  • Muecke
  • Muecke's Avatar
08 Mar 2026 18:38
Verdrahtung Leadshine DM856 Ena+ und - bei Mesa 7i76e
Category: Deutsch
Hey,
ich habe zwar nicht die gleichen Treiber, aber ich habe einfach 5 V draufgegeben und der Treiber war gesperrt.
Demnach müsste nur ein digitaler Ausgang deiner Mesa-Karte auf ENA+ gelegt werden und der entsprechende GND des digitalen Ports der ESA auf ENA-.
Wenn der digitale Port dann HIGH ist, müsste der Treiber gesperrt sein.
Gruß Mücke
  • Muecke
  • Muecke's Avatar
08 Mar 2026 18:31
Replied by Muecke on topic Forum Fehler, ... :-(
Category: Deutsch
Wie zu erwatren ist ein Fehler aufgetreten :-(
Error
Kunena Internal Error: Please contact the site administrator to fix this issue!
 Ist eventuell etwas intern mitgeloggt worden?
  • andypugh
  • andypugh's Avatar
08 Mar 2026 18:24 - 08 Mar 2026 18:41
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Category: Driver Boards
Some observations:
Lots of people are using USB to Modbus convertors to control spindle VFDs, and that works OK, (it's noticably notchy doing CSS on my lathe, though)
Jepler (long-time LInuxCNC dev, but now left the project) wrote this back in 2007:
emergent.unpythonic.net/01198594294
USB is definitely adequate for any HMI interaction, otjherwise gamers wouldn't be able to use USB keyboards. (I know that _some_ insist on PS2 for less latency, but most don't)
  • andypugh
  • andypugh's Avatar
08 Mar 2026 17:57
Replied by andypugh on topic 7i97+8i20 error function not found
Category: PnCConf Wizard
Have you tried an "fq" config (or "fqi"). That should use the Fanuc commutation for initial starting and then use the quadrature position from that point on.
Probably :-). I haven't tried it.
  • Hakan
  • Hakan
08 Mar 2026 17:51
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
Dec 27 it looks like from github. Actually, the bug shouldn't affect you.
A negative refClockSyncCycles value should switch on the PLL and synchronize servo loop time with DC time.
You can always check the lcec.pll-* hal variables. If some of them move, it's on.
refClockSyncCycles is how often the master sends a synchronization signal to the slaves to compensate for clock drift.
I use 1000 because the slaves' DC clock run pretty accurate as it is. Many people use 1 as value.
I have not seen that any number is better than the other, maybe there is, but feel free to use any number you prefer.
  • TAKUYA
  • TAKUYA
08 Mar 2026 17:18 - 08 Mar 2026 17:19
Replied by TAKUYA on topic Ethercat random jitter fix
Category: EtherCAT
Now as in just recently or in the patch from last year? or reaaally recently
Also, what does the refClockSyncCycles value do and is there any baseline on what to set it at?
  • Hakan
  • Hakan
08 Mar 2026 16:35
Category: EtherCAT
There was a bug with "-1", fixed now but it sounds like you have it.
Use a positive value in refClockSyncCycles and set syncToRefClock="true"
and that should hopefully fix it.
  • TAKUYA
  • TAKUYA
08 Mar 2026 16:04
Category: EtherCAT
I currently have refClockSyncCycles="-1" which according to the docs you linked above, means its enabled for backwards compatibility. Sadly, I have these mentioned issues where the axis starts clunking randomly (on a random axis) after some time. Its a fresh install from end of january. Does SyncToRefClock still need to be set?
  • Hakan
  • Hakan
08 Mar 2026 15:56
Category: EtherCAT
Better yet, enable synchronization with syncToRefClock="true"
github.com/linuxcnc-ethercat/linuxcnc-et...s.md#master-settings
The refClockSyncCycles is how often to synchronize the clocks between the slaves
which is something different altogether, and doesn't help this problem.
  • 0x2102
  • 0x2102's Avatar
08 Mar 2026 15:43 - 08 Mar 2026 15:50
Replied by 0x2102 on topic CiA 402 Folder Missing
Category: EtherCAT
Never mind.
