  • cakeslob
  • cakeslob
07 Jul 2025 23:36
Replied by cakeslob on topic Potential All-in-One Single Board Computers
almost. I dont have support for SPI SD card that they use on the manta just yet.
  • Benb
  • Benb's Avatar
07 Jul 2025 22:48
Replied by Benb on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
LinuxCNC froze! That’s the first time I’ve ever heard of that happening. In your case, since it’s a plasma machine, the risk of harm is relatively low when the control system locks up. But if this had occurred on a large machine, it could’ve been disastrous. That’s exactly why I always advocate for an external hardwired E-stops which are fail-safe and operate independently of the software layers. Relying on on-screen gui emergency stops or and wireless pendant estop are inherently unsafe, as they can create a false sense of security. As you experience shows, you could not stop the machine and you had to reboot the computer.
  • Lcvette
  • Lcvette's Avatar
07 Jul 2025 22:14 - 07 Jul 2025 22:20
Replied by Lcvette on topic Probe Basic Screen missing axes
Category: QtPyVCP
Also, anytime you update if there is something missing in probe basic using your machine config on program open, check the probe basic simulation from within the linuxcnc sims. It will always have any updated requirements performed. If the sim opens and appears normal, then it's a safe bet that  it's your machine configuration requiring new updates. We put information right on the status page that is updated with new releases with a link to any requirements due to upgrades in probe basic.  Always start there.
  • Lcvette
  • Lcvette's Avatar
07 Jul 2025 22:07
  • Marko6
  • Marko6
07 Jul 2025 21:12
HAL CiA402 Drive Interface for Can Bus,Ethercat etc...
Category: HAL
Hi. Yes, but no.
Speed tutorial is there but its just procedure what to send to drive. I have no clue how to implement that to Linuxcnc.
 Thank you.
  • PCW
  • PCW's Avatar
07 Jul 2025 20:53
7i77 lost connection while encoder counts (PREEMPT-RT)
Category: Driver Boards
Looking around, this may be a Ryzen/kernel version issue.
  • PCW
  • PCW's Avatar
07 Jul 2025 20:42
Best HAL function 2 contol bits for S32 in, 1 of 4 out?
Category: HAL
Typically this is done by by connecting the MPG count to all axis
and selectively enabling jogging on the desired axis
  • PCW
  • PCW's Avatar
07 Jul 2025 20:38
Replied by PCW on topic Grizzly G1006 with Servos
Category: Show Your Stuff
Yes.  That's the idea.  I have a 7i96s already mostly wired.  I spent much of this weekend working on getting the configuration setup, using pncconf.  Only to find that Claude (online AI) led me astray.  I should have been using stepconf.  Or even better... MesaCT.
pncconf and MesaCT can both create 7I96S configurations, stepconf cannot (stepconf is for parallel port hardware)
  • unknown
  • unknown
07 Jul 2025 20:37
Failed Parallel Port on system, Recommended Easiest Upgrade Solution ?
To tell the truth I'm not a big fan of Rufus, it tries to be too smart by far.
When I had to create bootable USB stick via windows I always used win32diskimager.org/
Or if using Linux
dd
does the job fine, askubuntu.com/questions/1333102/what-is-...-hard-drive-over-usb
  • marked23
  • marked23
07 Jul 2025 20:25
Replied by marked23 on topic Grizzly G1006 with Servos
> Why not just use it as-is?
  • I don't have a license for Mach3
  • I prefer to use Ethernet
  • I'm removing Windows from all my computers, before October.
  • LinuxCNC does not fit on the old computer.
The PMDX board and the pendant will be repurposed for a Sherline from the same guy.  The CPU is barely practical, but I'll give it a try for that Sherline. When that 22 year old hard drive dies, that's the end of that too.
> Maybe just put a mesa board in place of the PMDX
> ... wire the drives directly to Mesa
> Does it work fine right now?
Who knows? It was working fine in 2009, when it was last used. Yes, the servos move. I can't yet try the spindle until I put in a new electrical circuit.  My garage has one outlet, shared with the lighting and garage doors. And my breaker panel is full.
> What is that IPAC board?
It takes commands from button presses on the pendant, and injects them into the keyboard communication. Then you run Mach3 with keygrabber so that the pendant buttons are captured and sent to Mach3.  There are two ps/2 keyboard ports on the IPAC.  One goes to the computer, the other to the keyboard.  (Which is a real IBM M1... precious metal to me.)
