24 Feb 2026 03:55 - 24 Feb 2026 04:05
Enabling multi-touch (pinch-to-zoom) in QtDragon HD with Touchscreen
Either way, it is a Linux thing to recognize multiple fingers if your monitor supports it, so might be better to look in the Debian forums.
  • jtrantow
  • jtrantow
24 Feb 2026 03:43
hm2_modbus pktuart, probably a firmware request?
Category: Driver Boards
Thanks, that makes sense. R's must be built into the usb adapter.
I will add termination resistors and give that a try.
I flashed 7i96_pktv3d.bit to try out the modbus with a minimal config. I assume I will need updates to run the rest of my configuration?
My lathe has a 7i96 with rs485 connector.
Can I use ptkuart with my 7i92 and 7i92T if I use a ttl to 485 adapter and firmware updates?
Lathe uses a 7i96 with 7i85S and a G540 - 7i96p1_7i85dsdi.bit
Mill uses a 7i92 with 7i85S and 7i75 daughtercards, 7i92_7i85sx1sdid.bit
Router uses a 7i92T with a 7i75 and a G540 7i92t_g540d.bin
  • kello711
  • kello711's Avatar
24 Feb 2026 02:54 - 24 Feb 2026 02:54
Replied by kello711 on topic XHC WHB04B development?
I don't think I would trust a USB device under these circumstances. I would recommend you go back to XHC's website and look for a 433 MHz pendant that hard wires in to send/receive unit. After years  of use, these have never let me down
Do you have a link to the one you use or a model number?
  • PCW
  • PCW's Avatar
23 Feb 2026 23:45
Here's the wiring information:  (just added to 7I96 manual)
RS-485 OPERATION
For 2 wire RS-485 applications, TX+ must be connected to RX+ and TX- must be
connected to RX-. RS-485 pair wiring is TX-/RX- to A and TX+/RX+ to B.
For RS-485 applications, 7I96 cards require two biasing resistors to establish the
non-driven state of RS-485 interfaces (MODBUS etc). The first resistor should connect
between +5V and RX- and the second between GND and RX+. Suggested resistor value
is 330 Ohms.
  • AlessandroEmm
  • AlessandroEmm
23 Feb 2026 22:03
Replied by AlessandroEmm on topic Remora - Cannot clear E-STOP, without error
Category: Basic Configuration
Sorry, I dont follow, what Syntax error are you referring to?
  • Ferra
  • Ferra
23 Feb 2026 22:01
Hello everyone,I hope this is not a trivial question — I am still learning the Linux input stack and QtVCP internals, so please excuse any misunderstanding on my side.I am running LinuxCNC with QtDragon HD (QtVCP) on Debian RT.
My touchscreen hardware supports 15-point multi-touch (confirmed on Windows).
On Linux, the device is detected as
wch.cn TouchScreen
.What I would like to achieve is:
  • Two-finger pinch for zoom in the 3D preview
  • Possibly two-finger rotation/pan gestures
​​​​​​​Any guidance, even high-level direction, would be greatly appreciated.​​​​​​​Thank you for your patience and for the excellent work on LinuxCNC.​​​​​​​​​​​
  • jtrantow
  • jtrantow
23 Feb 2026 21:59 - 23 Feb 2026 22:35
Connected CommanderSK VFD RS485 to 7i96 connector.
Docs at linuxcnc.org/docs/2.9/html/drivers/mesa_modbus.html state:6. Hardware ConnectionThe Mesa serial ports have separate pins for Tx and Tx pairs. For RS422 Modbus RTU communications these should be connected at the Mesa card Tx+ to Rx+ and Tx- to Rx-.Note that there are differing naming standards for Modbus pins. Typically Rx+ and TX+ will connect to the B- pin on the modbus device and Rx- and Tx- will connect to the A+ pin, i.e., +/- will appear reversed.
Is RS485 wired the same way?
My working USB/485 dongle solution connects:
RJ45                 USB Dongle
2 EIA485+          A+
3 0V                  GND
7 EIA485-          B-
So I have connected EIA485 to Mesa TX- and RX-, EIA485- to Mesa TX+ and RX+, 0V to Mesa GND.
