  • Ismacr63
  • Ismacr63
15 Feb 2026 19:43
Replied by Ismacr63 on topic Some problems with probe basic lathe
Category: QtPyVCP
I’ve tried changing the field names in Turning using Qt Designer so they match the macros, but without success. I’m not exactly sure if what I tried makes any sense, since I don’t have experience with this.I’ve looked at the files in the link, but are they for Probe Basic Mill? This is a bit beyond me because I don’t really have the necessary knowledge…I also saw a post on the Facebook page about an update to the lathe conversational section. Does anyone know when that update will be released?
  • rockabye74
  • rockabye74's Avatar
15 Feb 2026 18:53
Replied by rockabye74 on topic Firmware Request 6i25 + 7i77 + 7i89
Category: Driver Boards
You are awesome! Thank you very much!
  • PCW
  • PCW's Avatar
15 Feb 2026 18:07
Replied by PCW on topic Firmware Request 6i25 + 7i77 + 7i89
File Name: 5i25_7i77_7i89d.zip
File Size:97 KB
  • Finngineering
  • Finngineering
15 Feb 2026 17:50
Replied by Finngineering on topic XHC WHB04B development?
I had/have very similar issues as you mention earlier today Hakan. The after the pendant disconnected once, it kept doing so every 20 s or so, just like for you. And you see the LIBUSB_ERROR_NO_DEVICE because the dongle has disconnected. However, if you again start LinuxCNC (maybe need to try a couple of times to get the timing right), the pendant will resume working just fine and the disconnects stop for the time being.
As I have said, I believe the reason for the disconnects is that the dongle is unhappy with the current situation and resets itself. And "unhappy with the current situation" is most likely because the host has not been polling its interrupt endpoint for some time (maybe half a second or so).
I attach here a logic analyser screenshot, capture file as well as wireshark capture from a "forced" disconnect event. For this capture, I had the dongle disconnected, LinuxCNC (sim) running a program and in the background waiting for the pendant. I then started all captures, connected the pendant, pressed the Step button (and maybe some others) on the pendant and jogged the wheel. This caused the Usb::setupAsyncTransfer assert failed.
In the screenshot you can see that from approximately 2950 ms (corresponding to wheel jogging), there are no packets until ~3600 ms (except for SOF, which I have turned off on purpose). And at 3750 ms, there is a reset on the USB bus, corresponding to the dongle "disconnecting" and the assert failed. This reset is as far as I'm concerned generated by the dongle itself, because it was unhappy with the conditions.
If I zoom in a little bit on the disconnect/reset event, that becomes more clear. Here I have turned the SOF packets back on, and we see that they are sent every 1 ms as expected. And then suddenly the D+ signal drops to zero, indicating a bus reset (either from the device or the host). And I see no reason why the host should generate a reset in this situation, so I say its generated by the dongle. This is consistent with repeated disconnects every 20 s already discussed.
The .sr file can be opened with PulseView and the .pcapng with Wireshark, in case anybody wants to have a look.
At least for me the pendant is anything but solid. And I do think the dongle firmware is mainly to blame. That being said, it could very well be that different drivers/hardware could mask some of the issues I experience. If only I knew what causes (all) the disconnects, I'm sure we could figure out some ways to fix it.
  • rockabye74
15 Feb 2026 17:17
Firmware Request 6i25 + 7i77 + 7i89 was created by rockabye74
Hi, I will be retrofitting two Prototrak machines (TRL1440 LX2 Lathe, DPM5 SMX Mill) that use the Servos, Glass Scale Encoders, and Digital Handwheels with Disk Encoders and am thinking that I will require the 7i77 and 7i89 to process the Servo and Encoder Breakouts. I currently have a 6i25 from a previous build, hence the desire for the 6i25 + 7i77 + 7i89 firmware build.
Thank you so much!
Mike
  • MRx
  • MRx
15 Feb 2026 17:15
Replied by MRx on topic XHC WHB04B development?
Under normal operation there's no disconnect of the XHC pendant. It's solid. If you power it off it will disconnect.
I heard from others that they had EMI problems with USB and the XHC pendant in the past, I'm going to operate it with a large CNC in the near future so I will see if it will hit me too.
I think you have to fix a problem on the USB layer, maybe use another system which has a native USB 2.0/ehci port. The XHCI USB ports can cause issues depending on the hardware.
By the way you can easily convert an WHB04B to 6 axis by removing a stopper with a knife which is inside the rotary switch. 6 axis are wired up even on the 4 axis versions.
  • andrax
  • andrax's Avatar
15 Feb 2026 16:51
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
I have an idea.
rodw: Can you make the bits from 0x6041 available as pins?
Then we can observe the bits during the home run.
If we know which bit is set when, the state machine could be set up accordingly.
But maybe we're overcomplicating things.
I took a look this afternoon and looked at various CIA drives. 0x6040 and 0x6041 are standardized. All CIA402-compatible drives use the same bits.
