  • Domi
  • Domi
08 Apr 2025 12:49 - 08 Apr 2025 13:38
jenkinson8 post=325911 userid=42861Teraz som späť doma. Príkaz, ktorý hľadáte, je:
[code]pip3 install tftpy --break-system-packages
Then rerun the upload_config.py command again.
 Its okay. Thanks
[/code]
08 Apr 2025 12:49
Replied by tommylight on topic How to build a CNC Router?
Category: Milling Machines
A not properly crimped plug or semitight srew termnial might cause a problem as well?
Yes.
Or does the damage only occur when all four wires are disconnected at same time?
Any motor wire.
I would guess the system does not know if I did it or it just happened.
What system? The drive will know, motors are inductors and disconnecting powered inductors cause huge spikes that very often end in dead equipment.
  • machinedude
  • machinedude's Avatar
08 Apr 2025 12:19
What do you really get for a $350 desk top engraver ?
Category: Show Your Stuff
i just measured the bearing OD and the housing bore diameter, and the housing is a good .002 larger than the bearing OD. the shaft is either pressed into the ID or it got that way when it broke? the bearing feels like it is spinning just fine so i don't think the bearing was the root cause. the break was right at the shoulder where the bearing would ride and seat on the shaft. no wave washer on the front side and it does not feel like it has one on the other end either.
  • spumco
  • spumco
08 Apr 2025 11:58
Replied by spumco on topic Rf45 clone glow up.
Rf45 clone glow up.
OP - That's a nice harmonic drive you've got there, especially with the big through-bore.
If you still need some mounting inspiration, Andy Pugh did a fantastic job of documenting his 4th axis build based on similar reducer.
  • spumco
  • spumco
08 Apr 2025 11:39
the only other clue i can offer up at this point would be the fact that the bearing was not pressed in the motor housing. it came right out so maybe a poor press fit added to this?
Bearings are quite often an interference fit on the shaft but close sliding (or transitional) fit in housing.  Makes assembly easier, especially in production environments.  Interference fits on both the shaft and housing make assembly a nightmare.
Frequently for smaller motors a spring/wave/Belleville washer is used inside one housing end to permit the bearing to move axially as the rotor shaft grows (from heat).  That spring preload also tends to keep the bearing outer races from spinning in the housing bore.
If the bearing was a fairly sloppy fit in the housing there was very little resistance to shaft bending and all the movement would have been concentrated at the shaft bearing seat shoulder.
Andy's suspicion about a fatigue crack from shaft misalignment is looking pretty darn persuasive to me.
  • woodbox
  • woodbox's Avatar
08 Apr 2025 10:41
Working with Aspire 12 – Happy to Help If Anyone Needs It
Category: CAD CAM
I've built an CNC router with MESA7I96 controller. I use an Pi5 for running linuxcnc and it works fine. Until this time I used Fusion360 for CAM, but I'm thinking on to try Vectric Pro.
Vectric has any metric post processor for linuxcnc? If yes, which one you use?
  • unknown
  • unknown
08 Apr 2025 10:32
Replied by unknown on topic The dumification of humanity through internet
It's always fun to poke fun at the Septics, tho they seem to encourage it when some of the louder ones don't realise that other countries do things their own way and will argue the point.
  • timo
  • timo
08 Apr 2025 09:37
Replied by timo on topic How to build a CNC Router?
  • rodw
  • rodw's Avatar
08 Apr 2025 09:31
Replied by rodw on topic LinuxCNC S-Curve Accelerations
Glad you waded into the live build environment. Wait till I get you going on the raspberry Pi
Sorry it failed for you.. I had plenty of that. The biggest issue I had was getting apt configured and installing the gpt keys.
Bjarne from Etherlab was a big help there.
I think Linuxcnc builds all of the Debs in the one go.
There was a really interesting pull request from Stefan Moller that has yet to be committed which installed the dependencies the Debian way (eg. Just using one command. It would have been nice to see it in the code by now.
  • jenkinson8
  • jenkinson8
08 Apr 2025 09:29
Replied by jenkinson8 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hey guys, letting you all know that I found the problem. Looking back a few pages found that the repo has different nvem config files. Uploaded this one and it now works: github.com/scottalford75/Remora-RT1052-c...xCNC/nvem-rt1052.txt
  • jenkinson8
  • jenkinson8
08 Apr 2025 09:27 - 08 Apr 2025 09:27
I'm back home now. The command you're after is:
[/code]
  • Fredrancis
  • Fredrancis
08 Apr 2025 09:17
Replied by Fredrancis on topic Halscope trigger level grayed out
When I started halscope, the trigger level slider worked as expected. For some reason it has become non-functional. The slider is gray, no green, no way to adjust it. I've tried restarting halscope and changing trigger channel. It doesn't matter if I'm in Red Light Green Light Normal or Auto trigger.
Thanks,
Steve
Did you make any adjustments to the settings before the trigger level slider became greyed out?
  • blazini36
  • blazini36
08 Apr 2025 09:05
Replied by blazini36 on topic The dumification of humanity through internet
Anyone against deleting this topic?
I failed to raise hell... :)
P.S.
I still maintain that calling silicium "silicon" is not smart, by any stretch of imagination. Sue me !
Well I mean, if you're looking for a fight......
I noticed quite a few jabs taken at us 'Mericans over here......I could oblige. I also noticed some strange replies that are missing the post they must have been replying to, wonder what that's about.....
I rarely click the "recent topics" button, so I missed the fun.
  • machinedude
08 Apr 2025 09:03
Displaying 17206 - 17220 out of 17468 results.
Time to create page: 0.375 seconds
