  • jjdege
  • jjdege's Avatar
23 Apr 2025 06:48 - 23 Apr 2025 06:51
Thank you
it's not a configuration problem
I tried the procedure you described, but nothing changes
XYB works, ZC dir doesn't work, A doesn't work
it's a hardware problem.
  • besriworld
  • besriworld
23 Apr 2025 06:22
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
It seems that the two problems are related. I just have to try another gui
  • Aciera
  • Aciera's Avatar
23 Apr 2025 06:18
36 MESA boards new and used Auction ending 4/19
Category: User Exchange
The boards seem to have been sold now.
  • rodw
  • rodw's Avatar
23 Apr 2025 05:13
Replied by rodw on topic amplifier fault troubleshooting
Category: Driver Boards
This:
net plasmac:breakaway joint.0.amp-fault-in <= hm2_7i97.0.inmux.00.input-04-not
Looks like the only thing that can generate a amplifier fault
Why would you connect the torch breakaway switch to an amplifier fault? That is wrong
  • rodw
  • rodw's Avatar
23 Apr 2025 05:08
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Looks like the path in your ini file  to your Ethercat xml file is wrong
  • Soccer Kid
  • Soccer Kid's Avatar
23 Apr 2025 03:17 - 23 Apr 2025 03:19
Category: EtherCAT
Personally, I think compiling through source code will have a much better effect. Usually, different environments lead to very poor compilation results...
  • Soccer Kid
23 Apr 2025 03:06
Replied by Soccer Kid on topic .xml generic drivers not working?
Category: EtherCAT
Thank you very much for your answer. After repeated tests, I found that this BUG occurs on a specific machine. I have two identical machines at hand. One machine will never have this problem no matter what, while the other machine always has it. After this, I updated to 1.25.1 and this problem was solved!
Cheers! scottlaird!!!
  • RushA
  • RushA
23 Apr 2025 02:39
  • PCW
  • PCW's Avatar
23 Apr 2025 02:38 - 23 Apr 2025 02:39
Replied by PCW on topic amplifier fault troubleshooting
The 7I97T is likely repairable if only the encoder interface chip(s) are damaged.
You might check if any encoder inputs work.
  • bentiggin
  • bentiggin
23 Apr 2025 01:30
Replied by bentiggin on topic amplifier fault troubleshooting
Ah, thanks for setting me straight.
Since I'm getting encoder signals to the 7i97t, but it's not getting that signal to linuxcnc, than I assume that the high frequency start somehow damaged it.
  • PCW
  • PCW's Avatar
22 Apr 2025 22:44
if you measure across A+ , A- you should get alternating polarities like your +3.5V, -3.5V
If you measure A+, A- relative to ground they should be close to ground in one state
and > 2.4V in the other.
  • bentiggin
  • bentiggin
22 Apr 2025 22:38
I set the encoder jumpers on the 7i97t to ttl and tried grounding a+, b+ and i+ while watching the corresponding hal show pins and they didn't light up.
So it looks like the encoder signals aren't getting through.
I then put my multimeter on a+ a-, b+b-, i+ i- and got 3.5ish v, but on both a and b at the same time. Shouldn't one phase be high like 3.5v while the other phase is low, like .5v? It seemed like they were jumping between -3.5 and 3.5 when i moved the motors instead of jumping between .5 to 3.5. Is this wrong or am I mixed up?
Except for the z axis which was reading more like 5.22v.
  • PCW
  • PCW's Avatar
22 Apr 2025 21:52
Replied by PCW on topic OLD Lathe conversion to a CNC
Category: Turning
Not sure if it's related, but here is a similar issue, also using gmoccapy:
forum.linuxcnc.org/20-g-code/44739-g96-issue
  • bentiggin
  • bentiggin
22 Apr 2025 21:36
I commented the breakaway out and now I don't get the amplifier fault. Being normally closed(i think), linuxcnc must not be getting the signal.
Since it was working just fine before, I assume its relating to the interference/grounding that tommy brought up.
To be honest, I get quite confused with the grounding.
-the ground clamp is securely bolted to the table. I did notice when bolting it to the plasma, the stud had a little play, I assumed that it's set up like many welding machine studs where this not a problem, but maybe it is. I'll take the cover off the plasma and see how it looks on the inside.
-There is grounding connected to machine and PC? I think? The whole machine's star ground is connected to the power panels ground. The pc is only grounded through the normal plug/outlet grounds. The pc is currently about 5 feet from the machine and is only connected through the ethernet cable.
-the grounding in the box unpainted aluminum box all goes to one spot that in turn has a wire to go to the star ground for the machine.
- The box is on the gantry. I think it's a dumb spot, but I was trying to keep the retrofit simple, so I left it there. This means the the ethernet cable does run parallel to the torch cable. They are about 6 inches apart in the cable chain and the torch is has a braided copper shield it's entire length. Maybe this is the problem? I thought it would be fine since it was already this way before the retrofit and worked before, but now I'm leaning toward moving it off the gantry.
The DRO number don't change at all. I suspect something got damaged here. I will test to see if mesa/linuxcnc can pick up any encoder signals.
  • unknown
  • unknown
22 Apr 2025 21:16
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Drivers build & load without having to install any "extras".
git clone https://github.com/lwfinger/rtw88
cd rtw88
make
sudo make install
sudo make install_fw
Displaying 16381 - 16395 out of 17399 results.
Time to create page: 0.455 seconds
