  • papagno-source
  • papagno-source
21 Apr 2026 07:44
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
Good morning everyone. I would like to do more. I can make an image of my HD and put the image somewhere, made with Clonezilla or other software. Luca, I will contact you, so you can give me a link to support the image. While you have Debian 13, so you can try it on your system. In the meantime, today I will try your patch and try to scale the I/O peripheral, the last one on the bus, and if it still doesn't work, I will change PC.
  • Spezidrohne
  • Spezidrohne
21 Apr 2026 06:55
Need help transitioning from axis XYZ to XYYZ
Category: Basic Configuration
Hello,
I dont know, if i am in the right folder, but it seemed like the right one. If not, just move the topic.I have already now managed to get my ethercat servos and i/o running, with 3 motors for XYZ. Now that i have everything running, i want to finally add my second motor on the Y axis for my Gantry setup. Connecting the joints with the ethercat is no problem. But if I go in the ini, add joint_3, set the joints =4 and rewrite the coordinates = X Y Z to = X Y Y Z, and start the machine, i get an error, that my joint_3 min and max limits does not match with the min and max limits on the Axis A. but i dont have an A Axis set up. I guess it wants to merge the Joint_3 with the A Axis, but thats not set up. As far as I understand,  with XYZ it is mapped the following: Joint_0=X Joint_1=Y Joint_2 =Z. Then when i go with XYYZ it should be the following: Joint_0=X Joint_1=Y Joint_2=Y Joint_3=Z. But somehow it is: Joint_0=X Joint_1=Y Joint_2=Z Joint_3=A? Is there somewhere else except the .ini where i need to join the Joints with the axis? what else do i need to change/set up? I started with the sim Axis mm. If i need to post any files, tell me.
I also managed to crash my PC, when starting LCNC. After double clicking the icon, nothing happened, and after like 30s the whole PC froze. After digging around in my changes, i saw that i wanted to change the number of joint from 3 to 4, but forgot to put 4. so it was accidentally left blank, like this: Joints =
If that helps anyone, here you go.
  • Surmetall
  • Surmetall's Avatar
21 Apr 2026 06:48
Replied by Surmetall on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Thanks for your quick reply. It is very possible that I made a mistake somewhere.For some reason, I am unable to create and download the ZIP file using the button in the top right. Is this the correct link? I get an error message whenever I try to generate and download the ZIP. Is this the correct link: codeberg.org/endian/twincat3_to_lcec_eth...ator/src/branch/main Because of that, I used AI assistance to download the data via the terminal instead. There is a high chance that something went wrong during that process.I will redo everything from scratch this evening: download, export, and convert it again, just to make sure nothing is going wrong on my end.I do feel a bit bad about it. There is now such a great configurator that makes the whole process manageable even for beginners, and I still somehow managed to get it wrong. Apparently there is always a dumbest possible user, and in this case, that would be me. :'(
  • grandixximo
  • grandixximo's Avatar
21 Apr 2026 02:42 - 21 Apr 2026 02:54
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
I tried, no much difference, and there should be almost none, the "bug" was more cosmetic, not really hindering OP time, if anything we are talking in the milliseconds range, no human perceivable difference.
OP time is not immediate with DC, can you time how long it takes? If the wait is excessive, there may still be something I have not found.
Would love to get remote access on the debian 10 and debian 13 setups, to compare, get that USB to ethernet adapter please, you are the only one that has both quick and slow OP, and I could compare what the drives and lcec are doing.
21 Apr 2026 02:13
Replied by tommylight on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Mods - please mark as 'solved'
Done, thank you.
  • spumco
  • spumco
21 Apr 2026 01:47
Replied by spumco on topic (Solved) FlexGUI - Multiple spindles?
Category: Flex GUI
Looks like JT updated FlexGUI for multiple spindles on GH a few hours ago.
Can't wait to update and have a go at it!
  • ihavenofish
  • ihavenofish
21 Apr 2026 00:37
Replied by ihavenofish on topic Leadshine L7 / L6 servos
Category: EtherCAT
thanks, the EC is a much older version of the drive. these are L7N
So i'm not sure if the settings translate, but its a start. :)
  • Rookie0
  • Rookie0
21 Apr 2026 00:29
Replied by Rookie0 on topic Leadshine L7 / L6 servos
Category: EtherCAT
  • Marko 87
  • Marko 87
20 Apr 2026 23:38
5-Axis BC Head Router – LinuxCNC Kinematics, TCP and Hardware
Hello everyone,
I’m working on an unfinished DIY 5-axis CNC router project with a BC head. The machine was originally built by a company but never fully completed, and it has been sitting unused for about 2 years. It never achieved proper simultaneous 5-axis operation.
