  • Aciera
  • Aciera's Avatar
12 Jun 2025 06:15
  • spincycle
  • spincycle
12 Jun 2025 05:57
Replied by spincycle on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Alrighty!
Drives and motors arrived. Setup a bench test rig.
I've made it as far as getting the encoders to read in LCNC (scale seems right). Unfortunately I'm getting following errors when I try enabling the drive. I can hear the drive enable relay latch very briefly.
I've followed Tommylights guide, but can't get too far when it errors straight out of the gate. Im also getting a "could not switch machine on, is limit switch activated". I currently have no IO assigned.
I suspect my wiring is at fault or I'm really missing the mark with my initial PID numbers - I've tried a bunch so far, even with giant max f errors.
Schematic below. Any thoughts would be greatly appreciated!
Thanks,
J
  • jimmyrig
  • jimmyrig
12 Jun 2025 05:52
How many uncoordinated axis can linuxcnc drive?
So we have the 9 normal ones.....problem is I need 16axis total.
Found a machine that needs a new controller and peaked my interest on how would I do it..... It has 20ish stepper motors on it
It's a machining version of a progressive stamping die. Where 4 drills and a tap station are positioned into place via steppers than ran pneumatically after that. Thus most of the axis are used at the start of the program... after that they aren't used. These do have working homing switches.
A saw, bar feeder, bar magazine, and prob the tap station are the things that need live axis/gcode control..... But none of the axis needs to be coordinated As everything fires (drill, tap, saw) then the bar feeder advances one station.
The lame way would be to have 8 solenoids (3PDT) connect the step, direction, and home switch pins for each of those 4 drills (2 axis each), then home and position it. So all 8 axis could be "one axis" in software..... Seems complex.
Surely a software solution exists. Custom M code?
Will use gcode for as much as possible but not opposed to Python or hal scripts.
  • kubes
  • kubes
12 Jun 2025 04:12
Connecting a tool setter and touch probe at the same time
Thanks, and to confirm both tool setting and probing use "probe-input"?
If so, then I am considering using mux2 and utilizing M64 and M65 to select which digital input the tool setter and digital probe are connected to.
  • Lcvette
  • Lcvette's Avatar
12 Jun 2025 04:10
Replied by Lcvette on topic Jog Increments based on G20 or G21
Category: QtPyVCP
INCREMENTS = 1 mm, .5 in, ... - Defines the increments available for incremental jogs. The INCREMENTS can be used to override the default. The values can be decimal numbers (e.g., 0.1000) or fractional numbers (e.g., 1/16), optionally followed by a unit (cm, mm, um, inch, in or mil). If a unit is not specified the machine unit is assumed. Metric and imperial distances may be mixed: INCREMENTS = 1 inch, 1 mil, 1 cm, 1 mm, 1 um is a valid entry.
From the docs. I don't think you can change on the fly since it in the initialization file. I could be wrong, but you can mix and match to suit your needs. I rarely use any besides the fine feed. Could probably get away with 4 units, jog, mm, mm, in, in
  • kubes
  • kubes
12 Jun 2025 04:03
Replied by kubes on topic Jog Increments based on G20 or G21
Category: QtPyVCP
Thanks.
I want to jog in inch increments when in G20, and have it change to mm increments when using G21. Similar to the DRO when it changes.
  • Lcvette
  • Lcvette's Avatar
12 Jun 2025 03:57
Category: QtPyVCP
Yes you can have either in or mm to specify what is displayed.
  • DMNZ
  • DMNZ
12 Jun 2025 03:49
Replied by DMNZ on topic Pentium J2900 fanless pc test results
the internal wifi card sits on the same pci bus as hard-drive and ethernet, so its driver can easily throw a wrench into the latency. I could probably just blacklist its driver in grub from loading, but i chose to completely remove it.
yes, sudo apt install r8168-dkms will work fine if you have your controller connected to the internet. I did not, so i used that command to build realtek 8168 driver on a virtual machine connected to the internet. (which in fact is just one file called r8168.ko) then i copied this file over to the controller using usb stick and manually replaced the default driver.
I don't plan to upgrade the kernel any time soon, so this approach works for me.
  • cmorley
  • cmorley
12 Jun 2025 03:38
  • PCW
  • PCW's Avatar
12 Jun 2025 03:08
chinese AC servo 17-bit encoder question
Category: CNC Machines
A high resolution encoder allows better velocity feedback
so you don't get "crunchy" feedback/motion at low speeds.
This is especially important with absolute encoders as you do
not get time stamps of count events like you can with normal
quadrature encoders.
Returning the encoder count to LinuxCNC if the drive has local
feedback is mainly useful if the feedback is from linear scales.
  • Boogie
  • Boogie
12 Jun 2025 02:56
Gents,
have a question on those famous cheapish AC servos form Aliexpress. Most of them are 17-bit absolute encoders. Correct me if i'm worng - this means it has 17-bit resolution per revolution? 1 / 131072. What for? is there any advantage of having such a big resolution per rev? i can imagine belt drive involed in drive - the slightest tension change in the belt under load will lead to position vs command discrepancy and force the motor to react. I think it will make the system nervous unless you set some parameter like dead band - but then why use such a big resolution?
Have anyone of you used those servos with Mesa cards and used encoder feedback from driver to Mesa?
Bit confused.
  • unknown
  • unknown
12 Jun 2025 01:59
Replied by unknown on topic WiFi Problem on Raspberry Pi
What material is the enclosure ?
  • tivoi
  • tivoi's Avatar
12 Jun 2025 01:22
Spindle atc hsk32 used for sale was created by tivoi
Category: User Exchange
Spindle model SW100
MAX power(kw) 3.3
MAX current(A) 13.1A
Maximum speed(RPM) 30000
Maximum frequency(Hz) 1000hz
Nose HSK32E
Lubrication Grease
Weight(kg) 15
Cooling water or oil
Tool change type Pneumatic
Diameter 100mm
shipping list
1pcs spindle motor
6pcs hsk32 er20 new chuck
6pcs hsk32 chuck holder
1pcs solenoid vale
1PCS SPINDLE HOLDER
1PCS 4KW VFD input 220v single phase/ output 380v 3 phase 1000hz
1PCS BRAKING RESISTOR
10m PU tube 8mm
1PCS power conector
1PCS signal conector
www.ebay.com/itm/187284133495
  • kubes
  • kubes
12 Jun 2025 01:21
Jog Increments based on G20 or G21 was created by kubes
Category: QtPyVCP
Hello,
Can the INCREMENTS be dynamic by G20 (in) or G21 (mm)?
In my .ini / DISPLAY
INCREMENTS = JOG  .010in .001in .0001in
INCREMENTS = JOG  .100mm .010mm .001mm
  • electrosteam
  • electrosteam
12 Jun 2025 00:21
Replied by electrosteam on topic WiFi Problem on Raspberry Pi
Thanks Rod, the external antenna was my next move.
I am in Sydney, any suggestion on model number that is known to work with LC2.9.4 ?
The Extender has been set up to use 2.4 GHz from the start.
The engineer in me wants to know why the failure in the cubicle.
I will do some more testing.
John.
Displaying 13456 - 13470 out of 17414 results.
Time to create page: 0.348 seconds
