  • JacobWnavy
  • JacobWnavy
09 Apr 2026 14:00
Ethercat, CIA402, Yaskawa Sigma-X was created by JacobWnavy
Category: EtherCAT
Hello Everyone,
I have been working with LCNC for a couple of years now, but I am just now entering the forums. I am currently struggling to solve a CIA402 and Ethercat issue. I have set up Yaskawa Sigma-X servo packs using the CIA402.comp by  dbraun1981  and Ethercat Lcec. My problem is that on startup, the servo packs will transition through preop -> safeop -> op, but after sending the servo on control word one or more of my servos will drop to preOP or preOP E. I can fix this by sending the EtherCAT states OP command in the terminal and trying again. Sometimes I have to repeat this process 4 to 5 times before they all hold the OP state. I am thinking that it is related to distributed clocks or something along those lines. I was able to temporarily resolve the issue by setting the Sync Error counter limit to 0 (Disabled). I would like to use the Sync Error counter as intended, so if someone knows how to fix the desync issue on startup, that would help me out a lot.
09 Apr 2026 13:35
Replied by tommylight on topic Crash on loading large file
Search the Debian forum/website for "how to enlarge swap space" and make it at least 8GB or 12GB or whatever you can fit.
  • amanker
  • amanker
09 Apr 2026 13:27
Crash on loading large file was created by amanker
I was trying to load gcode file for small engraving of size 200x150mm, gcode file size is 243MB. I tried qtdragon_HD and Axis GUI both crashes while loading the file. Even I tried disbling preview by adding (AXIS,hide) at start of GCODE. But didnt helped. Using Raspberry PI 5, 4GB RAM version.
  • grandixximo
  • grandixximo's Avatar
09 Apr 2026 11:58 - 09 Apr 2026 12:13
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
With ec_igb or ec_igc native driver: interrupt moderation is irrelevant, they use polling not interrupt.
With ec_generic: interrupt moderation is active and you should disable it with
ethtool -C <iface> adaptive-rx off rx-usecs 0 tx-usecs 0
probably as soon as possible on boot, before ethercat starts.
To know which drive you are using, check your erhercat.conf file
  • m0602232
  • m0602232
09 Apr 2026 11:11
too long hm2_7i97.0.read.tmax or something else?
Category: Driver Boards
Just in case anybody has to deal with similar problems:
I had to investigate a bit further since the spiking came back, but I think it might be working now. The spiking indeed was graphics related, this thread is slightly misplaced now but anyway.
Software rendering seems to work the best with this hardware:
LIBGL_ALWAYS_SOFTWARE=1 QT_OPENGL=software MESA_LOADER_DRIVER_OVERRIDE=llvmpipe \
So OpenGL Mesa this time, not the usual Mesa:)
I don't know if it is a good practice to use software graphics but I'm open to suggestions.
  • andrax
  • andrax's Avatar
09 Apr 2026 10:46
Replied by andrax on topic Ethercat random jitter fix
Category: EtherCAT
I found another clue.
A Google search for "Intel NIC interrupt moderation" yielded the following advice: this should be disabled, as it can also lead to jitter.
The Cause of Jitter: When enabled, the time between packet interrupts varies depending on traffic flow (sometimes fast, sometimes slow), causing inconsistent packet processing times.
That would at least be worth investigating.
  • Todd Zuercher
  • Todd Zuercher's Avatar
09 Apr 2026 10:15
Help me use two 7i96s in Ethernet switch to control 6 joints
I know you already have two 7i96 cards, but perhaps using only one of them with a 7i78 daughter card connected to the expansion port of the 7i96 might be a better option than the two 7i96 cards to get extra stepgen outputs?
Did you change the IP address on one of the 7i96 cards so that they are not the same? Set the first as 10.10.10.10 and the second as 10.10.10.11. You have to use the Mesa flash utility to set the address on the card. Set the static IP for the nic on your Linuxcnc PC to 10.10.10.100 (or something other than 10.10.10.10 or 10.10.10.11 but in the same range.)
I believe you can use a switch, but the switch and the PCs ethernet port need to be dedicated only to this use. If you want to also have an ethernet network/internet connection you will need a second nic on the pc for that.
Here's a thread with instructions from Peter at Mesa
www.forum.linuxcnc.org/38-general-linuxc...sa-7i92-via-ethernet
  • DerKlotz
  • DerKlotz
09 Apr 2026 09:21 - 09 Apr 2026 10:53
When I implement a handwheel, the milling motor stops spinning
Hello,
When I implement the XHC-WHB04B-4 handwheel in LinuxCNC, my milling motor no longer receives a speed command via gcode file or mdi command.
I had to remove some commands from the *.hal file to prevent errors from occurring at startup. My files are attached.
  • NWE
  • NWE's Avatar
09 Apr 2026 04:16 - 09 Apr 2026 04:35
Replied by NWE on topic MotionMaster Upgrade
Am I understanding correct your brushed DC servo motors are 140 volts? That leads me to think your analog servo drive is likely designed to operate on 120V power. 120VAC rectified to 170VDC is plenty good.
If the analog servo drive uses a bridge rectifier, then, no, you cannot connect negative to ground. You will have smoke and sparks. Unless it is powered by an isolated 120VAC source (some do it like that) Then they sometimes ground the negative side. I would check how it was wired and keep that the same.
