XHC WHB04B development?
- Thank you received: 4138
07 Mar 2026 07:22 #343975
Replied by rodw on topic XHC WHB04B development?
I have not been following this but if the system fails with a program running, there is a fault with the driver logic. Jogging should not be permitted unless the machine is in teleop mode and programs are not permitted to run in teleop mode.
The driver could request teleop mode with halui.mode.teleop and this will prevent a program from running. I did this with a hard wired pendant. Gmocappy is a good gui to demonstrate this because setting teleop mode makes it display the jog buttons.
- Finngineering
- Thank you received: 49
07 Mar 2026 07:34 #343976
by Finngineering
Replied by Finngineering on topic XHC WHB04B development?
The current component tries to change to manual/teleop mode even with a program running/paused. The changes made by Hannes prevents that. However, if a program is not running/paused and you start jogging, it will change to manual/teleop mode automatically. It could of course be discussed if the pendant should be "allowed" to do this just by jogging the wheel. But the PR by Hannes is really mainly bugfixes, so I would presume that it's best not to alter the behavior of the pendant more than necessary.
07 Mar 2026 08:00 #343977
In my case I had a deadman's switch that had to be held down to enable the jog wheel on the pendant so I set teleop mode when that button was pressed. I don't think you should allow just jogging the wheel to change modes. There are some safety rules around this stuff. And yes having to switch modes to jog on screen or a pendant is frustrating but probably for safety.
- Hakan
- Thank you received: 453
07 Mar 2026 08:42 - 07 Mar 2026 08:45 #343979
by Hakan
Replied by Hakan on topic XHC WHB04B development?
You are right, rodw, and I don't particularly like it. But that's how it is.
That part can be taken out, for sure.
Some news. I think it is now narrowed down to debian 12 and probably gcc 12.2
Hannes, your question on trixie, I thought I was on trixie on my development pc, no I was on 12.13.
And suspicion about va_args.
So I upgraded to trixie and gcc 14.2.0.
Recompiled, and now it doesn't segv anymore.
It continues after a short break, like it should.
The problem is in libusb1.0 when compiled with gcc 12 (if I understand right).
Last edit: 07 Mar 2026 08:45 by Hakan.
- Finngineering
07 Mar 2026 08:47 #343980
by Finngineering
rodw: I tend to agree that jogging should not be possible by accident. However, I would personally keep that kind of behavior change separate from the bugfixes in the PR. I just fear that changing behavior makes the PR more likely to be not be accepted. But I don't really know, and it's Hannes' PR after all.
Hakan: Great if you got rid of that libusb issue. Then unless somebody else experience the same issue, I think not much need to dig deeper.
- Hannes
- Thank you received: 6
07 Mar 2026 09:54 - 07 Mar 2026 09:55 #343982
by Hannes
Replied by Hannes on topic XHC WHB04B development?
That WHB component is somewhat a rabbit hole... I tried to do proper error handling, can you test it?
github.com/hdiethelm/linuxcnc-fork/tree/...fix-v2-errorhandling
The proper way of testing would be:
1. Get this version to fail reliably: github.com/hdiethelm/linuxcnc-fork/tree/xhc-whb04b-6-fix-v2
2. Now test this version: github.com/hdiethelm/linuxcnc-fork/tree/...fix-v2-errorhandling
Otherwise, you can never be sure the change made any difference. I now that is often not that easy.
Looking at the code, just removing the assert() probably can result in segfaults in libusb as long as the error is not handled properly.
Note that even with my changes, it is not really how you would do it in a nice way but it should work I think. I am not able to reproduce your issue, so I can just guess and try to do better error handling.
@rodw: Jogging in manual mode is fine. My machine can not jog in teleop mode due to I have two Y axis servo motors. The only thing the WHB component does after my PR is:
- Change to teleop mode if not homed (which fails on my machine but on others, it will do that) -> You can jog before homing any special action
- Change to manual mode if homed AND program is idle -> You can jog after homing without any special action
Last edit: 07 Mar 2026 09:55 by Hannes.
- Hannes
07 Mar 2026 10:58 #343984
by Hannes
I found an other issue while trying to test the error handling. Please wait with testing.
- Hannes
07 Mar 2026 11:53 - 07 Mar 2026 12:03 #343987
by Hannes
So, it should be solved. Ready for testing.
In the case libusb_submit_transfer() returned an error and you remove the assert, the whole xhc-whb04b-6 module would just do nothing any more. I think that's what you observed.
I tested it by pretending an error happens, so not 100% what you have:
int r;
static int i;
i++;
if(i==30){
r=-1;
i=0;
}else{
r = libusb_submit_transfer(inTransfer);
Last edit: 07 Mar 2026 12:03 by Hannes.
- Hakan
07 Mar 2026 12:42 #343988
by Hakan
The crashes I got was after removing the assert() in setupAsynchTransfer().
When that condition happened, the code waited three seconds and tried to to re-establish
communication. I then got a segv crash from within libusb forum.linuxcnc.org/38-general-linuxcnc-q...ment?start=90#343894
I tried on two different computers and got the same crashes on both. Both debian 12.13, gcc 12.
When i upgraded to debian 13 and gcc 14, there are no more crashes.
I also don't get that debug message from libusb about destroying device.
"Only" changing the gcc compiler version did change things to the better.
My way of get the xhc component to fail is to increase the loops to 100 in hal.h,
start G1X-200F100 in MDI and once that is slowly running, I spin the wheel very fast in the Z direction,
or any direction, but Z is safe.
With default value of loops it takes some tries to get it to fail, and with loops 10 it is almost impossible to get it to fail.
After it fails it usually restarts after a few seconds. Unless the libusb crashes it with segv as it did with gcc 12.
I did try your component yesterday for a short time and it never failed.
- Hakan
07 Mar 2026 16:43 #343993
by Hakan
I sat for some fifteen minutes and tried my best to make the xhc fail. The errorhandling branch.
It works fine. The movement I used to make it fail is now blocked. And for the rest I just works.
I tried things that takes a bit of time like switch screen that used to be a problem.
Not a proof it always works, but I am unable to make it fail.
Time to create page: 1.188 seconds
