  • PCW
  • PCW's Avatar
12 Mar 2026 21:08 - 12 Mar 2026 21:19
Replied by PCW on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Just checked 7i97t_7i74d.bin
md5sum=
4130ebee623115267327c166f8da9d39  7i97t_7i74d.bin
All encoders work, 7I97 sserial (0) and all 7I74 sserial channels (1..7) work as expected
  • Mbrand1901
  • Mbrand1901
12 Mar 2026 20:15
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
I have only used firmwares from the Website. I also know that i only need a 7i97t with 7i74 firmeware. In the file there are a few firmwares with the 7i97t_7i74 Name. So the 7i97t_7i74d.bin is the right now?
Tomorow i will look further in to it.
And why the encoders arent counting.
  • natas01
  • natas01
12 Mar 2026 20:01
pin locations was created by natas01
pin locations
might be a dumb question I have a 7i96s how how do you no where PIN numbers locations. I'm in the pnccofig it says pin # xx  but where is it on the board ?
  • Xnke
  • Xnke
12 Mar 2026 19:57
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
This is the plan. Keep in mind, all who follow, that if you finish the installation completely offline-no internet access-your Debian package sources files will be empty. You will have to create the .sources file, or when you do sudo apt install you will get "could not find" and when you do sudo apt unpdate it will run through the updates and say there is nothing to update.
  • TAKUYA
  • TAKUYA
12 Mar 2026 19:27 - 12 Mar 2026 19:33
Replied by TAKUYA on topic Ethercat random jitter fix
Category: EtherCAT
So pll-error remains 0 for me. App phase hovering between 9800 and 10500
What i did notice, i had all 3 axis vibrate like crazy upon first Launch today. Rebooting lcnc fixed that.
Edit: did another power cycle. No Vibration but sudden clunking on all 3 axis again
  • Todd Zuercher
  • Todd Zuercher's Avatar
12 Mar 2026 18:36
Replied by Todd Zuercher on topic Connect Siggen to Stepgen?
I think I overlooked the control type (because its in the pin list rather than a parameter.)
  • Todd Zuercher
12 Mar 2026 18:33
I'm not sure if I set the control mode to 1. I'll have to check that. I thought I had most of the settings the same as the stepgens that were in use, and those are commanded by velocity command from the PID.
  • endian
  • endian's Avatar
12 Mar 2026 18:00
Replied by endian on topic LinuxCNC S-Curve Accelerations
Hello,
I can see merge of your progress to master? Am I right ?
Regards e.
  • PCW
  • PCW's Avatar
12 Mar 2026 17:57
7i97t_7i74d.bin  would be the correct firmware for a 7I97T +7I74
Note that with this firmware sserial channel 0 is on the 7I97T
and channels 1..7 are on the 7I74 (7I74 physical channel 0 does not work)
  • liutas4x4
  • liutas4x4
12 Mar 2026 17:52
Replied by liutas4x4 on topic some qs about Axis tuning
It seems I will try gmoccapy. It looks more friendly for me. And possibility to add stand alone pyvcp will help me too.
Once more, thank you for real help.
/eugenius
  • PCW
  • PCW's Avatar
12 Mar 2026 17:48
Mesa 6I25 and 7I78 setup for ELMO SSA-6/100OPT2 servo drives
Category: Driver Boards
You can certainly get firmware that replaces the step/dir outputs to PWM/DIR,
but then you still need multiple channels of PWM/DIR --> +-10V analog conversion
and then you are still missing the multiple encoder channels needed.
So, a 7I78 is really the wrong starting point here. Mesa should have 7I97Ts
in 1-2 weeks so that is the simplest solution I see. Production 7I77Us are still
about 6-8 week away.
12 Mar 2026 16:27
Replied by tommylight on topic Retrofitting Deckel FP4ATC
Can someone please send me the right firmware for that config? I have tried a few and it wouldnt work. Also the encoders stopped working after the new firmeware.
Don't do that, just don't.
You need firmware for 7i97T with 7i74, you do not need anything for 7i84 as that is an SSerial board so it needs no firmware per se, it is a Smart Serial so it arranges things on it's own when communicating with the FPGA.
And, never ever flash Mesa boards with random firmware, except from Mesa website and explicitly for the FPGA you have.
  • jgandgg
  • jgandgg
12 Mar 2026 16:21
Hello everyone,I am currently working on bringing an old CNC milling machine back to life. The machine uses analog axis drives with a +/-10V command signal.The original controller (NUM 1040) is no longer working. However, the axis drives are still functional. They are ELMO SSA-6/100OPT2 drives.My plan is to replace the controller with LinuxCNC. I already have a Mesa 6I25 and a 7I78 card, but these only provide STEP/DIR outputs, which are not directly compatible with my analog +/-10V drives.I am therefore looking for a solution to convert STEP/DIR signals into an analog +/-10V command. I have seen that it may be possible to convert STEP/DIR to PWM and then from PWM to +/-10V, but I am concerned that this could introduce latency or reduce control quality.Another option would be to use a Mesa 7I97 or 7I77, which natively support analog +/-10V outputs, but unfortunately these cards are currently unavailable.If anyone has experience with a similar setup or knows a reliable solution, I would greatly appreciate your advice.Best regards.
  • Lcvette
  • Lcvette's Avatar
12 Mar 2026 16:20
Replied by Lcvette on topic Some problems with probe basic lathe
Category: QtPyVCP
i just tried using the facing one and it does do things, but i really am not a fan of the setup, i suspect it is incomplete compared to the original macros andy put out. it looked to have several missing inputs. and im not a fan of it running without having a chance to see the output plot for verification. i would say the subs need some work before i would use them personally.
  • Lcvette
  • Lcvette's Avatar
12 Mar 2026 16:14
Category: QtPyVCP
did you verify your paths for the subroutines were correct? those look to be correct names to be parsed. it appears you have hardcoded max rpm speed instead of using the ui entry. but other than that the names look to be correct. I would test by copying the subroutine and trying to run it as a program filling in the data as expected and see if you can make it run, may tell you if the subroutines is correctly formatted or not.
Displaying 5851 - 5865 out of 12544 results.
Time to create page: 1.292 seconds