See here:
Bosh Rexroth CIA Status word
That means all we really need to do is find a suitable SCL code from Beckhoff or Siemens and rewrite it for Linuxcnc. For example, this one:
VAR
    // PDO mapping inputs (from the drive)
    wStatusword : WORD; // 0x6041
    iActualMode : SINT; // 0x6060
    // PDO mapping outputs (to the PLC)
    wControlword : WORD; // 0x6040
    iModeOfOp    : SINT; // 0x6060
    // Control / Monitoring
    bStartHoming : BOOL;    // Trigger
    bHomingActive: BOOL;    // Status
    bHomed       : BOOL;    // Target reached
    bError       : BOOL;    // Monitoring: Error
    iState       : INT := 0; // Step chain
    // Monitoring: Timer
    fbTimeout : TON;
END_VAR
// --- Read status bits from status word (0x6041) ---
// Bit 12: Homing process running / successful (depending on method)
// Bit 13: Homing error
// Bit 10: Target reached (often used during homing)
bHomingActive := (wStatusword.12); // Homing operation in progress
bHomed        := (wStatusword.12) AND (wStatusword.10);
bError        := (wStatusword.13); // Homing error
// --- Monitoring (timeout) ---
fbTimeout(IN := bHomingActive AND NOT bHomed, PT := T#10S);
// --- State machine for homing (CiA 402) ---
CASE iState OF
    0: // Wait for start
        IF bStartHoming AND NOT bError THEN
            bStartHoming := FALSE;
            iState := 10;
        END_IF;
 10: // Set mode of operation to “Homing” (6)
        iModeOfOp := 6;
        IF iActualMode = 6 THEN
            iState := 20;
        END_IF;
    20: // Set drive to “Operation Enabled” (standard CiA402 state machine)
        // Simple example: Set control word to 0x0F (Enable)
        wControlword := 16#000F;
        IF (wStatusword AND 16#006F) = 16#0027 THEN // Ready to operate
            iState := 30;
        END_IF;
    30: // Start homing: Set bit 4 in control word (start homing procedure)
        wControlword := 16#001F; // Bit 4 high, enable op
        IF bHomingActive THEN
            iState := 40;
        END_IF;
        IF fbTimeout.Q OR bError THEN iState := 999; END_IF; // Monitoring
    40: // Wait for completion
        IF bHomed THEN
            wControlword := 16#000F; // Reset homing start bit
            iState := 0;
        END_IF;
    999: // Error state
        // Error handling: Cancel homing, set message
        wControlword := 16#000F; // Stop
        bError := TRUE;
        IF NOT bStartHoming THEN iState := 0; bError := FALSE; END_IF;
END_CASE;
  • Hakan
  • Hakan
15 Feb 2026 16:48 - 15 Feb 2026 16:50
Replied by Hakan on topic XHC WHB04B development?
Had a session with a lot of mode shifts, auto programs, manual and mdi and not being careful when mode shifting.
Worked great, it felt like there was no problem with the xhc.
I had checked autosuspend which was set to 2. Set it to -1 and the disconnect/connects in syslog stopped.
Finished after a few hours. Checked syslog and now the xhc is just laying there doing nothing on the milling machine.
The faint light is on, that's all. And the syslog fills with new disconnect/connects. Every 10-20 seconds it happens.
autosuspend was already set to -1.
Went to the milling machine and turned off the pendant. New disconnects/connects stopped coming in syslog.
Didn't touch the usb dongle during the whole day. The pendant causes the disconnects? When idle?
  • PCW
  • PCW's Avatar
15 Feb 2026 16:30
Integrating a BCL-AMP capacitive sensor to LinuxCNC
Category: Plasma & Laser
That entirely depends on your scaling.
On way to check is to monitor the "plasma_voltage"
 and determine the threshold  for the fake Ohmic sense point.
  • Nathan40
  • Nathan40
15 Feb 2026 15:56
Thanks for the reply.
For the 930000, fake ohmic sensing are we expecting the voltage value to around 15500.
Please let me know
  • turbohoolik
  • turbohoolik
15 Feb 2026 15:35
Replied by turbohoolik on topic Soft limits are not working all the time...
Category: Basic Configuration
Found my problem, the problem was me!
My soft limits were further away than hard limit switches. Why I was set it up like this, I have no idea...
Thank everybody for thinking with me!
  • PCW
  • PCW's Avatar
15 Feb 2026 15:15
If you do not, you will have a huge offset that would have to be compensated
by using a similar setpoint. If you use the 22900 offset, you will now have
a 0 to 1000 active range ( if scale = 1)
15 Feb 2026 14:44
Replied by tommylight on topic socket raw Eth.
socket raw Eth.
That was me, i did check and it was the same post, and at the time the post here was not deleted.
Sorry for the inconvenience.
  • Marcos DC
  • Marcos DC's Avatar
15 Feb 2026 14:12
Category: EtherCAT
Good point about the homing bits being mode-specific / poorly documented. I initially mentioned bit12 as an example, assuming we’re aiming for a generic solution, but that’s clearly not something we can rely on.
I think the right approach is to keep the core logic generic (state machine + timeouts + progress watchdog), and make the actual homing status (done/active/error) configurable per drive, e.g. via masks on 0x6041.
While internal homing runs, keeping pos_cmd slaved to pos_fb still seems necessary to avoid the jump when control is handed back.
With that, A6 becomes just one mapping, not a special case baked into the algorithm.
  • MRx
  • MRx
15 Feb 2026 13:38
Disconnects might be caused by multiple reasons.
a) poor xhci support for that system - try to connect the pendant to a USB 2.0 port
b) check if USB autosuspend is disabled (as root)
cat >/sys/module/usbcore/parameters/autosuspend
echo -1 >/sys/module/usbcore/parameters/autosuspend
c) if connected to a USB hub - don't do that, connect it directly
d) EMI issues, check if there's a pattern that can trigger this, check if a relay is able to disconnect it somehow; I had HDMI displays resetting due to issues with relays a decade ago (eg. missing flyback diodes)
I worked on the XHC pendant some years ago to fix some issues, I never had disconnect issues with it.
Displaying 6946 - 6960 out of 12579 results.
Time to create page: 0.324 seconds
