  • rodw
  • rodw's Avatar
15 Aug 2024 11:13
  • meister
  • meister
15 Aug 2024 11:09
oh well, one more thing
if someone is from germany and has a Mesa 7C81 or 7I90HD lying around that he can lend for 1-2 weeks,
then I would try to port RIO to it
  • meister
  • meister
15 Aug 2024 10:50 - 15 Aug 2024 11:03
there is none
EDIT:
Just my general opinion on this:
I think it's fine if someone doesn't want to give out all the sources, he has already posted the schematics of many relevant parts.
I'm glad that someone with knowledge is constructing a board for RIO.
If you want, you can also build your own board and just show the pictures here, I am also happy to help with such projects. The main thing is that everyone has fun and it helps the project to grow (community/bug-fixes/...)
  • DPFlex
  • DPFlex
15 Aug 2024 10:45
How to setup gearbox/reducer was created by DPFlex
Category: Basic Configuration
Hello,
I have AC servo motor which has harmonic gearbox with ratio is 80:1
How can I setup LCNC to work correctly with the gearbox ratio ?.
Thank you.
  • Ahmo
  • Ahmo
15 Aug 2024 10:28
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Are they making some updates on ethercat right now? Because when I try to install it it says that it cant fetch some files, I checked and the files that he is searching are version 1.5.2. but the files on repository are version 1.6.1. these files are changed 15 days ago so I was wondering do you now how long will it take for them to fix that?
  • Grotius
  • Grotius's Avatar
15 Aug 2024 10:16
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
i Lcvette,
Yes, will check the mm to inches.
To test the scurve motion planner in linuxcnc i added a new repository , based on lcnc stable version 2.9.3.
Inside the repository we have the cmake framework to build one the current motion planner  "tpmod" and
two a motion planner called "tpmod_scurve".
Conclusion: very compact code enviroment to test scurve motion planner.
Now to make the new motion planner work in linuxcnc, we have to add some logic because the new planner works a little
different then the current motion planner.
Main differences :
1. New motion planner loads gcode itself. Old motion planner, recieves gcode in chunks over the servo cycle.
2. New motion planner calculates "look ahead" before gcode execution, Old motion planner does this at runtime.
Possible difficulties:
1. New motion planner loads gcode itself, this can take a few seconds for big files. This could result in creating a multi-threading process.
2. The clothoid & spline fillets are not shown by lcnc gremlin on forehand. Validation and debugging is more difficult.
Next week i will add the code to make this work.
  • kzali
  • kzali
  • hans48
  • hans48
15 Aug 2024 09:03
Replied by hans48 on topic Ein Neuling sucht Hilfe
Category: Deutsch
Hallo Danke für die Antworten.
Habe die HAL und INI Datei Kopiert hoffe es sind die Richtigen. Habe auch das Video angeschaut ist leider auf Englisch konnte daher nur wenig versehen. Gibt es einen Chresh Kurs damit man die Befehle verstehen kann? So mal schauen ob ich die File auch mitschicken kann.
Die Mesa Karte ist die 7i96s. Die x-Achse hat 2 Motoren.
  • meister
  • meister
15 Aug 2024 07:50
too late
but W5500 pins are missing , so you can do this part :)
  • Mecanix
  • Mecanix
15 Aug 2024 07:49 - 15 Aug 2024 07:50
In fact don't change anything right now. Once I have the board and set PINs for permanent set-ups I'll upload my json(s) over and hopefully you can help me to have this included in Riocore. Let's wait!
ps. I'm really leaning toward binning those colorlight cards and going RIO/Gowin for all 3 (2ax lathe, 4ax mill, 3ax laser). No joke!
  • elovalvo
  • elovalvo
15 Aug 2024 07:35
  • Mecanix
  • Mecanix
15 Aug 2024 07:34 - 15 Aug 2024 07:35
That's too kind strikes again! Thanks, Oliver. Can I further abuse your generosity and ask for the amendments below? (C7 part, 50meg XO, UDP). Otherwise final, I think. Convenience at its finest, too cool this GUI
{  "name": "Mecanix5ax",
  "description": "Mecanix5ax",
  "type": "GW1NR-LV9QN88PC7/I6",
  "pinimage": "board.png",
  "family": "GW1N-9C7",
  "toolchain": "gowin",
  "_toolchain": "icestorm",
  "package": "",
  "protocol": "UDP",
  "clock": {
    "speed": "50000000",
    "pin": "52"
  • Aciera
  • Aciera's Avatar
15 Aug 2024 07:32 - 15 Aug 2024 07:43
Replied by Aciera on topic Change the axis limit
Category: AXIS
The short answer is, yes, you can change axis limits through HAL connections as well as through GCODE but there are a few things you need to be aware of.
- Axis limits are exposed as hal pins only after the GUI has started up. So any hal connections would need to be made in the POSTGUI_HALFILE
linuxcnc.org/docs/html/gcode/overview.html#gcode:ini-hal-params
As stated in the documentation #<_ini[section]key> parameters are read_only so if you want to change the value from Gcode you have to use a custom Mcode that uses a script language (eg tcl or bash) to execute a 'halcmd'
- Changes to ini parameters during GCODE execution will only become effective AFTER a quebuster command (eg M66 E0 L0)
My usual solution to change ini parameters from GCode is this:
1. save this bash script as 'M123' to a folder named 'mcodes' in your machine config folder and mark as executable:
#!/bin/bash
P=${1%.*}
Q=${2%.*} # in case you want to use the second parameter to0
echo " P: ${P} Q: ${Q}";
case $P in
11) echo „X min limit“
halcmd setp ini.x.min_limit $Q;;
12) echo „X max_limit“
halcmd setp ini.x.max_limit $Q;;
21) echo „Y min_limit“
halcmd setp ini.y.min_limit $Q;;
22) echo „Y max_limit“
halcmd setp ini.y.max_limit $Q;;
esac
exit 0
To make sure that the changes are actually used we call the above script from a GCODE subroutine.
2. Save the following code as 'm123_wrapper.ngc' and save to a folder in your [RS274NGC]
SUBROUTINE_PATH
; this is the wrapper for the bash script
o<m123_wrapper>sub
M66 L0 E0                 ;force sync, stop read ahead
o100 if [EXISTS [#<P>]]
o100 else
    #<P> = 0              ;if no P word has been passed we use the default (0)
o100 endif
o101 if [EXISTS [#<Q>]]
o101 else
    #<Q> = 0              ;if no Q word has been passed we use the default (0)
o101 endif
M123 P#<P> Q#<Q>          ;call the bash script
o<m123_wrapper>endsub
m2
To make linuxcnc aware of these mcodes add these lines to the [RS274NGC] section of your ini file
USER_M_PATH = ./mcodes
      REMAP = M423  modalgroup=10 argspec=PQ  ngc=m123_wrapper
Note 'argspec=PQ' will enforce that the 'M423' command is followed by a 'P' word containing the code for which axis [X(1),Y(2)] and which limit [min (1), max(2)] should be changed and a 'Q' word containing the limit value.
example usage:
M423 P12 Q401
will set 'ini.x.max_limit' to '401'
The parameter handling can be changed to your specific requirements in the 'case' part of the bash script above.
  • meister
  • meister
15 Aug 2024 07:26
the board files are actually quite simple:
github.com/multigcs/riocore/blob/dev/rio...ecanix5ax/board.json
the only thing missing there are the fpga pins
“pin": ‘0’,
Displaying 23866 - 23880 out of 24414 results.
Time to create page: 0.657 seconds
