Suggestion for a PCI EPP card for 7i43
- juliankoenig87
- Thank you received: 55
15 Nov 2024 17:18 #314539
by juliankoenig87
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Mhmmm.
loadrt hm2_7i43 ioaddr=0xd000 ioaddr_hi=0xd010 epp_wide=0 config="firmware=hm2/7i43-4/SVST4_4.BIT num_encoders=0 num_pwmgens=0 num_stepgens=3"
gives me:
No parport registered at 0xd000. This is not always an error. Continuing.
hm2/hm2_7i43.0: board has FPGA '3s200tq144', but the firmware in hm2/7i43-4/SVST4_4.BIT is for FPGA '3s400tq144'
hm2_7i43.0: board at (ioaddr=0xD000, ioaddr_hi=0xD010, epp_wide OFF) not found!
hm2_7i43: rtapi_app_main: Invalid argument (-22)
gives me:
Warning: Spoiler!
- Thank you received: 5329
15 Nov 2024 17:27 - 15 Nov 2024 17:30 #314540
Replied by PCW on topic Suggestion for a PCI EPP card for 7i43
You might try reversing the addresses based on the lspci order:
Region 0: I/O ports at d010
Region 1: I/O ports at d000
It may also be that the 7I43 is damaged
Last edit: 15 Nov 2024 17:30 by PCW.
- juliankoenig87
15 Nov 2024 17:33 #314542
by juliankoenig87
Yes. Tried it before. Might be a faulty 7i43. Or I shoul test with an old pc with an "real" parport.
15 Nov 2024 17:40 #314544
Supposedly the Sunix based cards are OK for EPP mode
(the NetMOS 9805 based PCI cards do not implement EPP properly so can never work)
Time to create page: 0.083 seconds