The current setup is based on Mach3, without TCP/RTCP, so true 5-axis machining is not possible.
Machine configuration:
X, Y, Z + B, C axes
Stepper motors with encoders on all axes
Dual motors on the Y axis (gantry configuration)
BC head driven by stepper motors with gear reduction
Total: 6 motors
I’ve decided to rebuild the control system properly from the ground up using LinuxCNC.
At this stage, I’m trying to define the correct approach:
What is the recommended kinematics setup for a BC head machine?
How is TCP typically implemented in LinuxCNC for this configuration?
Are there example configurations I should study?
Hardware side:
What Mesa configuration would be appropriate for this setup (6 motors, dual Y, encoders)?
Is something like 7i95T sufficient, or would another combination be more suitable?
My goal is to build a stable and correct 5-axis system, based on a proven approach.
Any advice or pointers would be greatly appreciated.
Thanks!
  • ihavenofish
  • ihavenofish
20 Apr 2026 23:33
Replied by ihavenofish on topic Tuning Steperonline A6 Servos
Category: EtherCAT
If all you did was autotune, you aren't done.
You need to set the feed forward. Also set the in position error allowance.
What could be happening is that 2 or 3 microns is still within the drives set error, so it just doesn't move.
  • ihavenofish
  • ihavenofish
20 Apr 2026 23:25
Leadshine L7 / L6 servos was created by ihavenofish
Category: EtherCAT
So I have some L6 and L7 servos coming to evaluate for including with my machines. My understanding these are *mostly* the same as the EL6/EL7 models on their website, just OEM and 1/3 the price.
One notable difference is the 24 bit encoder on the L7.
Anyone set these up in linuxcnc? Issues? Success?
  • dm17ry
  • dm17ry's Avatar
20 Apr 2026 21:31
Replied by dm17ry on topic Yaskawa Mechatrolink 3 connect
Category: Driver Boards
got myself an sgd7s mechatrolink-iii drive... tried to talk to it. although it's basically a 100base-tx ethernet, they are not using ethernet 802.3 headers. and worst at all - they violate the 60 byte minimum frame length. by 4 bytes :) i was able to convince Zynq MAC to transmit short frames by turning off FCS offload. i can see the drive answers, but they get dropped and there's no way to receive them.
NICs on linux PC are no better.
so the only way to do it with Zynq is to implement a custom ethernet MAC in PL.. unfortunately my board has PHYs connected to PS pins, so i can't do it. will try again with another board...
  • endian
  • endian's Avatar
20 Apr 2026 20:07
Replied by endian on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
Are u using current version of translator?
Because I can clearly see subindexes of pdos are 0x00 instead of 0x01 which is clear issue to me l...
Download latest translator version and try export again.. versions before were buggy
Check it or edit it manually(fastest) and let me know
  • axemas
  • axemas's Avatar
20 Apr 2026 19:46
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
"Hi everyone,
Thank you all for testing the port and providing feedback! I've just pushed a few fixes to the repository (including the INI parsing errors and GTK deprecation warnings). github.com/cnc-proton/nativecam-py3-gtk3...vecam_2.0b-4_all.deb
Regarding Bug Reports:
As more people start using this port, it becomes harder to track individual errors and logs across forum pages. If you encounter a bug, a crash, or a specific error message, please report it via GitHub Issues here: github.com/cnc-proton/nativecam-py3-gtk3/issues
The forum is still the perfect place for general discussions, sharing ideas (like the Lathe Polyline!), and showing off your work. But keeping the technical bug reports on GitHub allows me to solve them much faster and keep the project organized.
Thanks for understanding and for your continued support!"
  • jetbadger
  • jetbadger
20 Apr 2026 19:25
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
I've tried that too. Now I've noticed that I have pid.c.feedback-deriv connected. Maybe getting rid of it will help, Guess I'll try that next.
Displaying 4306 - 4320 out of 12541 results.
Time to create page: 0.461 seconds
