  • spumco
  • spumco
22 Apr 2025 01:18
After homing X and Y, can I auto move to a non 0,0 location?
Ha!!! My motors stall if I go much over 40 inches / minute!
That seems exceptionally slow.
Is there a problem with your machine - perhaps axis binding - or do you have really undersized motors?
  • cakeslob
  • cakeslob
22 Apr 2025 01:04
Replied by cakeslob on topic ChatGPT LinuxCNC Assistent
Category: Configuration Tools
I suggest trying to work with this file. I still need to clean it up a little, but this is a far better starting point than the ai file
github.com/cakeslob/RRW_LAB/blob/inc/Lin...theng/remora-xyz.hal
github.com/cakeslob/RRW_LAB/blob/inc/Lin.../remora-xyzRE_ts.ini
I mean....big red flags from ai file
[EMC]
VERSION = 2.9.4
TASK = lathe_task
COORDINATES = XZC
KINEMATICS = trivkins coordinates=XZC
  • Soccer Kid
  • Soccer Kid's Avatar
22 Apr 2025 00:48
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
Perhaps it is related to the EOE mode of the drive. Generally, it is recommended to adopt the drive in COE mode...
  • unknown
  • unknown
22 Apr 2025 00:39
Replied by unknown on topic 7i92 firmware issue
7i92 firmware issue
Category: Driver Boards
Mainly for my own records and thinking aloud.......
Switched from the i5 & Realtek NIC to a RPi5. Seems somewhat more solid, can get Mesaflash to write reliably with a 8us usleep instruction around the "sync" instruction. Still thinking the issue is my side, have ordered some "sample" interface chips from Microchip, I'll assemble another board, this time using a reflow oven for the SMD parts. If that doesn't fix it I have a board designed for the OMDAZZ dev board I've used before, SPI just needs upgrading to 16Mb part as it only comes with a 4Mb part.
  • unknown
  • unknown
22 Apr 2025 00:30
Replied by unknown on topic ChatGPT LinuxCNC Assistent
I think about 6 months ago a user tried to use ChatGPT to write a component for Linuxcnc...what a mess that was and the user was quite upset, not so much with the code supplied but with the fact that the replies suggesting the code made no sense.
  • unknown
  • unknown
22 Apr 2025 00:26
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
Thanks for your input. Keyboard input is USB, so meh, not a lot that can be done about that.
  • unknown
  • unknown
22 Apr 2025 00:23
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Use the official fan & heatsink, it works well and you'll have no issues. I've left mine on for days at a time during the summer in Australia and nothing has gone wrong.
I prefer a wired pendant, connected via a Mesa 7i73. It's solid and you don't need to worry about disconnections. Just axis & step selectors with a hand wheel. Tho Rod does us a fancy wireless one.
  • pgf
  • pgf
22 Apr 2025 00:18
22 Apr 2025 00:15
Replied by tommylight on topic 7i95T & 7i77
7i95T & 7i77
Category: Basic Configuration
Rod, all my 3D printers run Klipper on laptops or NUC's, nothing runs on RPI's on my shops, although i have 2 somewhere, the 3B version.
Use KIAUH from github, it will install and setup everything on a PC, including camera, telegram bot, etc
  • ErwinCNC
  • ErwinCNC
21 Apr 2025 23:42 - 22 Apr 2025 00:23
First of all, thank you very much for your work with the images.
According to everything I found on the net, a pi 5 8GB with SanDisk extreme pro 64gb, official power supply and a Mesa 7i96s should work without any problems? Is that correct?
Are there any restrictions regarding
- user interface (probe basic, gmoccapy)
- the wireless 6 axis handwheel
One last question about the cooling / housing.Is a passive cooled case like the Flirc Raspberry Pi 5 case sufficient or should active cooling be provided? My thoughts on this are mainly dust protection.
Perhaps useful for others
Unfortunately, the standard office monitors all have large ventilation slots on the back. I have been looking for alternatives for a time and would now like to use a mobile external monitor (sold as a supplement to the laptop). These seem to be much better protected against dust.
Erwin
  • vre
  • vre
21 Apr 2025 23:11
Replied by vre on topic Digital Input
Digital Input
Category: O Codes (subroutines) and NGCGUI
So this code does the same thing?
(pwmgen.00 is the spindle pwmgen)
	o307 if [#<_hal[[pwmgen.00.enable]> GT 0]
		(abort, spindle not stopped)
	o307 endif
  • rodw
  • rodw's Avatar
21 Apr 2025 23:05
Replied by rodw on topic 7i95T & 7i77
7i95T & 7i77
Second hand laptops are much cheaper and much more powerful, and can easily run Klipper.
I didn't know that!
  • rodw
  • rodw's Avatar
21 Apr 2025 22:59 - 21 Apr 2025 23:00
First time to try build my xml for not listed ethercat in-out component
Category: EtherCAT
I don't think the error has anything to do with your I/O module. Sounds like you are using a wrong pin name. comment it out until it opens and then review in halshow to see what you did wrong...
  • rodw
  • rodw's Avatar
21 Apr 2025 22:55
Okay, I think a picture will help.
That's because since homing (and even rapids, on my mill) are very slow, I'd really rather skip the extra bed travel, and have it home directly to 12, and stayed there.
Homing does not have to be slow but there is a tradeoff between overtravel and velocity. Now you have it working, try playing with the HOME_VELOCITY and LATCH_VELOCITY. ON my plasma table, I settled on 12 metres/minute
  • rodw
  • rodw's Avatar
21 Apr 2025 22:49
Replied by rodw on topic Should I switch from AXIS to QtDragon?
Category: Qtvcp
Just buy a cat.
They're cute and they catch mice.
Said cat is out of a job due to technology in the better mouse trap!
Displaying 16441 - 16455 out of 17400 results.
Time to create page: 0.332 seconds