I set up CommanderSK.mbccs to simply read the software version from the vfd. This fails with a "Received PDU too small, size=4"
I have tried hal_types HAL_FLOAT, HAL_U32 with the same result.
Any hints before I bring out the scope?
  • HansU
  • HansU's Avatar
23 Feb 2026 21:56 - 23 Feb 2026 21:58
Replied by HansU on topic G-code wizard für Gmoccapy
Category: Gmoccapy
Hast du dir mal PyNGCGUI angeschaut? Es gibt eine Beispiel-Sim-Config "gmoccapy_pyngcgui"
  • AlessandroEmm
  • AlessandroEmm
23 Feb 2026 21:47 - 23 Feb 2026 22:03
Thanks Tuxcnc - I tried to replicate this with the SPI-fields of remora-spi. (minus the external pin) Unfortunately the behaviour stays the same. Besides looping in the external e-stop does it do something different in terms of iocontrol states?
  • liutas4x4
  • liutas4x4
23 Feb 2026 21:29 - 23 Feb 2026 21:30
Replied by liutas4x4 on topic M codes for a second spindle?
Sounds good. I will try it. Thank you.
23 Feb 2026 21:07
Replied by tommylight on topic Mesa 7i73 auf analog in + encoder mode stellen
Category: HAL
Das ist fuhr die Mesa 7i77,
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
## Feed-Override
## mit Poti
loadrt mux_generic config=fs2
addf   mux-gen.00 servo-thread
setp [HMOT](CARD0).7i77.0.0.analogin0-scalemax 350
setp halui.feed-override.direct-value true
setp halui.feed-override.count-enable true
setp halui.feed-override.scale 0.01
setp mux-gen.00.in-float-00 100
net feedpot-raw    mux-gen.00.in-float-01  [HMOT](CARD0).7i77.0.0.analogin0
net machine-is-on  mux-gen.00.sel-bit-00
net feedpot-mux    mux-gen.00.out-s32      halui.feed-override.counts
  • Hakan
  • Hakan
23 Feb 2026 20:38
Replied by Hakan on topic XHC WHB04B development?
Had a milling session, not very long. XHC didn't crash. Doesn't say much, so I'll continue using libusb_fill_interrupt_transfer().
Ok no testing. Interesting to see how it goes, and if the firmware in the dongle is to blame.
23 Feb 2026 20:36
Replied by tommylight on topic M codes for a second spindle?
Try
M3 $1 S1000
Since LinuxCNC 2.8 (i think) there is built in support for multiple spindles, the $n should be the G-code controlling the spindle number where n is the spindle number starting from 0 (zero), so $0 is the default first spindle, then $1 is the second spindle, etc.
linuxcnc.org/docs/html/examples/spindle.html
linuxcnc.org/docs/stable/html/gcode/othe...ec:set-spindle-speed
23 Feb 2026 20:28
Replied by tommylight on topic XHC WHB04B development?
... I prefer to call the USB part the dongle and the actual handheld device the pendant.
That is the usual naming since the dawn of "security dongles" started by software companies to prevent copying software and later adopted by some banks, and naming them something else... forgot what exactly, but dongle prevailed.
  • Finngineering
  • Finngineering
23 Feb 2026 19:54
Replied by Finngineering on topic XHC WHB04B development?
Yes, unless somebody have better terms, I prefer to call the USB part the dongle and the actual handheld device the pendant. In case of the wired version, I would presume all logic is in the pendant and the "USB part" is only a connector.
The problem for everybody else than myself is that you might have different hardware/firmware version. And if you overwrite the factory firmware with this new firmware, you can no longer go back, because you don't have the factory firmware. I could give you the factory firmware that was in my dongle, but it could be different than what is in yours. The firmware can be extracted (like I have done), but its tedious.
Anyway, I think its a little bit early for public beta testing. I will make some improvements and see if it appears stable over time. Maybe there could be some way to do at least a partial readout/verification of the factory firmware through USB.
Displaying 1891 - 1905 out of 17359 results.
Time to create page: 0.259 seconds
