  • Hakan
  • Hakan
15 Feb 2026 06:11
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
generic is the right choise.
There used to be a performance difference between generic and say the igb driver.
But not anymore, I always use generic even if I could use igb or igc.
I upgraded to 2.9.8 on a test system and initially saw the same problem you have.
Then I rebooted and made too many things to remember and then it worked again.
So I can only recommend to reboot and cycle the power of the ethercat units.
If that doesn't work, go back to 2.9.5 or try 2.9.8 iso.
Your settings from before is fine.
  • cmorley
  • cmorley
15 Feb 2026 05:51
Replied by cmorley on topic Control panel
Control panel
Category: Show Your Stuff
Is that a custom keypad now?
Looks good!
  • Marcos DC
  • Marcos DC's Avatar
15 Feb 2026 05:10
Technical questions about CIA402 and homecomp.comp on A6
Category: EtherCAT
While waiting for Andrax’s view, IMHO for a generic CiA402 setup there’s no standard “homing started” bit, so I’d supervise it with two simple triggers/timers.
I’d start the overall homing timeout when the drive actually confirms Homing mode (6061 == 6). Then, when we assert the homing start (opmode-specific, e.g. the bit-4 flip after 6061 confirms), I’d start a short “start→motion” watchdog and look for real motion as proof (e.g. |6064 - pos0| > eps, or 606C > threshold).
  • rodw
  • rodw's Avatar
15 Feb 2026 04:23
Category: EtherCAT
@rodw Yes, I would have implemented it in the same way in a PLC. The only thing missing is the safety timer from start homing to axis in motion. Then the homing would be practically monitored. Regarding the axis jumping, you could set the feed rates to minimum after completion until Linuxcnc has synchronized.
Can you explain this timer? I would have thought you get the homing signal from linuxcnc, pass it on to the drive then  loop until bit 12 goes true keeping lcnc in sync.. I can't remember off the top of my head how we check that the homing request has actually stuck but I seem to remember we could do this too before doing the loop. Bit 13 will tell us if there is an error during homing.
  • grandixximo
  • grandixximo's Avatar
15 Feb 2026 04:14
Category: EtherCAT
I think after you upgrade your linuxcnc, you might want to build a compatible version of linuxcnc-ethercat
and check your settings
with your hardware generic is inevitable, it is not supported, performance will not be guaranteed. I should look at getting hardware that already has support from IGH
like intel igc or intel igb
but I never got eoe to work, so you are already ahead of me on that front, so I might be just blabbering nonsense...
  • rodw
  • rodw's Avatar
15 Feb 2026 04:11
Category: EtherCAT
rodw, I kind of think of a structure like this
if drive ready
  if csp
  else if csv
  else if pv
  else if probing
  else if homing
     if homing_method == 1
     else if homing_method == 2
     else if homing_method == 37
        Do the torque homing. Although it doesn't seem to be standard
Keep track of what op-mode we were in last time so we recognize a transition
between op-modes. To deal with offsets and such things.
Great feedback I wasn't really happy with what came after the state machine but I've had to put this project down for a week or so and you forget everything when its so complex.
  • NWE
  • NWE's Avatar
15 Feb 2026 04:07
Replied by NWE on topic Electrical Contactors/Relay Help?
Category: Milling Machines
I know that some contactors are mechanical so going higher amps increases service life and solid state contactors are heat limited but why would companies state that such a high overage is needed?
Frankly, I'm a bit puzzled where that 5-10x safety factor recommendation comes from. A quick google search shows me 1.25x and 1.5x safety factor recommendations. I tend to go for a 1.5x safety factor, in more extreme duty conditions I've done 2x or 3x. A big contactor killer is frequent start/stops. I can imagine 10x might be used in some special applications.
  • PCW
  • PCW's Avatar
15 Feb 2026 03:06
Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
Category: Driver Boards
The 7I76EU is compatible with 7I76E hal/ini files, so you can
just select "7I76E" in pncconf.
  • Lcvette
  • Lcvette's Avatar
15 Feb 2026 03:03
Probe Basic Tool Setter touch off pos Y not set
Category: QtPyVCP
If you have usb, you can update with Deb files
  • Lcvette
  • Lcvette's Avatar
15 Feb 2026 03:01
Category: QtPyVCP
Run another update i think your on the faulty commit. Should be resolved now, stable is now 0.6.5
  • Nathan40
  • Nathan40
15 Feb 2026 02:41
Integrating a BCL-AMP capacitive sensor to LinuxCNC
Category: Plasma & Laser
Does this value always needs to be equal to the min value? Please help, thanks.
  • Pupy1993
  • Pupy1993
15 Feb 2026 02:13
Hello.
I'm new in this form. I couldn't config my Mesa Card 7i76EU, the PncConf doesn't show the 7i76eu. I'm using Linux CNC 2.9.8. Thanks in advance.
  • Looby
  • Looby
15 Feb 2026 01:54
Replied by Looby on topic Electrical Contactors/Relay Help?
The two 120v ins is more just because I think I will overload a single 120v outlet so trying to split the loads to different circuits. It SHOULDNT but really dont want to wire this whole thing and THEN find out. This is unfortunately a "mobile" setup that I have to load up and take to and from work as I cannot run a router like this in my apartment so I am also making some allowances for portability in this setup so both plugs will be detachable from the unit to ensure power safe if needing to work inside the box. All of this is going in a rolling road case... Yes I know sketchy sketchy sketchy but.... nah no buts I know its sketchy.
  • grandixximo
15 Feb 2026 01:45
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I will have YangYang take a look after the holidays, thank you for testing.
We are on a Chinese new year brake for a couple of weeks.
I'm still working on Planner Type 2, will see what YangYang thinks after the holidays, hopefully Rob will also do some testing
  • NWE
  • NWE's Avatar
15 Feb 2026 01:36
Most contactors list a thermal current rating and an inductive current rating, if your load is less than those current ratings you're fine.
I usually use 30A contactors for 20A loads... just oversizing a bit for good measure.
Not sure about two power sources, are both going to the same box? I try to avoid that. It can cause accidents if someone disconnects one power source and starts working on it. If two power sources to one box is unavoidable, label the cover with a warning label stating the box is powered by more than one power source.
If the two 110V power inputs shown are going to separate boxes, I think it should be fine.
Displaying 6976 - 6990 out of 12579 results.
Time to create page: 0.276 seconds
