  • Finngineering
  • Finngineering
05 Feb 2026 14:56
Replied by Finngineering on topic XHC WHB04B development?
I consider having to restart LinuxCNC unacceptable. If I don't find a better solution, I will not use this pendant.
The rotary knob sounds more like a configuration issue(?). Have you checked if you see the position switch changes by running "xhc-whb04b-6 -a" from a terminal?
  • HexaCube
  • HexaCube
05 Feb 2026 14:44
Replied by HexaCube on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
Greetings Mark!
First of all, excellent work on the retrofit - this thread will end up being a literal goldmine for me.
Last week I also purchased a 1986 MH400E and the goal is to convert the machine to LinuxCNC in the coming few months.
Somewhere in this thread I saw that you have a 'collection of notes' for your conversion - is there any way to get these from you? I can't seem to find an email-adress available on your YT Channel as previously stated.
I haven't quite had the time to work through all 180 pages, but I do have a quick question:
How is the gear-changing generally handled? Do you have to command an exact speed value, or will LinuxCNC pick the correct gear for whatever arbitrary speed you command?
Also, will the gear-change happen automatically whenever a speed is commanded, or is there specific codes that need to be ran (I would love to use the F360 CAM and I wonder if linuxcnc will handle selecting the speed automatically, or if I need to fiddle around with the post-processor?)
Thanks and very best regards from Germany
Daniel
  • rodw
  • rodw's Avatar
05 Feb 2026 12:52
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
If the drive is reducing the speed by itself you will get following errors.
Otherwise it's the settings in the ini file that are throttling the speed.
Yeh, that's what I have been playing with to determine where to set max velocity. I remembered from when I set up my plasma on a Mesa card to see how much of its 10 Mhz bandwidth I could use that there was a physical limit to how fast you could step in the real world. That's why I cut back the settings here. The design target was 10240mm/min so it fell a bit short, But the RPM is still quite respectable. I've had enough for one night.
I also might try increasing the amps a bit too
  • Hakan
  • Hakan
05 Feb 2026 12:31 - 05 Feb 2026 12:32
Replied by Hakan on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
  • rodw
  • rodw's Avatar
05 Feb 2026 12:22
Category: EtherCAT
So I had this theory that at default 10000 steps/rev it was running out of bandwidth when it got to 2000 mm/min (400 rpm). S0 I changed the steps to 1000 steps/rev which I assumed might get me to 10 x 2000 = 20000 mm/min
This let me get up to 8500 mm/min maximum velocity. But It did not get me to the expected 20000 mm/min (10 x 2000)
So definitely reduce the steps/rev if top end speed is important to you. I think you'll need to tweak the steps/rev to suit your design parameters.
  • unknown
  • unknown
05 Feb 2026 11:44
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Looks like the Trixie issues repo got nuked, does anyone know what happened?
Mental health issues.
  • Ismacr63
  • Ismacr63
05 Feb 2026 11:29
Replied by Ismacr63 on topic T3D-L20A-RABF configuration help
Category: Turning
Today I was able to get the spindle to rotate, but I've encountered two new problems. While the DI4 wire is connected to pin 16 of the bobbin to reverse the spindle's rotation, it always remains reversed, regardless of whether pin 16 is activated or deactivated. I checked with the HAL meter, and pin 16 is working correctly. I also measured with a multimeter, and when it's activated, it reads 0V, and when it's deactivated, it reads 5V, but the spindle always rotates in the same direction. Interestingly, when I disconnect the reverse wire from pin 16, it rotates in the correct direction, and if I reconnect it, it reverses direction, but nothing happens from the interface using pin 16.
The other problem is that the RPMs don't match, for example, an M3 S1000. I've tried to correct this unsuccessfully from both the driver and the HAL. I have a 1.58:1 pulley ratio (45mm motor pulley, 71mm spindle). My knowledge of Linux CNC is limited, and I'm not sure where to go from here.
I'm not sure if I've explained myself clearly. Sorry for my English.
