Suggestion for a PCI EPP card for 7i43
- juliankoenig87
- Thank you received: 55
06 Nov 2024 10:42 #313885
by juliankoenig87
Suggestion for a PCI EPP card for 7i43 was created by juliankoenig87
Hi.
I do have a 7i43 laying around and want to use it with a thinkcenter p90 (good latency) without a parallel port.
So is there a good choice for a current pci to epp card?
The suggested ones are hard to get nowadays.
Best regards
Julian
Best regards
Julian
- PedroSMS
- Thank you received: 3
06 Nov 2024 13:38 #313899
by PedroSMS
Replied by PedroSMS on topic Suggestion for a PCI EPP card for 7i43
I use the SUNIX brand. I see them on ebay etc... They have a variety of PCI variants, and single & dual ports.
I hope this helps.
Kind regards
Pedro
I hope this helps.
Kind regards
Pedro
- Thank you received: 7488
06 Nov 2024 13:50 #313903
Replied by tommylight on topic Suggestion for a PCI EPP card for 7i43
PCI or PCI-E ?
- juliankoenig87
06 Nov 2024 13:57 #313905
by juliankoenig87
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Hi.
It doesnt really matter, but I would prefer PCI.
06 Nov 2024 14:08 #313909
Ok, does the P90 have a PCI slot, the long white one?
P93 does not have PCI, hence my questions.
- juliankoenig87
06 Nov 2024 15:03 - 06 Nov 2024 15:04 #313913
by juliankoenig87
Ok. I missed the p, sorry.
It is a M90p and has PCIe 16x and PCI on board.
Last edit: 06 Nov 2024 15:04 by juliankoenig87.
06 Nov 2024 18:07 #313934
Yes, it has both, nice
I will do a post with the cards i have tested and working, stay tuned.
No idea if they will work with 7i43 though, but they should support EPP, will have to double check that.
- juliankoenig87
06 Nov 2024 19:01 #313936
by juliankoenig87
That would be nice!
Pedro can you confirm that Sunixs cards are working with a 7i43?
06 Nov 2024 20:21 #313950
forum.linuxcnc.org/18-computer/54368-pci...-work-out-of-the-box
Apparently i have a Sunix card, and it works out of the box, but i have no 7i43 to test with.
When i get to the shop i can try to get some info on what modes it supports and report back.
- Thank you received: 426
06 Nov 2024 23:07 #313971
Replied by Cant do this anymore bye all on topic Suggestion for a PCI EPP card for 7i43
Check the Lenovo motherboard for a lot header. If there is one but the Lenovo header cable, that will enable the parallel port in the bios. Without going into too many details the cable shorts a pin on the MB enabling the parallel port.
Worked on the Lenovo tower I picked up by the side of the road.
Time to create page: 0.350 seconds