  • Konstantin
  • Konstantin
08 Mar 2026 15:23 - 09 Mar 2026 16:47
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
I was trying the entire weekend to make the drives work but still no success. Basically I started from scratch and cloned "linux-cia402" from RodW github page. Then executed "ethercat pdos" and the drives return PDO mapping 1701h and 1B01h. Next, following the manual and the mapping for 1701h and 1B01h, I wrote the .xml and .hal files. In the .xml file, I tried to set the data type for each pin as per the manual but the lcec components does not like s16, u16 and u8, anyway I changed them to s32. LinuxCNC opens and loads the configuration but when I try to home, a following error occurs.
In the terminal I observed a weird output when execute "ethercat pdos" after LinuxCNC has started - there is no names on the right of the PDOs, look at the attached pdos.txt file.
Also the synchronization error  and 1 datagram unmatached warning appeared again.
In the beginning of the .xml file I tried to set the PDO mapping using "sdoconfig" but it does not seem to help either.
08 Mar 2026 14:59
Replied by tommylight on topic Forum Fehler, ... :-(
Category: Deutsch
Debug enabled, give it a try.
  • andrax
  • andrax's Avatar
08 Mar 2026 14:06
Replied by andrax on topic Ethercat random jitter fix
Category: EtherCAT
Okay, thank you.
I had already thought that the issue had something to do with packet loss when starting LinuxCNC.
However, this seems to occur during operation, which I have not yet experienced. If this work results in ethercat running more stably, I will simply wait until Sascha announces an official patch, which will likely be available via update.
Until then, I will simply stick with refClockSyncCycles="1">.
  • hitchhiker
  • hitchhiker
08 Mar 2026 13:57
EMCO Compact 5 cnc Turret with dc motor and no feedback
I got it working.
No feedback needed.
3 pins are used..
Forward
Backward
Pwm pulse
L298n cheap modul.
I clean up the component and then i make a small video und can share the code.
I use a 8 position toolchsnger from my emco 220 where i unmount the lightbarrier pcb.
How it works:
Start linuxcnc..
Then 1 time make movement over a button of the toolchanger.
Then look which tool is in position.
Then set toolnumber over buttons.
After this all is done over timing.
No motor noise!
No overheating!
No issues!
Rollover is handled.
The biggest problem was to find the correct timings and speeds.
The reason for the issue is that the dc motor has a planetary gear and the wormgear has small play.
You can setup:
How many toolslots you have
Time from slot to slot
Backward time
Backward locking time
Pwm for forward
Pwm for backward
Pwm for locking against the pawl
Advantage:
If you hit emergency off the toolchanger stops and resets
You can add reference signal to tool1
You can drive toolchanger from slot 2 slot over buttons.
You have pins where you csn see if you have rollover and the slots it must travel.
Its complete openloop and can setup over a hal or halpkns
  • Hannes
  • Hannes
08 Mar 2026 13:56 - 08 Mar 2026 13:57
Replied by Hannes on topic XHC WHB04B development?
@Finngineering: So you did not start a rewrite? I see it the same way. The actual component looks like a school book example of object oriented design, then it didn't suite the needs, took way more time then estimated and the needed redesign, simplification and finalizing never happened. But for a rewrite, the chances are high the same will happen and to get it to the functional state the actual module has, it will take a lot of time. So if it works now, fine. If there emerge unsolvable issues, we can think about it again.
I looked quickly into the xhc-hb04: is way less complex but it also has less functionality. I find this automatic change to manual quite nice. And the xhc-hb04 has a complex hal and config file which probably also makes it difficult to use.
@rodw: As I understand linuxcnc, before homing, you can only jog single axis due to the kinematics needs homing. But due to jogging Y1 separate from Y2 will bend the gantry, this is deactivated like in my machine using HOME_SEQUENCE. I don't need jogging before homing, so that's fine for me.
However, the WHB04B tries to activate jogging also before homing and then generating errors. For me, that's a non-issue, I just don't touch the wheel. And if it happens by accident, nothing else happens except an error messages.
For non-gantry machines, you can jog also before homing, so I did not remove that functionality because it might be useful for others.
An solution would be to add a command line option for this. However, I rather create some chips than continue coding... ;-)
Additionally, I started another rabbit hole which is more important for my machine:
github.com/LinuxCNC/linuxcnc/issues/3839
Just a note: Linuxcnc is just a hobby for me I started recently. But I have a lot of experience in coding and bug fixing from my day job and I figured fixing the issues I am having myself and creating PR's would give something back to the community.
Displaying 6001 - 6015 out of 12547 results.
Time to create page: 0.691 seconds
