  • skunkworks
  • skunkworks
23 Jul 2025 18:06
Display motion.current-vel ? was created by skunkworks
Category: Plasmac
Am I missing it?  Is there a way to display the current velocity of the machine while cutting?
Thanks!
BTW - Just setup Plasmac using pncconf - It was painless and QTPlasmac is a really nice gui.   No problems..  (mesa style board with thc10)
Great work!
sam
  • Cerezas
  • Cerezas
23 Jul 2025 16:38
Inverting jogging sense of X Axis on a VistaCNC P1A-S pendant
Category: HAL
Since this is for a lathe, there are only 2 joints in the HAL parameters. LinuxCNC requires that the joints are numbered from 0 consecutively, that is, I can only have joints 0 and 1. The association between joint 1 and the z axis is done in the HAL files. With that association, GCode works properly.
As I mentioned before, the pendant was jogging the X axis as I wanted in Step, Velocity and Continuous mode before I moved to the mesa card. I was using exactly the same vc-p1as.hal file as the one I'm trying to use now. Something very subtle changed and that's what I'm trying to figure out.
I tried debugging with halmeter and see what signals were triggered when I used the pendant, but that didn't help much. I'm still learning about the HAL.
Thanks once again for looking into this issue.
  • PCW
  • PCW's Avatar
23 Jul 2025 16:03
Replied by PCW on topic How to control brake before moving ?
Category: HAL
The gcode (M62,M63,M66) method with digital I/O will work for any motion but you need to change the gcode.
  • bladekel
  • bladekel
23 Jul 2025 15:35 - 23 Jul 2025 15:40
Replied by bladekel on topic How to control brake before moving ?
Category: HAL
The intended use is for indexing rotaries as described in this section:
linuxcnc.org/docs/stable/html/config/ini...:ini:sec:axis-letter
If you need more than just G0 moves then you would likely need to make something up in HAL.
I can only control the brake with G0 moves.
here is the way;
[EMCMOT]
EMCMOT = motmod unlock_joints_mask=0x08
[AXIS_A]
LOCKING_INDEXER_JOINT = 3
[JOINT_3]
LOCKING_INDEXER = 1
I have to control the brake for G0,G1,G2,G3 and manuel movements. Because that axis' motor has mechanical brake.
In any type of movement, brake is have to be deactivated and after the movement it has to be activated again.
Do you have any opinion else ? What else I have to try?
  • Aciera
  • Aciera's Avatar
23 Jul 2025 15:23
Replied by Aciera on topic How to control brake before moving ?
Category: HAL
  • RotarySMP
  • RotarySMP's Avatar
23 Jul 2025 14:42
Replied by RotarySMP on topic Un-lobotomizing a Maho MH600T
Category: CNC Machines
Nice work you have done on that DIY EXE, with DIN rail mounting.
  • jjdege
  • jjdege's Avatar
23 Jul 2025 14:18
Replied by jjdege on topic Axis and tool length sensor troubles
Check the Z travel to reach the probe in the .ini file.
[TOOLSENSOR]
MAXPROBE = XXX
  • JT
  • JT's Avatar
23 Jul 2025 13:32
Replied by JT on topic Is mini still available?
Category: Other User Interfaces
buildbot.linuxcnc.org/dists/
is debs you can see if your OS is there and 2.7 is built for that OS version.
JT
  • JT
  • JT's Avatar
23 Jul 2025 12:30
  • Walkahz
  • Walkahz
23 Jul 2025 12:10
User tabs file missing probe basic was created by Walkahz
Category: QtPyVCP
In the process of setting up prprobebasic on my machine, coming from gmoccapy.
have configured as per the help files however am getting a error saying the file path for user tabs is missing (refer image)
any ideas what I may have missed?
  • JT
  • JT's Avatar
23 Jul 2025 11:58
Mini was depreciated in LinuxCNC 2.7.
You could make a similar GUI using Flex GUI.
gnipsel.com/linuxcnc/flexgui/index.html
JT
  • Billiiles
  • Billiiles
23 Jul 2025 09:13 - 25 Jul 2025 09:19
Replied by Billiiles on topic Axis and tool length sensor troubles
Hi all
After a couple of years, I am finally back and ready to making chips. I have a router, use steppers on parport. Linuxcnc is 2.9.4, debian doodle jump :
Linux cnc0 6.1.0-35-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.137-1 (2025-05-07) x86_64 GNU/Linux
The router works, I can cut stuff etc. not the problem. The job that I want to do soon requires quite a few tool changes. So far I did it using the dowel method, but that is very time consuming. Sure an automatic tool changer would be perfect, but that's up for in a later stage. For now I have a tool length sensor, that I would like to use with my collet spindle to get tool length set after a manual tool change.
When I run tcdemo.ngc:
- goes to change position
- when I hit "Tool change complete", goes to zmax, tool sensor x and y, starts going towards the sensor.
- As soon as the sensor is touched, I get "Probe tripped during non-probe move" and program is stopped
How can I get over this?
I attach the relevant files in zipped folder "toollength_problem.zip"
Greez
chris
You might want to double-check that the
G38.x command is active before motion toward the sensor begins. Also, review your HAL and INI files to confirm the probe input isn't being tripped by noise or an early signal. Did you try adding a small delay before the probe move to stabilize the signal?
  • bladekel
  • bladekel
23 Jul 2025 09:02
Category: HAL
Maybe have a look at the 'joint.N.unlock' pins:
linuxcnc.org/docs/html/man/man9/motion.9...OINT%20unlock%20pins
It seems to work for me.
Is there any example for unlocking an axis?
  • cadcam
  • cadcam
23 Jul 2025 07:45
Replied by cadcam on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Does anyone have lathe working?
Run - python3 ncam and mill loads
Run - python3 ncam -c lathe and get the attached errors
  • Aciera
  • Aciera's Avatar
23 Jul 2025 05:07
Displaying 11866 - 11880 out of 17299 results.
Time to create page: 0.432 seconds
