  • Lampje
  • Lampje
09 Apr 2025 08:09
Problems with setting up my Leadshine HBS86H steppers with PNCConf.
Category: PnCConf Wizard
On to the next issue :(
During setup of the axis (pncconf) and I test the axis movement, it works perfect.
But from Linuxcnc itself i only get it half distance. HOW?
There is no encoder feedback to the Mesa board as the closed-loop is handled between the drive and motor.
It seems others are having similar issues, but i can't get a clear picture of how they fixed it other than basically running double distance in the wizard to get it to do the correct distance in Linuxcnc. But adding complexity with the speed and acceleration.
  • meister
  • meister
09 Apr 2025 08:00
Replied by meister on topic Best cam software to use for plasma cutting
Category: CAD CAM
lead in and lead out is implemanted, M3/5 on every cut also,
but no nesting :(
  • behai
  • behai
09 Apr 2025 07:51
4-Gang 1-Way Switch To Control 3 Power Supplies and a Router Independently
It's a fuse and a switch in the same box, the picture shows 2 of them.
Thank you tommylight,
I understand now. When I searched for "automatic fuses", I did get correct result, such as this one www.aurinkopaneelikauppa.fi/Automatic-Fu...30V-AC-slow-Type-C-2; but I confused them for circuit breakers.
Best regards,
...behai.
  • vre
  • vre
09 Apr 2025 07:50
Help,How to customize language of QtDragon's interface
Category: Qtvcp
It's in a library file. qt_action.py
github.com/LinuxCNC/linuxcnc/blob/2.9/li...cp/qt_action.py#L754
In this function where in the GUI can set the parameters
search_vel, probe_vel, max_probe, z_offset, retract_distance, z_safe_travel, rtn_method
09 Apr 2025 07:46
Replied by tommylight on topic Best cam software to use for plasma cutting
Category: CAD CAM
M3 and plasmac feed rate at the start of every cut
F#<_hal[plasmac.cut-feed-rate]>
M03 $0 S1(turn on plasma)
And M5 at the end of every cut.
Also simple nesting or just ability to change the order of cuts would be nice to have.
And lead in and lead out with the option of no lead out.
  • behai
  • behai
09 Apr 2025 07:43
For a control box, the simplest way is to use a switched, EMI filtered and fused IEC connector
www.amazon.com.au/uxcell%C2%AE-IEC320-Sw...Filter/dp/B01FT0VRTS
You can see one of these used at the bottom right of my photo shared earlier.
But in your case, this won't work if you want to switch the router on and off because the current of the router will be too high for the typically 6 amp AC rating. Plus you would not want the electrically noisy router to be on the same side of the EMI filter as your electronics.
So in your case, I would use a fixed power lead and a cable gland to bring mains into the control box to two household breakers around 10 amp. One of these will protect your router circuit and the other your electronics, On the electronics circuit, immediately after the breaker, fit an EMI filter
www.jaycar.com.au/240v-ac-emi-filter/p/MS4001
Then connect all of your power supplies to the filtered mains power.
Filtering the power is really important to avoid spurious triggering from electrical noise. I learnt the hard way.
The next thing to work out is your estop. That's a bit tricky because you need to disable the router and the stepper motor power supply without using any relays that could fail. The estop needs to drop power to your router power and  stepper mains motion. You could use 2 phases of a 3 phase breaker but technically you would then need  to use a safety relay to be compliant.
Its probably acceptable to disable your stepper drivers using the enable pins on them that are usually left disconnected.
Thank you Rod,
I have been thinking about your advice on the router, I am trying something I don't have any practical knowledge of, I will just leave this one out, I will get the other three working, as my knowledge increase, I might rewire it again. This just my hobby project. But I really like learning electronics now, I have always been afraid of it.
You are right, the ENABLE pin on the CLT57T-V41 is left unconnected. During my learning of this driver, I used only the Raspberry Pi 4 and Python to program it, setting ENABLE to high disables the motor.
Best regards,
...behai.
  • machinedude
  • machinedude's Avatar
09 Apr 2025 07:23
What do you really get for a $350 desk top engraver ?
Category: Show Your Stuff
it was on a belt drive with an omega style configuration.
