XHC WHB04B development?
- kello711
02 Apr 2026 00:38 #345040
by kello711
Replied by kello711 on topic XHC WHB04B development?
I have this pendant and would like to test out your firmware. Where do I find it/install it from? I'm tired of this device working and then just deciding to quit working in the middle of operations.
- Finngineering
- Thank you received: 49
02 Apr 2026 16:02 #345063
by Finngineering
Replied by Finngineering on topic XHC WHB04B development?
I imagine that you will be satisfied with the updated xhc-whb04b-6 component by hdiethelm, which allows the pendant to reconnect in case it disconnects (as well as several other improvements). But you need to compile it from source, same as building LinuxCNC from source (which is not all that difficult). He made a backport to LinuxCNC 2.9.8:
github.com/hdiethelm/linuxcnc-fork/tree/...x-v2_backport-v2.9.8
So basically git clone that repository, checkout xhc-whb04b-6-fix-v2_backport-v2.9.8 and then compile. I don't know about exact version compatibility, but I don't think you actually need to use v2.9.8 to run the component. You can just give the full path to the newly built compnonent binary in the loadrt command.
I made a custom firmware for the USB dongle that I use myself, but I can't really recommend that for others. There is a decent risk that it would irreversibly break your dongle in case the hardware is slightly different than what I have.
I don't know your proficiency with git and compiling LinuxCNC from source. Just ask if my somewhat terse instructions are not clear to you.
The following user(s) said Thank You: rhscdn
Time to create page: 0.072 seconds
