  • PCW
  • PCW's Avatar
05 Jul 2025 16:13
Replied by PCW on topic 7i90hd. Problem with writing bit file
Category: Driver Boards
Hard to tell if this is a EPP interface issue or maybe a Mesaflash problem
Can you try:
Power up on alternate EEPROM (which should have a valid boot sector)
program FPGA via JTAG (NOT FLASH!)
Then try mesaflash again to write a standard EPP bitfile
If this does not work, a temporary workaround (if you are building you own firmware)
would be to write the flash via JTAG
  • ziggi
  • ziggi's Avatar
05 Jul 2025 16:12
Troubles to get started with SD240 Retrofit
Category: Turning
Thank you, I will try and report
Sigi
  • kulek
  • kulek
05 Jul 2025 15:38
Replied by kulek on topic 7i90hd. Problem with writing bit file
Yes. I tryed. Result was the same
  • PCW
  • PCW's Avatar
05 Jul 2025 15:30
Did you try writing one of the standard supplied EPP bit files?
  • phino
  • phino
05 Jul 2025 15:21
Graphical glitches with Raspberry Pi 400 + LinuxCNC 2.9.4 (arm64)
Category: Installing LinuxCNC
The official LinuxCNC 2.9.4 image for arm64 is installed on a Raspberry Pi 400. There are strange partial graphical glitches in browsers, such as some pages or partial horizontal section of the page not displaying properly, while the rest is fine.
This was tested with Firefox ESR, but Chromium was also installed, and for example, the settings page for Chromium never displays properly. It would appear the underlying text and buttons/links are present but not visible, except by sometimes mousing over them.
The problem appears to be only in browsers, not other applications. Youtube in either browser is also unusable, with graphical glitches on the player controls (YT buttons like play/pause/settings are either invisible or look corrupt).
Similarly, when opening PDF documents in browsers, the control buttons along the top of the document for Zoom/Download/Save etc are often invisible, but still present if moused over.
Also, Youtube video playback is extremely laggy, and that is including after removing the isolcpu=2,3 option. The goal on the Pi is just to familiarize with LinuxCNC and set up configs, not to run machines on it, so I'm not too concerned about the latency penalty in this case..
Has anyone else experienced this problem?
  • jmelson
  • jmelson
05 Jul 2025 14:57
looking for advice on retrofitting hydrolic mill
I had an old Bridgeport mill that had had heavy production use. After getting some level of proficiency with it, I was having BIG problems getting things to fit together. So, I'd make some device, and then in a different setup, make a cover with screw holes that were supposed to line up. They didn't! It turned out that the Acme (trapezoidal thread) screws were more worn in the center that at the ends.
This was enough so that there was a large positioning error when moving from one end of the screw toward the middle.
Tommy, so this machine has ONE servo motor and clutches to the various leadscrews? I've heard of such machines, but never seen one. That does kind of match the amount of electronics in the thing.
Jon
  • kulek
  • kulek
05 Jul 2025 14:56
No it does not.  After unsucsessful firmwareI  I tried to boot from the second EEPROM (W3 in the low position). But Mesaflash not founded 7i90 and 2 leds glowed ( power and int ) opposit to 3 in first case.
  • PCW
  • PCW's Avatar
05 Jul 2025 14:47
Category: Turning
Looks basically ok
Maybe the machine does not think its homed
You should be able to jog without homing by adding
the joint jog pins:
# ---Handrad-Signale zu Mesa Encoder - shared MPG---
net axis-selected-count <= hm2_7i80.0.encoder.03.count
# ---mpg signals---
# for axis x MPG
setp axis.x.jog-vel-mode 0
net selected-jog-incr => axis.x.jog-scale joint.0.jog-scale
net axis-select-x => axis.x.jog-enable joint.0.jog-enable
net axis-selected-count => axis.x.jog-counts joint.0.jog-counts
# for axis z MPG
setp axis.z.jog-vel-mode 0
net selected-jog-incr => axis.z.jog-scale joint.1.jog-scale
net axis-select-z => axis.z.jog-enable joint.1.jog-enable
net axis-selected-count => axis.z.jog-counts joint.1.jog-counts
sets selected-jog-incr 1.000000
05 Jul 2025 14:37
Replied by tommylight on topic Rote LED
Rote LED
Category: Deutsch
Was gibt beim
ip a
in terminal?
  • PCW
  • PCW's Avatar
05 Jul 2025 14:32
Does the alternate EEPROM still have a valid image?
(that say mesaflash --readhmid works with)
  • PCW
  • PCW's Avatar
05 Jul 2025 14:25
Replied by PCW on topic [Solved] Mesa 7i96 Spindle PWM
Sorry, attached the wrong file...
This should be right:
File Name: 7i96d_2pwm.zip
File Size:105 KB
  • Edi_48
  • Edi_48
05 Jul 2025 13:39
Replied by Edi_48 on topic Rote LED
Rote LED
Category: Deutsch
Neues Kabel gleicher fehler
-- 10.10.10.10 ping statistics ---
60000 packets transmitted, 59993 received, +6 errors, 0.0116667% packet loss, time 60036ms
rtt min/avg/max/mdev = 0.054/0.110/0.313/0.031 ms, pipe 12
05 Jul 2025 11:42
Replied by tommylight on topic looking for advice on retrofitting hydrolic mill
Those Maho's are already CNC from the factory, meaning they have motors on each axis and have ballscrews, so very easy to retrofit.
  • timo
  • timo
05 Jul 2025 10:42
Servo Zentralantrieb in allen drei richtungen
means
central (single) servo drive for all 3 directions
So not hydraulic, but the tool lock is hydraulic, both for horizontal and vertical head.
In short, retrofitting to full CNC would require removing the central drive and gearbox and adding motors to each axis on the hand crank, most probably.
Also, normally, this type of machine uses trapezoidal screws and brass nuts, so have a lot of backlash, that can be fixed in software to a certain degree, but do not expect much precision.
Displaying 12571 - 12585 out of 17374 results.
Time to create page: 0.367 seconds
