  • dave.franchino@gmail.com
14 Aug 2024 18:55
configuring GPIO for a Raspberry Pi 4B was created by dave.franchino@gmail.com
Category: Configuration Tools
Hey kind folks,
I am working to configure a Raspberry pi 4B to run LinuxCNC for a two-axis machine I'm building.  I am using the HAL driver for Raspberrry PI GPIO pins (hal_pi_gpio).
I am proposing to use the following pins:
net Xdir => hal_pi_gpio.pin-15-out
net Xstep => hal_pi_gpio.pin-16-out
net Ydir => hal_pi_gpio.pin-18-out
net Ystep => hal_pi_gpio.pin-22-out
When I start LinuxCNC the HAL file appears to be loading properly.
But if I go to a terminal and say Halcmd show pins  - it appears to be showing my pins configured as INPUTS - not outputs?
(I'm assuming that's what the direction column in the show pins command means).
nc@raspberrypi:~/Desktop$ halcmd show pin
Component Pins:
Owner   Type  Dir         Value  Name
    28  bit   IN          FALSE  hal_pi_gpio.pin-15-out <== Xdir
    28  bit   IN          FALSE  hal_pi_gpio.pin-16-out <== Xstep
    28  bit   IN          FALSE  hal_pi_gpio.pin-18-out <== Ydir
    28  bit   IN          FALSE  hal_pi_gpio.pin-22-out <== Ystep
I'm pretty sure I did the math on the mask right although I could be wrong. To confirm, I just tried masking for one output and it still shows up as IN.
The documentation says I should add up the hex values for all pins that should be configured as an output which I think is what I've done.
Anyone see what I'm missing?  Thanks!!!!
my full .hal file follows:
# Generated by stepconf 1.1 at Fri Nov 17 17:18:50 2023
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
# Load the Raspberry Pi GPIO driver
loadrt hal_pi_gpio dir=0x00F00040
loadrt stepgen step_type=0,0
# Add to the base thread
addf hal_pi_gpio.read base-thread
addf hal_pi_gpio.write base-thread
addf stepgen.update-freq servo-thread
# Configure output pins
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
  • blazedforever
  • blazedforever
14 Aug 2024 18:51 - 14 Aug 2024 19:31
Replied by blazedforever on topic Configuring a dual stage axis
Hey thanks for that information! I think it will probably be fine for my needs, mostly light duty stuff and the stage I have planned seems rigid enough. I kind of want to give it a go and see the results. If anybody has more information or examples on how this configuration might work that would be appreciated. I'm digging into the manual , still at a bit of a loss on where to start.
  • RMJ fabrication
  • RMJ fabrication
14 Aug 2024 18:27 - 14 Aug 2024 18:29
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
My computer is not connected to the internet and has no wifi should I connect to the internet and try again? I used a cable to do the installation and then I disconnected it to connect the 7i76e.
  • Hauligali22
  • Hauligali22
14 Aug 2024 18:06
Replied by Hauligali22 on topic Linuxcnc with Computer Vision …
Hi Hamel2020,
I am currently attempting to integrate computer vision in a cnc machine to develop a closed-loop system. My idea was also to hopefully update the original g-code in real-time but I have been also recommended to use external offsets instead. What progress have you made? Thanks!
  • PCW
  • PCW's Avatar
14 Aug 2024 17:58
Category: Plasmac
Yes, looks like you have no network connectivity.
What does
ip a
report
14 Aug 2024 17:49
Replied by tommylight on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Sorry but i can not help you with stuff i have no clue about, the bash is trying to run an executable file that i do not know what it contains, etc, etc.
I do admire your will to try and fix it and you being hell bent on learning new stuff, but at some point you have to cut the losses and move on.
Find another hard drive, cheap used one, install everything you need, and if this succeeds, then get rid of the old one. This way you still have a backup.
14 Aug 2024 17:45
Category: Plasmac
On your screenshot, it clearly states to do
sudo apt-get update
and try again
Although, this being a networking issue, i have to ask:
-how is the PC wired to internet?
-If wired through cable, did you revert back the network settings?
  • Muftijaja
  • Muftijaja
14 Aug 2024 17:17
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Hello tommylight! I know, you said this somewhere at the beginning of this thread. I must say, I did not know anything about the fickleness of this theme. I am (now as before) absolute newbie to Linux and Linuxcnc, I made my config with the wizard and afaik, I did not touch the /etc/network files at any time until someone in this thread told me to do this. I did not play around with settings but tried to consolidate the network with the help of the guys here. If I have done sth. wrong, I apologize.
Any help with my latest questions (bash) is welcome.
Cheers, Hanno
  • RMJ fabrication
  • RMJ fabrication
  • besriworld
  • besriworld
14 Aug 2024 15:52
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
Thank you! Yes, I also use it as a control panel.
OK, no problem!
  • Todd Zuercher
  • Todd Zuercher's Avatar
14 Aug 2024 15:41
Replied by Todd Zuercher on topic Configuring a dual stage axis
I think it could be done in multiple ways. I'm sure you should be able to find some configuration examples out there where people have set up Linuxcnc to control knee mills with both the quill and knee contributing to the Z axis position, this would be nearly identical.
It might be better to simply do it using X and U axis, where U would be the extra stage mounted on the X. This set up would give you better control over when and how each axis is used. Alternatively you could simply use a Kinematics model were X is the sum of the two X axis joints, but this might give you less control over when or how each joint contributed to the position and movement of X.
