  • Lcvette
  • Lcvette's Avatar
16 Mar 2026 23:09
Replied by Lcvette on topic Probe Basic Errors after successfully probing
Category: QtPyVCP
i just tried to replicate your warning, but i was able t stop and make adjustments and report without running into any of those error pop up. those are actually linuxcnc statement stating that your entered parameters would cause an over travel event, are you certain the parameters you entered would be tool paths within the constrained machine motion envelope?
16 Mar 2026 22:59
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
Category: Installing LinuxCNC
LOL, i feel sorry for the keyboard! :)
It is hard for now, but after a while everything starts to fall in place and make sense.
Changing one single thing at a time and testing is much more productive and easy to roll back in case of failure.
  • kello711
  • kello711's Avatar
16 Mar 2026 22:53
Replied by kello711 on topic Probe Basic Errors after successfully probing
Category: QtPyVCP
what is your machine setup like regarding tool offsets?
My machine overall is a router style setup with a 30 in x 30 in work area. My spoil board is ~24 in x24 in. The spoil board corner is not at (0,0), well inside the machine soft limits. My tool table only has Z offset and Diameter. After probing the corner of the spoil board, the G54 offsets were: X=5.0161, Y=1.1693, and Z=-7.4953. Z probe Z offset is 2.3607 and cutting tool Z offset was 1.8513.
T1   P1   D+0.125000 Z+3.566440 ; 1/8 end mill Sample Tool
T2   P2   D+0.062500 Z+0.100000 ; 1/16 end mill Sample Tool
T3   P3   D+0.201000 Z+1.273000 ; #7 tap drill Sample Tool
T4   P0   D+0.236200 Z+3.688692 ; 6mm DLC End MILL (DSA1F-D6.0-L22)
T5   P0   D+0.196900 ; 5mm DriLL
T6   P0   D+0.255900 ; 6.5mm dRILL
T10  P0   Z+3.791137 ; 6MM COUNTER BORE
T11  P0   D+0.984000 Z+2.056925 ; BAP - EAP300r (C12-25-80-3T)
T99  P99  D+0.078500 Z+2.285087 ; 3d Probe
T100 P0   ; SPINDLE NOSE
16 Mar 2026 22:41
An all-in-one control panel based on Raspberry Pi and 15.6" touchscreen
Category: Show Your Stuff
Very nice, thank you, and also thank you for sharing the files on GitHub.
16 Mar 2026 22:37
Replied by tommylight on topic Pathpilot Spindle speed control for a lathe
Category: PathPilot
Moved to "pathpilot" section.
  • PCW
  • PCW's Avatar
16 Mar 2026 22:23
Axis position shift during helical boring - Fusion 360 Personal + Mesa 7i96s + C
5. NOT step timing: Tested DIRSETUP/DIRHOLD at 2000, 5000, and 10000ns. 5000 was slightly better but didn't solve it.
If changing the step timing changes anything that suggests that something is marginal
electrically or timing wise
Have you tried doubling the step time?
Are the drives step/dir connections single ended or differential?  (single ended is suggested for opto-coupled inputs)
Does the DRO show the error? if not it's most likely not the Trajectory Planner
  • grandixximo
  • grandixximo's Avatar
16 Mar 2026 22:10
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
There already is some basic merging, I'm sure it can be improved upon
  • belovictor
  • belovictor
16 Mar 2026 22:07
Just wanted to share the control panel I've built for my VM32 CNC conversion project. The aim was to get away from a typical PC+Monitor setup and build an all-in-one control panel for LinuxCNC which can be mounted on the mill cabinet and control the mechanics through MESA board. I published the resulting models for this build in a Github repo:  github.com/belovictor/linuxcnc-control-panel
You can also find the panel build video on my YouTube:
Best regards,
Victor Belov
  • Lcvette
  • Lcvette's Avatar
16 Mar 2026 21:51
Category: QtPyVCP
  • georgio
  • georgio
16 Mar 2026 21:39
Hi tommylight, thanks for helping me with that I very much appreciate it and all the knowledge you have. I am just a newbie who is flailing around knowing squat trying to learn linux and linuxcnc; and not killing my brain in the process (my head has a few bruises from bashing it against my keyboard.
