  • Finngineering
  • Finngineering
07 Mar 2026 07:34
Replied by Finngineering on topic XHC WHB04B development?
The current component tries to change to manual/teleop mode even with a program running/paused. The changes made by Hannes prevents that. However, if a program is not running/paused and you start jogging, it will change to manual/teleop mode automatically. It could of course be discussed if the pendant should be "allowed" to do this just by jogging the wheel. But the PR by Hannes is really mainly bugfixes, so I would presume that it's best not to alter the behavior of the pendant more than necessary.
  • rodw
  • rodw's Avatar
07 Mar 2026 07:22
Replied by rodw on topic XHC WHB04B development?
I have not been following this but if the system fails with a program running, there is a fault with the driver logic. Jogging should not be permitted unless the machine is in teleop mode and programs are not permitted to run in teleop mode.
The driver could request teleop mode with halui.mode.teleop and this will prevent a program from running. I did this with a hard wired pendant. Gmocappy is a good gui to demonstrate this because setting teleop mode makes it display the jog buttons.
  • Finngineering
  • Finngineering
07 Mar 2026 07:08
The assert statement is setupAsyncTransfer() is the "big" issue. Simply removing that causes the reconnect to be triggered when trying to send a display update. For me that reconnection works without problems. For Hakan, it gets stuck/segfaults in libusb after reconnect. Somewhere along these lines:
forum.linuxcnc.org/38-general-linuxcnc-q...ment?start=80#343687
It would of course be good to get to the bottom of this. But since I can't reproduce this, it's a bit difficult to debug.
Both myself (with the original firmware) and Hakan can trigger the disconnect reliably by using the original component and jogging while a program is running.
On the development computer, I use the LinuxCNC 2.9.8 iso image / Debian 13. That one has libusb 1.0.28-1. I'm not at that computer right now, so cannot check the kernel version. But it's the stock one from LinuxCNC 2.9.8 iso (unless "apt upgrade" has updated it).
  • rodw
  • rodw's Avatar
07 Mar 2026 06:22
Replied by rodw on topic RPi 4B - No Desktop Icons
The standard 4b installer should install the xfce desktop.
The gnome-desktop is empty by default until you find stuff in the search bar and add it. I have not run it for years (last was on bullseye) but it was a bit daunting!
Sounds like something has gone wrong....
You could choose a desktop if you
sudo apt update
sudo apt install tasksel
sudo tasksel
  • rodw
  • rodw's Avatar
07 Mar 2026 06:11 - 07 Mar 2026 06:13
Replied by rodw on topic heure et date
heure et date
Category: Français
Please run menu-config to set your wifi
  • rodw
  • rodw's Avatar
07 Mar 2026 06:07
Replied by rodw on topic What AI thinks of Flex GUI
Category: Flex GUI
Don't you hate it when AI quotes you back to yourself!
  • madmetal
  • madmetal
07 Mar 2026 06:01
Looking for new or used Mesa 7i96S board for CNC lathe conversion
Category: Driver Boards
Hi - I'm looking for new or used Mesa 7i96S board for CNC lathe conversion - Delivery to Hong Kong. Any simple alternatives for this if not available?
I'm converting WM210V lathe - so for inputs there will be two steppers/drivers, rotary encoder, lathe motor control board via three wires from potentiometer. Plan to use RPi Linuxcnc distro which i have been already playing around with.
Thanks!
07 Mar 2026 00:30
Replied by tommylight on topic Gmoccapy 4 axis question
Category: Gmoccapy
Anyone know why was this topic deleted?
07 Mar 2026 00:26
Replied by tommylight on topic Forum Fehler, ... :-(
Category: Deutsch
Sorry i can not find anything causing that.
Can you start new topics as a continuation of those two and i can post the links there?
And please do not use the same exact tittles as the old ones, anything different to easier discern.
Thank you for your patience.
07 Mar 2026 00:22
Trying to figure out all the Mesa cards and what to get
Are you sure it is +-15V ?
Maybe +-15V / KRPM ?
07 Mar 2026 00:13
Replied by tommylight on topic help - mesa 7i76eu - pin does not exist
Does 7i76EU have field power?
  • josh1e
  • josh1e
06 Mar 2026 23:48
hi. after running pncconf wizard, I cannot load linuxcnc because of error below, i was trying to setup sn04-p2 type proximity sensors on tb6 pins 0,1,2 and probe and estop on 4,5. Any ideas to resolve please? (note, im new to mesa and linuxcnc) thanks
Debug file information:
Note: Using POSIX realtime
./3020f.hal:31: Pin 'hm2_7i76e.0.7i76.0.0.input-00' does not exist
3994
  • Hannes
  • Hannes
06 Mar 2026 22:37
Replied by Hannes on topic XHC WHB04B development?
Normally, you anyway don't want the program or MDI command to stop because you accidentally jog, so I figured this is a good choice, even if it would switch to manual. Which it doesn't do anyway, at least in my case.
I did not read the whole thread in detail. But it seams you have issues with libusb_submit_transfer() and the assert afterwards? According to the manual, this function is allowed to return disconnected: manpages.debian.org/unstable/libusb2-dev/libusb.3.en.html
This should be fine, we should handle the error, cleanup properly and try to reconnect. Worst case, you have to do is disconnect the dongle and reconnect it again. I can look into that.
Meanwhile, do you have a way to reliably get the device to disconnect? Otherwise, it is always hard to see if a fix is really a fix or just the device behaving nicely for a few hours and then failing again.
@Hakan: I see you have Debian 12 (So libusb 2:1.0.26-1 I guess, libusb-1.0 is the package name, not the exact version). Did you try Debian 13?
@Finngineering:
Which Debian version do you have? Kernel version? Libusb version?
I have Debian 13 stock, libusb 2:1.0.28-1
  • electrosteam
  • electrosteam
06 Mar 2026 22:09
Replied by electrosteam on topic RPi 4B - No Desktop Icons
Andy,
Thanks for the suggestion, but all the workspaces are devoid of icons.
My post was only to alert the RPi developers in case there is something deeper going on.
I plan to re-install LC 2.9.4 from my back-up to see if that cures the problem.
Then, perhaps, try LC 2.9.8.
John.
  • andypugh
  • andypugh's Avatar
06 Mar 2026 22:05
+/-15V is rather unusual.
The drives would work at 2/3 of full speed on +/-10V. That might be enough in practice.
Displaying 6061 - 6075 out of 12547 results.
Time to create page: 0.800 seconds