> He obviously took pride in his work.
Yeah.  I was surprised he didn't use more off-the-shelf options. Learning and building was his joy, so that makes sense.
>Why change something so neatly and carefully made?
I can't make use of the pendant because the new computer doesn't have any parallel ports, and the pendant needs its own parallel port.
The servo control box will look exactly as it does, except the PMDX board will be swapped out for a Mesa 7i96s.
  • slowpoke
  • slowpoke
07 Jul 2025 20:21
Category: HAL
I have two rotary switches, each switch has 2 outputs driving inputs on a MESA card as 00,01,10,11
Switch #1 is used to select MPG increment 0, 0.0001", 0.001", 0.01"  I'm using a MUX4 to control that. No problem with this.
Switch#2 is for selection of where the MPG ticks   ( net encoder-counts  <= hm2_7i96s.0.inm.00.enc1-count ),gets routed, so to either:
X, Z, C (Compound), or N(None), so....
axis.x.jog-counts
axis.z.jog-counts
anglejog.counts-in
or to nowhere when position N is selected
  • Hakan
  • Hakan
07 Jul 2025 20:18 - 07 Jul 2025 20:22
Category: HAL
Is that the Delta 2000 CMC-EC01?
There is a manual for download includes a speed demo example.
downloadcenter.deltaww.com/en-US/Downloa...=cdate&sort_dir=DESC
  • TMinj
  • TMinj
07 Jul 2025 20:09
Replied by TMinj on topic Import pin value in handler.py
Category: Qtvcp
It work well using this : self.myPin = QHAL.newpin("MyPin", QHAL.HAL_BIT, QHAL.HAL_OUT)
Thanks a lot for your help
  • lonnox
  • lonnox's Avatar
07 Jul 2025 20:03
pin hm2_5i25.0.write.time did not change anymore.
Suggests this is a PCIE communication issue and probably
not related to 7I77 5V
It may indicate a grounding/EMI issue. Do you have an issue when
the 7I77 in not connected to the rest of the machine?
This is why i asked for a dmesg log as PCIE issues should show up there.
EMI was also one of my suggestions, at the time where the 6i25, 7i77 and the PC was part of the machine, so i decide to use shielded wires between the servos and their drives. Wires from drive to mesa are shielded too.
But the problem was the same.
Now i build a system with only the cards, the pc and rotary encoder but the problem is still the same.
Does dmesg show any errors?
Checked dmesg and there maby we have a track, the problem occur immediately after starting linuxCNC, this is the output:
[ 1323.534393] mce: Uncorrected hardware memory error in user-access at fcb01000
[ 1323.534404] Memory failure: 0xfcb01: memory outside kernel control
[ 1323.534405] mce: Memory error not recovered
[ 1323.534528] mce: [Hardware Error]: Machine check events logged
[ 1323.534532] [Hardware Error]: Uncorrected, software restartable error.
[ 1323.534535] [Hardware Error]: CPU:3 (17:8:2) MC0_STATUS[-|UE|MiscV|AddrV|-|-|-|UECC|-|Poison|-]: 0xbc002800000c0135
[ 1323.534541] [Hardware Error]: Error Addr: 0x00000000fcb01000
[ 1323.534542] [Hardware Error]: IPID: 0x000000b000000000
[ 1323.534544] [Hardware Error]: Load Store Unit Ext. Error Code: 12, DC Data error type 1 and poison consumption.
[ 1323.534546] [Hardware Error]: cache level: L1, tx: DATA, mem-tx: DRD
Is there any PCIE power management enabled in the BIOS?
Indead there was, but i disabled it before doing dmesg.
  • Marko6
  • Marko6
07 Jul 2025 19:56
Category: HAL
Hi everyone. I have made some progress on 3x Lichuan + 1x Delta C2000. Now I am able to measure the speed when the drive is turned on manually. But still no success with the speed command.
I found that the speed command in HAL CiA402 is 60FF and here in Delta it is 6042. I have tried both, but when I set only 6042 in the XML file, I am not even able to turn on the drive.
Any idea? Thank you.
File Name: ethercat-conf.xml
File Size:9 KB
File Name: cia402.hal
File Size:5 KB
File Name: cia402.ini
File Size:5 KB
Displaying 12496 - 12510 out of 17356 results.
Time to create page: 0.761 seconds