  • andrax
  • andrax's Avatar
05 Feb 2026 11:21
Replied by andrax on topic XHC WHB04B development?
I'm interested.
I also have the problem that the connection disconnects after a while. For me, however, it's enough to close LCNC, disconnect the dongle, and reconnect it.
I'm interested in the feed setting of the rotary knob button.
This doesn't work; only the increments can be set. I was only able to solve this with a workaround.
  • Finngineering
  • Finngineering
05 Feb 2026 11:00
XHC WHB04B development? was created by Finngineering
Is anybody interested in some development for the XHC WHB04B pendant? Both from a user perspective, but also with the development itself.
I bought a WHB04B-6 to use with my mill, thinking it should work okay. But of course there are issues. After a while, it disconnects and I have to restart LinuxCNC to get it back working.
I have already went quite deep with this, and have some and can generate more material:
 - USB packet captures with Wireshark (form both LinuxCNC and Mach3)
 - USB signal capture with logic analyser
 - WHB04B transmitter firmware
 - RF signal capture
One thing I noticed with the xhc-whb04b-6 component in LinuxCNC is that is has some blocking wait states. These can delay the USB polling of the WHB04B so much that it causes the device to reset. I fixed that (for myself), but still there are issues...
There are several possibilities:
 - improve the xhc-whb04b-6 component
 - create a new driver/component for the pendant, realtime if seen necessary
 - create a new firmware for the WHB04B transmitter, possibly also for the pendant itself
Any comments or thoughts from the community?
I guess many have the opinion that both wireless and USB pendants are a no go. Personally I don't see an issue at least for "garage application", provided its properly implemented. The main thing would be to have a watchdog monitoring the communication, which can (e)stop the machine if necessary.
  • Nkbhvid
  • Nkbhvid
05 Feb 2026 09:27
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Here is pwm.txt - only analog=0
File Name: pwm.txt
File Size:1 KB
  • rodw
  • rodw's Avatar
05 Feb 2026 09:20 - 05 Feb 2026 09:20
hal.h in install image different then hal.h in github?
You need to checkout the correct branch. The release versions are defined by a tag dso that are locked in. You can see this in git on the branch drop down if you select the tag tab. This will let you see the exact source for the version you have.
to get the source of 2.9.8 on your pc its  :git checkout v2.9.8
  • rodw
  • rodw's Avatar
05 Feb 2026 09:09
Category: EtherCAT
Are the settings only possible through their software?
There are no SDOs for setting such things? Like Rtelligent has?
Yes there is. I will load the sdo docs on my NAS later, Seems like the app gives you access to all the SDOs and you can save them to a text file for later reimport so if you had a few of these drives it would be easy. The sdo docs sometimes have a better description.  You could make these settings from the command line using the ethercat app without putting in your XML. They show as bring Read/Write so hopefully they can be accessed when homing.eg reduce motor power when homing
  • Hakan
  • Hakan
05 Feb 2026 08:43
Category: EtherCAT
  • rodw
  • rodw's Avatar
05 Feb 2026 08:14
Category: EtherCAT
found it! I hope. More in a minute!
@hakan Yes, I experimented until I got a max velocity of 2000 mm/min which was roughly 400 rpm! So no fb when homing is not fixed. That I want to sort out. I'll stay on this config until I work this drive out
@NWE In the windows config program Plug it into the USB on the drive. It is safe to leave plugged into Linuxcnc (check thw com port in Device manager) before ruunning the software.
There was a setting  #25 PA_055 "The percentage unit of current of the lock machine" was set to 40%. Changed it back to 100%
I had previously set the current #21 PA_051 to 2 amps (2000 mA) so it did not have much) So now I will play with max velocities now to confirm its what I think it is.
  • Hakan
  • Hakan
05 Feb 2026 07:55
Category: EtherCAT
Nope, design a machine instead.
Displaying 7456 - 7470 out of 12622 results.
Time to create page: 0.482 seconds