It may even be possible to configure it using a custom Kinematics where the X-axis = joint0 + joint3 and the U-axis = joint3. Allowing you to use U commands to control the extra stage's position, but still have it automatically contribute to the final X position.
(I have never actually tried any of this myself.)
All that said, is this really a good idea? Adding a lot of cantilevered forces and movement beyond the machine's designed structure could have less than desirable results (such as magnifying/multiplying tolerance errors and greatly reduced rigidity.)
  • PCW
  • PCW's Avatar
14 Aug 2024 15:24
Replied by PCW on topic OLD Lathe conversion to a CNC
Category: Turning
Since the 7I73 was designed for control panels and not direct machine control
it does not automatically disable outputs on a fault. I suppose that feature could
be added but it might make more sense to use a 7I84/7I84U in that case.
  • mighty_mick
  • mighty_mick's Avatar
14 Aug 2024 14:59
How can I modify trivkins.c? (and also other kinematics files)
Hello winyk. I've read your post, and there are few things i wanna mention.
I've developed custom kinematics module for my machine a while ago. Since you are starter, i suggest you to learn HAL layer of LinuxCNC first.
HAL layer is nothing but modules that run at background in while loop, with some sleep. Don't consider this layer as a software layer, it is actually a system that gives you ability to configure your modules, make them able to communicate with each other and allows you to collaborate across modules. In while loop, they checks some conditions, some values etc. and do the work. These modules are named as 'hal component'.
At the core of LinuxCNC, there is a motion hal component. You can check it in the documentation given below:
--> linuxcnc.org/docs/devel/html/man/man9/motion.9.html
This hal component is responsible for interpreting G-code commands and converting them into real-time control signals for machine's hardware. When you give "G90 G0 X10" command,
this is the component which gets 10 value near X and convert it to control signals for motor controller. This conversion uses your kinematics module. Your kinematics module is also a hal component, and the starter script loads it at the beginning. If you check your hal file, you are gonna see some lines like below:
loadrt trivkins
loadrt motmod servo_period_nsec=<value_from_your_ini_file> num_joints=<value_from_your_ini_file> tp=tp kins=<value_from_your_ini_file>
If you know what ini file format is, these lines gonna look like below.
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES tp=tp kins=[KINEMATICS]KINEMATICS
Since you are giving the file name of your kinematics module in your .ini file like below:
[KINEMATICS]
KINEMATICS=mykins
The motmod hal component uses your kinematics component to make the calculations.
After you run "halcompile --install mykins.comp" command, the halcompile exe does these steps given below:
1. Convert .comp file to appropriate .c file
2. Compile generated .c file with system's compiler, generate a shared library (.so file)
3. Locate that .so file in /usr/lib/linuxcnc/rt-preempt/ directory.
Since you are new in C programming, you need to learn basic flow of compilation of a .c source file. You need to check what is .so file, how it can be used etc. to understand concept. The key thing you need to know is, you are generating a calculation module which exports some symbols with names as 'kinematicsInverse, kinematicsForward, .. etc.', you are locating it in the system's directory. After that, during the start of LinuxCNC, it loads motion hal component with that hal component. So the conversion and calculation of machine movement is being calculated by your code. There are so many things you need to know, but this is a basic flow.
If you wanna change the direction of your X axis, you need to change kinematicsInverse function only. The j variable is responsible for generating physical coordinates. You are getting commanded value from const EmcPose * pos variable, which is your commanded coordinate of machine, and forwarding it to physical value. This is the point that you give 10 and make it -10. So, don't change both of them to negative, change only 'kinematicsInverse' to negative. If you do this, hopefully you are gonna see your "G90 G0 X10" command is resulted as X=-10. If i am wrong, maybe i need to remember some things.
I developed some kinematics module to fix geometrical errors of my machine(squareness, straightness) a while ago. I was adding extra moves to X,Y,Z axises according to each other to neutralize the physical oscillation that one makes along any axis. There are different topics that you can use this kinematics module, but this is the core flow. If you have any other questions, i would be happy to discuss them.
Don't forget, if you are trying to change kinematics module, you need to change your ini file. Check the given link below:
--> linuxcnc.org/docs/html/config/ini-config.html#sub:ini:sec:kins
If you don't change your ini file, your hal component can't be loaded. I assume the reason that you didn't get the right result is giving negative value in both reverse and forward functions, but i can be wrong, so don't forget to check your ini and hal files.
  • Todd Zuercher
14 Aug 2024 14:12
Replied by Todd Zuercher on topic LED to indicate M3/M5 status
Category: GladeVCP
For the 2nd option. To display an image instead of Hal_LED's small colored circle or box, the simple answer is you can't. You must use a different widget to do this. You could use a GtkImage widget to display your images for spindle ON and OFF, then use your Python handler file to define what images are displayed and create the nessisary hal pin to select between them.
I've done something similar to this, but more complicated for the spindles on a machine I've set up. On that machine I have multiple spindles controled by Modbus, and I set up a series of GTK Images to display the status of each of them. It uses S32 hal pins to display one of about a dozen different images for each VFD, such as "Com Error", "Run", "Stop", "Accel", "Decel". "Fault"...
14 Aug 2024 13:45
Replied by tommylight on topic OLD Lathe conversion to a CNC
Category: Turning
You should ask that in the "driver boards" section of the forum as i am not sure PCW monitors this side of the forum, well i am sure he does sometimes, but not sure if always.
Displaying 23926 - 23940 out of 24414 results.
Time to create page: 0.901 seconds