More detailed photos of the servo drives would help a lot.
Your power-up test might get more realistic results if you leave the servo motors wired to the drives and rather mechanically uncouple the motors from the axis drive-train to avoid run-away accidents. 1.5 volts DC should be perfect for the speed command test. If your servo drives have good speed regulation, trying to do this without a motor wired to it would cause it to either go full power or fault because it did not receive speed feedback from the motor.
  • georgio
  • georgio
09 Apr 2026 02:43
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
Category: Installing LinuxCNC
I have got my repaired 7i76eu board returned from Mesa, Thanks again Peter. I have all the limits and estops showing now on Hal show and they are working correctly. I try to home all or jog and the machine just vibrates and shacks until I hit the estop. I have checked everything I can think of. Except for the inputs for limits and estops etc that weren't working before I could get the machine to move, now I can't???? Everything was hooked up as it was before I don't think anything has changed.
  • motionmasterupgrade
09 Apr 2026 01:28 - 09 Apr 2026 01:58
Replied by motionmasterupgrade on topic MotionMaster Upgrade
Yes. I shelved this idea. The faceplate on the VFD made it quite clear that it isn't going to take 240. I have a buckboost to take 240 to 272. Hoping that this will give me enough power for the analog drives. Will use 240V single phase to power a VFD for a much lower HP spindle. Will also use 240V single phase to power any additional drives. Not super sure exactly which MESA setup I'm going with yet. Have to confirm that the analog drives are good first. I was wondering if I could just hook up the 10V to a 1.5V battery and make the drives move the steppers.
- I'm going to first disconnect the brushed servos from the analong drives. Power leads, encoders, everything.
- I guess I can first check the DC bus this by sending in 120V. This should give me close to 170VDC.
- If math serves me right, the DC bus should be 390V rectified with the single 277V leg. With my transformer, it should be 385V. Wondering if the drive cares whether the negative leg of the DC bus input is tied to ground. If it does matter, I'm not sure how to proceed from here. Not exactly sure how to check.
- From here, I am guessing that connecting a 1.5V battery to the drive "should" make the drive send out a tiny bit of the DC bus DC voltage. Since I'm not connecting it to anything, i should be fine.
Will try to understand more from first principles but most appreciate any pointers.
  • rdtsc
  • rdtsc's Avatar
09 Apr 2026 00:23
rpi5/Trixie and many PyQt6 messages about QPalette
I thought maybe I could be missing some package, so searched apt for things which might be related to Qt and platform theme, and found that only qt5-gtk2-platformtheme was installed - none for qt6.  So then I tried installing qt6-xdgdesktopportal-platformtheme and qt6-gtk-platformtheme but neither made any difference.  So this appears to be more involved than initially suspected.
  • spacemanspiffee
  • spacemanspiffee's Avatar
09 Apr 2026 00:14 - 09 Apr 2026 00:17
Probe Basic and XHC-WHB04B-6 jogging issue was created by spacemanspiffee
Category: QtPyVCP
Hi all, I'm working on moving from an older (Linuxcnc 2.8) Axis config to a Probe Basic config after getting a new spindle for my router.
I have successfully gotten the basics working and have even gotten the ATC functions mostly where I want them. (Huge thanks for the the starting point that is the Probe Basic screen set and all the macros)
I am running into trouble integrating my XHC-WHB04B-6 pendant. It works just how I want it to in the old Axis configuration, and in fact that configuration runs just fine under Linuxcnc 2.9 and the pendant works in that config.
However, in Probe Basic the pendant produces stuttery motion when jogging both in step mode and in continuous mode. It also will not register all pulses or clicks of the jog wheel when the wheel is spun quickly. If I slowly click the wheel in step mode (say 1 click per second) I get each step translated into machine motion, but if I quickly spin the jog wheel, I will only get a small fraction of the wheel clicks actually translating into machine motion.
General info:
-  What Linux OS being used including kernel type?
> Debian GNU/Linux 12 (bookworm)
> Kernel version: 6.1.0-44-rt-amd64
-  What version of Linuxcnc is installed?
> 2.9.8
-  What version of QtPyVCP and Probe Basic is installed?
> Probe Basic version: 0.6.6
-  How did you install Probe Basic? Quickstart guide? Dev Guide?
> Probe Basic APT stable install following the guide here: kcjengr.github.io/probe_basic/index.html
-  Have you gone through your ini and hal files and compared to the sim config files to make any changes needed?
> Yes, Probe Basic is functioning, just the integration with the pendant is giving me headaches
-  Have you added all of the necessary files in your config folder that probe basic needs to run?
> Yes
I attached the hal files ini files and pendant hal files for the two configs. (note i renamed the pendant.hal file for the Odroid config so that there were not two of the same file name)
Please take a look and let me know if more info will make the problem easier to diagnose.
Thanks!
08 Apr 2026 22:53
08 Apr 2026 22:51
Replied by tommylight on topic Water depth, slats, and underwater cutting
Category: Plasma & Laser
Rod, i refrained from giving up such info.
Displaying 4741 - 4755 out of 12541 results.
Time to create page: 0.377 seconds
