. In this video, you can see it handling horizontal drilling operations smoothly.
The port is stable and performing well in a real workshop environment on LinuxCNC 2.9 / Debian 13.
Live demonstration: www.youtube.com/shorts/RL7QDfig8vQ
You can find the updated code here:
github.com/cnc-proton/nativecam-py3-gtk3
Feedback and testing are welcome!
  • aaronstone
  • aaronstone's Avatar
25 Apr 2026 08:08
Replied by aaronstone on topic Kinematics for XYZAB mill
Sir, I think that site has not been working for more than a year. If you need old pages or PDFs, those URLs may help you.
web.archive.org/web/20260000000000*/https://sa-cnc.com
github.com/Tpj-root/Linuxcnc_Kinematics/tree/main/Back_Up
  • sns5400
  • sns5400
25 Apr 2026 07:36
Replied by sns5400 on topic Kinematics for XYZAB mill
Hello, i try the source you describe sa-cnc.com but none of these are available
Maybe something is changed.
Is new information available
Thank you in advance
  • endian
  • endian's Avatar
25 Apr 2026 05:59
Replied by endian on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Difference between 00 and 01 is bug at master/slave layer... If you will map everything at 00 it will works just few IDNs and main number of then will produce mess .. i do not know why it is that but its the fact ..
Second bug what many year ago was reported by @bkt or other skillfull user was that not supporting stuff mapping pdo is present and and mailbox is not changing... But it was fake data because main volume this ax5 have mapping pdos ON if an EEPROM does not tell you else....its just forgoten message from early days
I think its correct you can add other slave to your TC3 project.. give them naming with string length less than 16 chars and it will works well
Post command + output of you situation then here I can check it..
Thankfully we have that translator and its save anybody non nerdy in lcec one half life.. because I lost it too
24 Apr 2026 19:37
Replied by tommylight on topic JetCad3 CAD/CAM
JetCad3 CAD/CAM
Category: Show Your Stuff
At least there is something free with the added explanation on how to maximize the use of that free version, so thank you for that.
24 Apr 2026 19:30
Replied by tommylight on topic Tried Twice to start a thread, Failed
Category: Forum Questions
First post by new members must be approved by an Admin or Moderator, to prevent spam.
  • snowgoer540
  • snowgoer540's Avatar
24 Apr 2026 19:06
Replied by snowgoer540 on topic JetCad3 CAD/CAM
JetCad3 CAD/CAM
Yet another CAD/CAM software with a paid monthly subscription.
No thanks, I'll take my candid feedback to FreeCAD and try to escape this endless loop of monthly subscription software.
You realize you're talking to an open source community, right?
  • milhead
  • milhead
24 Apr 2026 18:52
Tried Twice to start a thread, Failed was created by milhead
I've taken the time twice to start a thread in LinuxCNC Install for my PC/Mach/Paralled to Pi5/LinuxCNC/Mesa conversion but both have disappeared after I submitted them?
Am I doing something wrong?
  • milhead
  • milhead
24 Apr 2026 18:41
Jumping In! Replacing my 20 year old PC with a Pi5/LinuxCNC/Mesa 7C81 setup
Category: Installing LinuxCNC
Hi Forum;
I went to use my CNC Router the other day and the cobbled together controller has give up.. Won't even boot after a few kicks and wiggles...
So I've put together a Raspberry Pi LinuxCNC controller with a mesa board to squeeze into the old PC location.
I've gotten  the Pi5/LinuxCNC all running off the boot image but just yesterday received and added the Mesa 7C81 I/O board.
It's assembled and powers on, now I just need to figure how to connect the Mesa I/O to the outputs from LinuxCNC.   I guess it's time to read.
If anyone has a good 7C81 configuration page they can refer me to I'd appriciate it.  Ive just started and am not stuck yet but love a good example to follow.
Adventure Awaits!
My second machine build log, If you want a good laugh and have time to waste that you will never get back
www.cnczone.com/forums/cnc-wood-router-p...t-log/35355-cnc.html
  • travis.gillin
  • travis.gillin
24 Apr 2026 18:29
JetCad3 CAD/CAM was created by travis.gillin
JetCad3 CAD/CAM
Hi everyone,
I’m building JetCad3 — a native parametric CAD and CAM application for people who design and cut real parts. The goal is a serious design tool with full 2D/3D modeling, sensible exports, and practical CAM for sheet cutting, without locking you to one vendor’s cloud or one OS: JetCad3 runs on Windows, macOS, and Linux. More about the project: jetcad.io
Right now there are two workspaces you can use end-to-end. The system is ready for daily plasma use, I've actually been using it for a few years in my shop as I've been at this for quite some time before making it publicly available.
Drafting (CAD)
Full 2D parametric sketching and 3D solid modeling (extrude, revolve, sweep, helix, and friends), re-editable feature history, assemblies / multi-body workflows, and the usual import/export you’d expect for fabrication and printing — e.g. DXF/SVG for flat patterns, STEP/STL/3MF for solids. There’s also a parametric geometry generator for common mechanical parts (gears, sprockets, pulleys, splines, etc.) so you’re not always redrawing the same primitives from scratch.
