  • PCW
  • PCW's Avatar
18 Aug 2024 01:31
Replied by PCW on topic 7i97t retrofit
7i97t retrofit
Category: Basic Configuration
Obvious missing bit (in red)
net joint.0.output <= pid.y.output
net joint.0.output => hm2_[MESA](BOARD).0.pwmgen.00.value
  • Benb
  • Benb's Avatar
18 Aug 2024 00:28
Replied by Benb on topic Replacing SWI TRAK CNC 2 Controller
Category: Milling Machines
This link might be helpfulhttps://forum.linuxcnc.org/30-cnc-machines/29358-proto-trak-mx3-retrofit-which-boards-mesa?start=0
  • Benb
  • Benb's Avatar
18 Aug 2024 00:11
Replied by Benb on topic Power supply for my drivers
Category: Driver Boards
If you are not getting the speed and power with 48vdc supply you can use 60vdc. Just make sure the drive heat sinks has good contact with your panel/frame. What usually kills electronics is heat. However, If you are happy with servo motor performance, stick with 48vdc supply.
  • bentiggin
  • bentiggin
18 Aug 2024 00:03
Replied by bentiggin on topic 7i97t retrofit
7i97t retrofit
I originally couldn’t connect at all to the 7i97t till I updated mesaflash to 3.5.9 and installed mesact 2.1.4.
I also tried changing the hm2_eth static address but I don’t think that worked.
  • PhilipME
  • PhilipME's Avatar
17 Aug 2024 22:54
Power supply for my drivers was created by PhilipME
My drivers for some reason rated for 58 volts DC. 2 volts short of the standard power supply which is 60
I am using 48 volt power supply, thinking that any higher voltage may damage the drivers.
Can I use 60 volts DC power supply ?
  • PCW
  • PCW's Avatar
17 Aug 2024 22:37 - 17 Aug 2024 22:38
7i97t retrofit
Can you post the hal/ini files made by mesact?
That would help diagnose the issue so mesact can be improved
With a pncconf created file, make sure you set the PWM offset mode true:
setp   [HMOT](CARD0).pwmgen.00.offset-mode 1 # offset mode so 50% = 0
 (for all PWMgens, not just 00)
Also for best ripple/resolution, follow the  PWM guidelines in the 7I97T manual.
  • bentiggin
  • bentiggin
17 Aug 2024 21:33
7i97t retrofit
Failing to get any results trying to follow the tutorial you posted is the reason I started this thread.
It seems like the drives are not getting 10v analog from the 7i97t.
I tried setting the follow error to 100 and putting my multimeter on the 10v analog on the 7i97t while I am holding the jog button and I get a steady .00v.
I just tried setting it up with pncconf wizard and now the drives are getting 10v from the 7i97t. They aren’t drifting and they’re responding to jog commands.
I was going try to edit the mesact derived .Hal files using the new pncconf config as a guide, but they’re just too different for me to feel like I’d succeed.
should I abandon mesact and just focus on pncconfig? I hesitate to go that route since pncconfig doesn’t recognize the board name. I used the discovery option but I’m not sure if I’ll end with it being fully functional or buggy.
  • acondit
  • acondit
17 Aug 2024 21:23
  • Aciera
  • Aciera's Avatar
17 Aug 2024 21:10
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
On a locally built (RIP) installation open a terminal and navigate to your linuxcnc installation folder:
source scripts/rip-environment
then to start glade:
glade
once glade has started, check if the linuxcnc glade widgets have been imported (ie widgets named 'HAL_....')
  • Bari
  • Bari's Avatar
17 Aug 2024 21:05
Replied by Bari on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
BIOS settings are important. Have you looked at all the howtos for lowering latency?
La configuración del BIOS es importante. ¿Has visto todos los procedimientos para reducir la latencia?
  • Bari
  • Bari's Avatar
17 Aug 2024 21:02
forum.linuxcnc.org/9-installing-linuxcnc...r-2-9?start=0#304599
I'm sorry my Spanish is too poor. The instructions are simple. Try Google translate.
Para instalar desde un Debian 12 nuevo sin LCNC instalado todavía, solo use: sudo dpkg -i (nombre del paquete aquí sin corchetes) para cada deb y reinicie. Elija el kernel RTAI en Grub, disfrute.
Para instalar en Debian 12 con linuxcnc-uspace ya instalado, use: sudo apt purge linuxcnc* y espere a que apt elimine por completo todos los rastros de LCNC.
Luego siga las instrucciones para una nueva instalación de Debian 12 que se indican anteriormente.
  • Moutomation
  • Moutomation
17 Aug 2024 20:50 - 17 Aug 2024 20:51
İnstall glade was created by Moutomation
İnstall glade
Category: Gmoccapy
I may become a Linuxcnc expert or even a developer in the future. Becoming a developer can be very difficult, but it is not impossible. I especially appreciate the Aciera. It takes a lot of effort and time. I want to be a useful person like him. I think I will work hard and make serious contributions to this forum in the future, I am currently in the learning phase. As a first step, I started making changes to gmoccapy. But there is a problem.
I installed Glade using the sudo apt-get glade command but I think this is a version issue, for example I can't see the jog keys as I should. Can you guide me on this issue? (Don't laugh at me, maybe I can succeed one day on how to become a developer with this inexperience)
  • acondit
  • acondit
17 Aug 2024 20:50
5i25/7i76 analog spindle control on Lathe spindle
I doubled those values from 1100 to 2200 and that seems to work from 100 up to about 1100 rpm. It is off a little more down about 75 rpm but there is less power down there anyway.
  • PCW
  • PCW's Avatar
17 Aug 2024 19:36
Mesa 7i96s firmware for Index (2.9 release)
Here is 7i96s firmware that adds a stepgen index pin for all stepgens
Note that these have been added to the P1 expansion connector
so can only be used with TTL/5V level index signals. It's also advisable
to add a say 220 Ohm series resistor to each input if interfacing
machine I/O to the P1 FPGA expansion port to protect against negative
input spikes.
File Name: 7i96ssdid_...8-17.zip
File Size:254 KB
Displaying 23641 - 23655 out of 24397 results.
Time to create page: 1.659 seconds