Thanks,
George
  • georgio
  • georgio
16 Mar 2026 21:34
Thank you Rod for your help it makes it alot easier to see where the errors are using geany was very helpful and good learning!
  • Lcvette
  • Lcvette's Avatar
16 Mar 2026 21:22
Probe Basic offset direction not seeming to work
Category: QtPyVCP
yup yup,, its pulled from the tool table and activated or not in the touchoff parameters.
user params 1 and 2 are there for you to use in any custom macro capacity. you can simply click on the label names and type your new name and it will store prsistently and you can look at the parameter names in the docs as what to pass to the subroutines. so if you wanted to add something specific to your machine you can do that with those and have realtime updating parameter entries in the ui. was just a "here ya go all" thing i figured might be useful and i had some space to use up so win win!
:side:
  • gspohn
  • gspohn
16 Mar 2026 21:11
Category: PathPilot
Hi
   I am brand new to this forum. I couldn't find an answer to my question, so here goes.
   I have modified an old manual lathe to run with pathpilot. Everything works except trying to change the spindle speed range. I have set up a custom card to control a VFD and when I run with these parameters in the tormach_lathe_base.ini its all good. Both high range and low range work as expected.
[Spindle]
LO_RANGE_MIN= 200
LO_RANGE_MAX=2500
LO_SCALE=1.0
HI_RANGE_MIN= 200
LO_RANGE_MAX=2500
LO_SCALE=1.0
  What I want to do is use the gear box to drop the spindle speed by a factor of 8. The new config information is the following
[Spindle]
LO_RANGE_MIN= 35
LO_RANGE_MAX=300
LO_SCALE=0.125
HI_RANGE_MIN= 200
LO_RANGE_MAX=2500
LO_SCALE=1.0
When I make this change, the VFD frequency is wrong and it appears that the direction lines don't function either. Version of PP is 2.14.0
Any ideas out there? My guess is that there is another parameter that I haven't changed to make a change like this.
greg
  • currinh
  • currinh's Avatar
16 Mar 2026 21:06
Replied by currinh on topic Trouble with XFCE (trixie) timed logouts
Rod: Thank you for the quick response and the script. I can only imagine the effort involved in finding all the settings for that script.
However, I ran the script and it didn't solve the problem on my machine. I ran the script and re-booted. When the machine started up I logged in and started linuxcnc. To test I just let it idle, no keyboard or mouse input and no running program in linuxcnc. It idled for just about 30 minutes and then logged out. The result was a user/password screen to re-login. When I login using that new screen I find myself stuck in a loop. I login, the computer thinks awhile, then pops up a new login screen. Same as I had when I pushed the wrong Power Management button before. Again, since I don't know how to revert from here using a terminal, I needed to re-install to get out of this loop.
I took to heart your comment, "Its actually very difficult to stop this". If there's no "standard" solution and you've had problems, I have no hope of fixing it myself. Instead I installed linuxcnc 2.9.4 which uses the older Debian 12 (Bookworm). But it sounds like to main problem is with the XFCE desktop more than the underlying Debian. I don't know the differences in XFCE between 2.9.4 and 2.9.8 but the problems look to be there.
Is this somehow computer dependent? If not a lot of users must be having the same problems. Is there a solution being worked on? If XFCE has gone off the rails, maybe a different desktop for future releases?  I'll need to update linuxcnc eventually and sure hope this is addressed.
Thank you very much for the help. I've solved my immediate problem, version 2.9.4 is now working. Again, thank you.
Hugh
  • georgio
  • georgio
16 Mar 2026 21:04
Well I have made a little headway thanks to your help but now I am stuck again after a few hours of banging my head against my keyboard I am back. I have encountered an error at hal 67 with limit inputs. I have the inputs on TB6 04-9 being first 4 limits xyy2z 8&9 estops. I have commented out any thing to do with the estops and spindle on both ini and hal files to try and get linuxcnc running without errors and then I will work on them. The is pin 04 does not exist and I'm sure I am going to get the same errors for the joints. I have updated my ini and hal files and and added a screen copy of the run of Linuxcnd with the exact error shown and you can see what else is loading.
thanks again,
George
Displaying 5671 - 5685 out of 12544 results.
Time to create page: 0.404 seconds
