  • PCW
  • PCW's Avatar
19 Mar 2026 16:12
Differential encoder hard crashes the PC MESA7i77
Category: Driver Boards
lspci did find the card but mesaflash does not, that may indicate a bad 6I25
There are no LEDs illuminated on a 6I25 in normal use except very briefly at power on.
  • dm17ry
  • dm17ry's Avatar
19 Mar 2026 16:08
Replied by dm17ry on topic Mitsubishi SSCNET
Mitsubishi SSCNET
Category: Installing LinuxCNC
and some more cross-generation mating... :) the MDS-E-V2 drive (2024) happily talking to the MDS-A-CR (1995) power supply without any persuation...
  • dm17ry
  • dm17ry's Avatar
19 Mar 2026 16:03
Replied by dm17ry on topic Mitsubishi MR-J3-XX"A" drive + 7i94 config?
X2 goes to the FPGA, for whatever expansion i may need. 4 diff pairs + ~40 single ended lines. for now i have a mezzanine board for old MR-S servos and another for interfacing meldas 6 base board...
yes, a combo... SV2 has 9 bidirectional RS-422/485 pairs. can be directly plugged MR-J/J2/J2S-B or MDS-A/B/C1/R-V/SP drives. or generate step/dir pulses. or read abz/serial encoders. whatever...
19 Mar 2026 15:52
Replied by tommylight on topic Sudden - Strange behavior of arcs
Picture of the result?
  • kmeld
  • kmeld
19 Mar 2026 15:46
Sudden - Strange behavior of arcs was created by kmeld
I have this strange problem since today. Everything was working fine when I was last using the machine.
today I noticed that G2 and G3 for full circles gives me holes elongated in X.
I was trying to do 25mm in diameter hole and it ended up being 25 along Y and 26 along X.
When I was using the machine before (approx 2 weeks ago) I was using the same program and result was circular.
I was looking for some mechanical cause, like something getting loos, but found nothing.
I checked the same program on two very different feedrates 2400 and 300 to check for any inertia driven causes.
I checked backlash on X, and it came back normal, around 0,02.
I am puzzled.
Any suggestions?
Cris.
  • Xnke
  • Xnke
19 Mar 2026 15:29 - 19 Mar 2026 15:35
Awesome. I figure by the time you have a good stable software, I might have a Y axis to hook up. I have to get the wire wheel into the column of the Z axis today and un-rustify it, so I can add in the new stiffeners and get it ready for heat treatment.
(I did kinda start this mess in 2020, and it's now 2026...)
EDIT: What's the X2 connector on the back side of the board for? And is this ethernet card a combo copper/fibre interface? Just looking at what the latching connector at the bottom of the top side, and that it looks like CN1 on some of the MR-J2 drives.
  • Spezidrohne
  • Spezidrohne
19 Mar 2026 14:58
Replied by Spezidrohne on topic StepperOnline A6 Servo
Category: EtherCAT
Thanks for the reply, but im still too dumb to integrate just these files. It just won't work. Can anyone guide me through this? What doch i have to do with these files? All i have done so far is to create a sample from the Premiere Samples and put the 3 files into the folder. Should i even call the Basic.hal from the axis.ini file? What am i doing wrong?
  • dkj4linux
  • dkj4linux
19 Mar 2026 14:40
Remora RP2040-W5500 — immediate joint 0 following error on first move
I'm an old retired engineer with limited LinuxCNC understanding trying to get @scottalford75 's Remora RP2040-W5500 project working.— and am now getting immediate joint 0 following error on first move (command ~125) after successful runs, low spike filters, W5500-EVB-Pico.
With Grok's help, I had this working reliably a couple of days ago... running full logo G-code and longer files to completion without errors. This was probably with unrealistic relaxed settings, however... just trying to get it running in the Axis visualizer.
After some tuning attempts and reflashes, it now fails immediately on the first G0 move with "joint 0 following error" at command 125, even with:
- SCALE = 38.5 (X/Y), 200 (Z) — proven on Grbl/FluidNC
- Acceleration set to 0 in [TRAJ]
- FERROR = 15+, MIN_FERROR = 1.5
- G61 exact path mode
- Clean reboot, minimal background, performance governor
- remora.status = TRUE, spike filters very low (~500-700), read.time stable
Tried:
- Full flash_nuke + both available .uf2 files from repo
- Re-upload config every time
- Power cycle Pico 60+ seconds
Halshow shows stable polling, no high spike filters, but pos-fb lags immediately on first move.
I've attached my .ini, .hal, and config.txt files.
Thanks for any help you can give me.
  • grossm5000
  • grossm5000
19 Mar 2026 14:31
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
I am wondering if my PCIe slot is bad. Trying a different slot today…stay tuned…
  • RLA
  • RLA
19 Mar 2026 14:05
tool compensation on joints was created by RLA
Hi...asked this before with another question that has not received any reply yet..
I currently have 2 tools on 1 axis as a rough and finish tool....as 1 tool is sharpened calibration between 2 changes ...I would need to adjust one tool diameter separately from the other...So the question is..if I set up as 2 joints on that axis can the tool diameters be changed independently and result in on joint compensating different from the other while following the motion for that axis?
Thanks for any help..
Rick
  • amanker
  • amanker
19 Mar 2026 14:03
Replied by amanker on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
Thanks for reply. I will wait.
  • aikiaviator
  • aikiaviator
19 Mar 2026 13:00
Replied by aikiaviator on topic Plasma table set, fine tuning a problem
Category: Plasmac
Hi Rod, Thanks. Found the section. Looks like no actual settings defined for the newer and current THCAD2. I guess I can muck my way through it. Looks like the calculator doesn't have it factored either. Thanks for the pointer.
  • spumco
  • spumco
19 Mar 2026 10:42
Replied by spumco on topic Trouble with XFCE (trixie) timed logouts
I just open power management under 'settings' menu and set all timing sliders to zero.
  • grossm5000
  • grossm5000
19 Mar 2026 01:51
Hey thanks for the fast reply. I ended up powering the 7i77 with a dedicated 5v power supply. Flipped all the appropriate jumpers on the 7i77 and 6i25
i would also like to point out that I removed the terminal blocks for ALL the encoders, drivers on the previously mentioned TB…so it can’t be shorted or drawing too much power because everything is disconnected!
I started to wonder if my 6i25 was dead. I don’t see any LEDs light up on it when I power up the PC. I also can’t find it with lspci
Displaying 5536 - 5550 out of 12543 results.
Time to create page: 0.614 seconds