  • meister
  • meister
09 Apr 2025 07:10
Category: CAD CAM
Can it also do g-code for plasma cutting?
Don't have plasma and can't say what is needed, but if you tell me what is missing I can expand it
  • Hakan
  • Hakan
09 Apr 2025 06:49
Category: CAD CAM
  • AMLD
  • AMLD
09 Apr 2025 06:41 - 09 Apr 2025 07:13
QtDragon_hd + Basic Probe - probing results not displayed
Category: Qtvcp
Okay, I will also make a video about what's happening and post it
  • papagno-source
  • papagno-source
09 Apr 2025 06:41
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
I have see value 1 on much example the xml file and not have problem with this value on debian 10 , lcnc 2.9.0-pre0 and ethercat 1.5.2.
I have test on debian 12, lcnc 2.10.0 and etehrcat 1.6.3 with value 1 and 5 and 1000 , but have error synch 5000 ms foe every drive.
only with -1 the error disappears.
What I don't understand is why on Debian 12, when LCNC starts, the PDO information is written to HAL after a few seconds and in sequence, one Ethercat node at a time from 0 to 5, while with the Debian 10 configuration, the PDOs are immediately read and updated in HAL, as soon as LCNC is running.
another difference between debian 10 and debian 12.
I use PCs with two ethernet ports.
With devian 10, with ip a I have 2 network cards enp1s0 and enp2s0,
while with debian 12 I have three, the two physical network cards and one with written: eoe0s0, which is created when ethercat is running.
Could it be that ethercat 1.6.3 unlike 1.5.2 uses a virtual card that in turn closes on a real one?
  • Hakan
  • Hakan
09 Apr 2025 05:51
  • meister
  • meister
  • sivaraj
  • sivaraj
09 Apr 2025 02:55
Trouble probing 1Vpp signal from Heidenhain LS403 with oscilloscope
Category: Milling Machines
As for as I know Heidenhain LS403 is a 11uA signal . Not 1Vpp.
Please check the datasheet
  • irwinger
  • irwinger
08 Apr 2025 21:53
Replied by irwinger on topic Spindle control not showing in Axis window...
Category: Basic Configuration
Back to the 'knowledge well'... sigh.
What I CAN do:
I have my motion control working (I can job X, Y and Z in the correct directions - or at least in the directions I want them to move when pushing the +/- buttons).
     - I had to 'reverse' the homing direction of my X and Y axes in the INI file, changing the lines:
       HOME_SEARCH_VEL = -0.050000  ; changed 0.050000 to -0.050000
I have my spindle control working - I can turn the spindle on and off from the Axis UI
I have my home/limit switches working - I can 'home' my X & Y (I don't have Z-axis home/limit switches)
     - the 'home' symbol shows in the DRO section of the Axis UI
What I CANNOT do:
1) I cannot 'touch-off' any of my axes. I homed all axes, jog my router off of the Home position, click the 'Touch Off' button and leave the defaults as presented, click the 'OK' button and immediately get an error stating "Can't issue MDI command when not homed. This of course also translates to my MDI (F5) screen when I attempt to move the router around using the G0 command
     - I am somehow way out of 'scale' with motion - I was planning on using the MDI interface to specify G-Code moves and measure results. Of course I immediately got the "Can't issue MDI..." error so I returned to the 'Manual' tab to ensure I was homed... which I was.
     - At this point, 'eyeballing' alignment with marks on the wasteboard, a 5" move shows as ~1.25" on the DRO in the X dimension. I'm guessing Y will be the same - but Z will be different because it uses a different Acme threaded rod.
I did try to find a solution in the 1347 pages of the manual... but that document is just absolutely overwhelming. In fact - I tried going through it again, one more time before I pushed 'submit' on this post (I DID realize that at least part of my motion scaling issue is my INI configuration). I even read the 'history' this time and realized that LinuxCNC emerged from a NIST project that was based on Windows NT... if ONLY the guys that were first involved would have stayed there (insert joking face emoji here).
If you want me to repost this as a new thread with a new title - I am happy to do it.
Displaying 17161 - 17175 out of 17469 results.
Time to create page: 1.186 seconds
