Suggestion for a PCI EPP card for 7i43
15 Nov 2024 14:37 - 15 Nov 2024 14:39 #314522 by PCW
Replied by PCW on topic Suggestion for a PCI EPP card for 7i43
You might try explicitly setting the high address in the hm2_7i43 command line (and the debug option)
did you try the --readhmid mesaflash option?
What kind of parallel port card do you have (what chip manufacturer?)
what does lspci report for the parallel port addresses? (trying to verify the high address)
Last edit: 15 Nov 2024 14:39 by PCW.
15 Nov 2024 16:00 - 15 Nov 2024 16:05 #314528 by juliankoenig87
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Thank you for the support.
lspci:
Warning: Spoiler!
It is a Sunix 4008T card. I have a Sunix PAR6408A card for pci-e, but cant use it.
Tried also "cat /proc/ioports":
Warning: Spoiler!
mesaflash:
Warning: Spoiler!
Last edit: 15 Nov 2024 16:05 by juliankoenig87.
15 Nov 2024 16:08 #314530 by juliankoenig87
Ok. Everytime I use only the terminal I can get a connection to the 7i43.
Once I try to start linuxcnc I get an error. After that the pc freezes when I try to reacg for the card by the terminal.
15 Nov 2024 16:10 #314531 by PCW
You would need the
lspci -vv
option to show addresses
15 Nov 2024 16:37 #314532 by juliankoenig87
lspci -vv:
Warning: Spoiler!
15 Nov 2024 16:40 #314533 by juliankoenig87
So. d010 and d000 ?
I tried 0xd000 without success.
15 Nov 2024 16:42 #314534 by PCW
might be 0xd000 low 0xd010 high
15 Nov 2024 16:42 #314535 by juliankoenig87
Ok. that is new:
cnc@linuxcnc:~$ sudo mesaflash --epp --device 7i43 --addr 0xd000
[sudo] Passwort für cnc:
EPP device 7I43 at 0xD000:0xD400
15 Nov 2024 16:59 #314537 by juliankoenig87
I can get some strange results:
loadrt hm2_7i43 ioaddr=0xd000 ioaddr_hi=0xd400 epp_wide=0 config="firmware=hm2/7i43-2/SVST4_4.BIT
Gives me:
No parport registered at 0xd000. This is not always an error. Continuing.
hm2/hm2_7i43.0: invalid cookie, got 0x00000000, expected 0x55AACAFE
hm2/hm2_7i43.0: FPGA failed to initialize, or unexpected firmware?
hm2_7i43.0: board at (ioaddr=0xD000, ioaddr_hi=0xD400, epp_wide OFF) not found!
hm2_7i43: rtapi_app_main: Invalid argument (-22)
If I change to:
loadrt hm2_7i43 ioaddr=0xd010 ioaddr_hi=0xd410 epp_wide=0 config="firmware=hm2/7i43-2/SVST4_4.BIT
I have to change to the 7i43-4 firmware because linuxcnc said thats tghe wrong one. Wit 000 and 400 it is vise versa...
15 Nov 2024 17:01 - 15 Nov 2024 17:12 #314538 by PCW
0xd400 cannot be a valid address as its not listed by lspci
that is,  "ioaddr_hi=0xd010" should be tested
Also hm2/7i43-2/SVST4_4.BIT is a bitfile for a 7I43-2, but you have a 7I43-4
Last edit: 15 Nov 2024 17:12 by PCW.
Time to create page: 0.324 seconds