Plasma CAM
Toolpath generation tuned for plasma tables: arc-preserved G-code (G2/G3), kerf compensation, lead-in/out, pierce delay, feed/speed controls, auto-nesting (several effort levels), and cut simulation with a live DRO-style view so you can sanity-check the program before it hits the table. If you’re already on SheetCAM or Fusion 360, there’s an AI-assisted post processor converter: paste your existing post, get something native to JetCad3 you can iterate on — handy if you’re comparing workflows or migrating gradually.
Laser CAM (roadmap)
Laser CAM is not shipping yet, but it’s a major focus. The plan is to cover CO2 flat-bed style cutting as well as fiber galvo workflows — different kinematics and process assumptions, so they’ll be treated as first-class paths rather than a single generic “laser” mode bolted onto plasma.
Why I’m posting here
A lot of LinuxCNC users live at the intersection of Linux on the shop floor, real G-code, and actually cutting parts. I’d like to find a small group who are interested in trying JetCad3 seriously — running real jobs, pushing edge cases, and giving candid feedback.
Testers would be marked Staff on the JetCad3 community forum, with free access to all current JetCad3 features for as long as they want to stay in the testing group (no fixed end date tied to “please churn out bug reports by Friday”). In return, I’m hoping for honest reports: what works, what breaks, and what would make the tool fit your workflow better — especially on Linux and with plasma (and later laser) in the loop.
If that sounds like you, reply here and mention roughly your setup (OS, table/controller if you’re comfortable sharing, and whether you’re more CAD-heavy, CAM-heavy, or both).
For anyone that's not really interested in being a tester but may be interested in trying out JetCad3 on their own time, there is Free / Hobby use available. You simply download from the website for your preffered platform (Window, Linux, or Mac OS) and click Free / Hobby at the sign-in window (No account creation required) in the desktop app. In the Drafting workspace that limits to one Component with up to 5 Sketches. In the Plasma workspace, you're limited to 500 lines of posted Gcode but you can Auto-Nest across multiple sheets, then post out one or two parts out at a time (to stay under 500 lines of gcode) to complete a large nest cut on your CNC plasma machine. If you feel the system has potential for your workflow, I'm offering 30 day free trial. The trial DOES require credit card input when signing up for the trial but you always have the option to cancel before getting a charge if you change your mind, this is just to keep trial abuse down to a minimum.
Thanks for reading — and thanks to everyone who keeps the LinuxCNC ecosystem moving; it’s a big inspiration for building JetCad3. I've used LinuxCNC for the better part of 12 years from everything between mill & lathe retro-fits to both new CNC Plasma and Fiber laser machines that I used to build for a living.
  • stirra
  • stirra
24 Apr 2026 17:30
Replied by stirra on topic 4 axis foam cutter configuration
Category: AXIS
I ended up using a bottle of water as a weight, with the wire fixed at one end and a pulley arrangement for the moving end. I used polished wire nozzles used for wire winding machines to guide the wire without fatiguing it. Do not try to use MIG welder wire nozzles, as they will break the wire very quickly.  I built the machine for a university lab, but I don't think they have used it very much since, so long term reliability is untested.-- Ralph
  • COFHAL
  • COFHAL
24 Apr 2026 16:56
Replied by COFHAL on topic Qtvcp GUI and hal pins
Category: Qtvcp
Thanks for you support.
I've already installed the python3-zmq package, but it's not clear to me how to include a macro. Could you help me with an example to complete it?
MACRO=
MACRO=
And how to connect these macros to an external button
24 Apr 2026 15:13
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Seems like encoder failing to count at higher speeds, might be interference, or encoder slotted wheel dirt/rust, or encoder input lagging, or encoder outputs marginally low output.
I have also seen a perfectly good encoder counting on one direction, and one channel going all wonky on the other direction, it was new so i returned it without the chance of figuring out what was wrong with it.
  • Dudelbert
  • Dudelbert
24 Apr 2026 14:44 - 24 Apr 2026 14:53
Category: Turning
I had time to test some more today.
Let me start with a big thanks for the great, helpful feedback.
I started trying some runs with G33. Multiple runs with the same settings resulted in only one tool mark.
Increasing the RPM did in fact result in a slightly lagging toolpath (cutting on the right side of the insert).
This was not very pronounced, even between 100 and 900 RPM the difference was visible, but not more than a few tenths of a mm.
At 2000 RPM, the new tool marks were close to the middle between the earlier ones. But I don’t really intend to thread at 2000 RPM anyway.
Going back to G76, but with Q, H, E, and L all set to 0, gave me my first nice thread.
Reintroducing Q29 still gives a nice thread and cuts on the left of the insert, as one would expect.
H2 also still worked, and after that E0.75 but L0 gave the same good result.
So only L2 was left, and I am now using the same G76 line as before, so this has to be the problem.
But no it also cuts fine.
At this point, I am uncertain if I should be happy that I can cut threads now or worried that I have no idea what was wrong until now.
I cannot think of anything I changed in between.The only thing is, I had a look at the belt connecting the spindle to the encoder.
I had this apart and inspected, checked the belt (nothing notable to see), and put it back together. I don’t think that should have changed anything, maybe slightly different belt tension?
Displaying 4201 - 4215 out of 12541 results.
Time to create page: 0.258 seconds
